LP bridge volume does not go to zero
Discussion in 'The Custom Shop' started by cnote, Feb 6, 2018.
  1. cnote
    cnote Premium Member
    601
    1,084
    Jun 17, 2010
    I know usually this means the third lug is not grounded to the back of the pot, or that it's a cold joint, but it is grounded, so something else is going on.
    I have swapped out 3 bridge volume pots, and it's the same problem with each pot. I have checked the whole harness with a multimeter, and get null resistance across all solder joints. I have checked that third lug many times, and with each pot, and it is solid and not a cold joint. That it has been the same with different pots makes me think there is something else going on elsewhere in the circuit.
    When I roll down the bridge volume, it performs normally, getting quieter smoothly, but then the right about 0 the fullness disappears and a thin quiet clean tone is heard through the pickup at 0. It's a nice clear jangly clean tone, but it shouldn't be there.
    The switch is grounded adequately to the back of the BV pot - 0 resistance across that solder joint.
    The ground wire is also adequately soldered all around - 0 resistance at all points.
    Any help appreciated - what else could it be? Thank you.
  2. swampblues
    swampblues Senior Member
    4,053
    2,995
    Mar 1, 2011
    Make very sure your bent soldered tabs on pots are making good ground
  3. Fred
    Fred Premium Member
    258
    69
    Feb 8, 2010
    Can we get a picture of your switch?
  4. cnote
    601
    1,084
    Jun 17, 2010
    Thanks all. Figured out I had the bridge and switch wires crossed. So I had it wired for independent controls, rather than 50s wiring, and with independent controls (pickup to middle lug) the pickup volume will never go to 0.
