LP Build #2 (Eastern Maple Carved Top content)
Discussion in 'Luthier's Corner' started by 73Custom, Jan 14, 2010.
  1. 73Custom
    73Custom Senior Member
    1,259
    39
    Dec 2, 2009
    Here's my first build (still underway, but getting there) where i decided to practice with cedar and aspen (home depot exotic woods, lol) so i could gain some skill before touching mahogany and maple... It didn't start as a build thread, but it turned into one...
    http://www.mylespaul.com/forums/luthiers-corner/70871-template-advice-needed.html
    anyway, here's the carved top i bought for this build.
    here's my stewmac ebony fretboard and mop inlays...
    this is what i am thinking about doing with the colors...
    The Plan:
    Mahogany Body (one piece blank, purchased from HC member)
    Mahogany Neck 24.75" (blank purchased from Grizzly)
    Maple Top (pre-carved flame top purchased from Eastern Maple Carved Tops, Thanks Tom !!! :thumb:)
    Ebony Fretboard (Stewmac)
    Custom Style Inlays (Stewmac)
    Holly Headstock Veneer (Eastern Maple Carved Tops)
    Bone Nut
    Not sure on hardware or pickups yet...
    :wave:
  2. 73Custom
    1,259
    39
    Dec 2, 2009
    here's the neck blank from Grizzly... enough for two necks... :thumb:
  3. 73Custom
    1,259
    39
    Dec 2, 2009
    inlays numbered and laid out on the ebony board
    shaved the back of the board down until it was about 3/16" thick. i collected the sawdust to use to make filler later.
    taped up and ready to go
    i centered the inlay and drew an outline of it.
    next i used a razor blade to score the board and cut away the tape.
    aligned a straight edge to help the dremel cut clean and straight...
    1st inlay slot cut...
    :thumb:
  4. 73Custom
    1,259
    39
    Dec 2, 2009
    inlay work...
    in the meantime, i did a very rough cut on the neck...
  5. 73Custom
    1,259
    39
    Dec 2, 2009
    inlays cut, fret slots covered, ready for ebony filler...
    the magic goop: testers model cement and left over ebony sawdust...
    all the gaps filled and drying...
  6. 73Custom
    1,259
    39
    Dec 2, 2009
    ready to trim to size and sand the filler and inlays down to the 12" radius...
  7. 73Custom
    1,259
    39
    Dec 2, 2009
    trimming the fretboard using my table saw. i use double sided rug carpet tape to hold the board in place.
    then i created a jig to keep the radius block on center while sanding the inlays down to meet the board. again, double sided rug carpet tape to hold the board in place.
    i went from 100 grit up to 800 grit. you can see at first it's a lot of inlay coming off. sand paper is held to the radius board with double sided carpet tape, deja vu... (just wait, all the templates for routing are held with the stuff too, lol)
    after a while with the 100 grit i start to get the inlays leveled down to the board... i have as much ebony coming off as MOP...
    here's the trimmed and sanded ebony with a little lemon oil rubbed on it...
    next i bent some fret wire to a 12" radius using my handy, dandy homemade fret bender...
    finished fret wire...
    btw, if you are interested in how to build the fret wire bender following this link. i wasn't gonna pay $100 from stewmac and an HC member pointed me to these plans... i used sander paper and double sided tape instead of the outdoor tread tape and the whole thing cost me about $18.....
    Make Your Own Inexpensive Fret Bender
  8. 73Custom
    1,259
    39
    Dec 2, 2009
    btw, I owed credit to Scott (Ex-Nihilo), Fletch and other builders here to some of the ideas, jigs, etc..., you see in this build...
    So thanks guys for your build threads and videos...
  9. monsterwalley
    monsterwalley Senior Member
    2,421
    1,323
    Jan 31, 2009
    Cool man! Another build. :thumb:
    Looks great so far.
    I'm rounding up stuff to hopefully do another build, maybe two at the same time. :fingersx: Hopefully soon.
  10. 73Custom
    1,259
    39
    Dec 2, 2009
    chamfering(beveling) the slots prior to fretting... just one or two drags of the file does it...
    fretting has begun. use the fret cutters to cut the fret wire...
    i use a fret hammer to seat the fret wire...
    and then some fret pullers to remove the fret, add superglue and press back in place.
    board is prepared for glue and the press...
    i use gel superglue, much cleaner and less runs.... ;)
  11. JonMan94
    JonMan94 Senior Member
    6,477
    1,657
    Sep 22, 2008
    damn.... good job dude!!
  12. 73Custom
    1,259
    39
    Dec 2, 2009
    here is the three drops of gel superglue...
    tapped back in with the hammer and then pressed...
    quickly wipe the glue off the fretboard before it dries...
    once they are all glued, reset and pressed, it's time to trim the edges.
    finished :D
  13. 73Custom
    1,259
    39
    Dec 2, 2009
    thanks guys... :dude:
  14. 73Custom
    1,259
    39
    Dec 2, 2009
    next up, glue on a white binding to the ebony board...
    the binding glued up... next is knocking it down between the frets to form the nibs...
    btw, i just used the superglue gel for the binding...
  15. nuance97
    nuance97 Premium Member
    2,172
    1,231
    Feb 26, 2009
    Really Nice 73Custom! I can tell that your first build has given you a lot of confidence.:thumb:
  16. 73Custom
    1,259
    39
    Dec 2, 2009
    here's the technique i use to cut down the binding and create the nibs... thanks Ex-Nihilo
    first i stick a dremel bit in backwards into the dremel...
    then i wrap the end of the exposed bit with tape to protect the fretboard. leave just about 1/8" of the bit exposed...
    i stole this picture from ex-nihilo (giving creadit where it is due), but this is the final step in bringing the binding down even with the fretboard...
    and now my mahogony...
    my 1 piece mahogany body... :thumb:
    some sexy wood !!! and heavy...
  17. 73Custom
    1,259
    39
    Dec 2, 2009
    thanks man... and you are very correct about the first build and i am extremely happy i did that one first... :thumb:
    i am really enjoying myself :applause:
  18. GooCart
    GooCart V.I.P. Member
    1,699
    1,211
    Jun 23, 2008
    Wow, you like the Lightning!!You don't waist any time. I really like your design approach for the build. I think the red top is going to be very cool.
  19. 73Custom
    1,259
    39
    Dec 2, 2009
    [ame=http://www.youtube.com/watch?v=I2iss1SrC5I]YouTube - Leveling Neck Binding[/ame]
    [ame=http://www.youtube.com/watch?v=OcIeR-drQDI]YouTube - Scraping a Neck Binding[/ame]
    and one more pic from the side after the razor scraping...
    this is all followed up with a fret file to help shape the nibs and then some 220 grit sandpaper and then 400 grit to finish everything off...
    be careful with the sandpaper. if you stay in one place too long you will melt the binding... ;)
    first i angle the binding over the frets with a flat file...
    next, i use a fret file bring the binding down to fret level....
    after a little sanding with the 220 grit...
    still have to go back and clean up the fretboard and do a little more sanding...
    then further down the line after applying the binding to the body of the guitar, i will create a acetone/binding glue dubbed "binding goop" by some HC member. not only is that good used to glue on the body binding, but it's great for filling in little spots on the binding that might need filling...
    there a few where i hit the binding with the dremel chuck. later in the thread i will fill those and sand them to invisible :thumb:
  20. decoy205
    decoy205 Senior Member
    7,889
    1,879
    Sep 10, 2007
    Nice job dude! Looks great. man when you realize all the money you need for tools for this it's nuts! Looking foward to the rest man.
