Low bridge?
Discussion in 'Gibson Les Pauls' started by Jefferson389, Dec 6, 2017.
  1. Jefferson389
    Jefferson389 Junior Member
    24
    12
    Jul 14, 2017
    I just bought a new 2017 LP traditional and I noticed that the bridge is lower than what I've seen on other LPs, particularly on the low E side. This is after I've adjust the neck to proper relief and action at 5/64" and 4/64" on high and low e strings respectively. I also noticed that there isn't that much difference in bridge height between the bass side bridge post and treble side bridge post (I recall there being a bigger difference on other LPs I've played) . I measured them and from the body to the bottom of the thumbwheel is 9-10/64" on the bass side and like 6/64" on the treble side. I included a pic of the bass side below.
    Functionally everything seems ok because both sides of the bridge have room to go lower than they should go, so adjustability isnt an issue. The guitar plays great as well with no signficant buzzing. I just wanted to make sure that the low bridge height and minimal difference between high and low e sides of the bridge doesn't indicate some sort of a problem.
    rdbear7d, Christosterone and mudface like this.
  2. mudface
    mudface Senior Member
    4,473
    13,039
    Aug 29, 2016
    No sir, your guitar is just fine. You are lucky to have a neck set that came out PERFECT. :cheers:
    More pics please.....
  3. TradPro2
    TradPro2 Senior Member
    295
    243
    Oct 23, 2014
    the bridge height looks ok but I would take your little ruler and now check the height of the pickups as it appears
    they now may be too close to the strings, you maybe need to lower them a tad
    they may be close to perfect and i cannot tell from the pic but I would check the pickup height
  4. scozz
    scozz Senior Member
    3,226
    3,686
    Sep 3, 2007
    Yup...they definitely look too high in that pic.
  5. ajay
    ajay Senior Member
    845
    545
    Jun 3, 2015
    Joe Walsh says that the perfect tailpiece is the one sitting on the top. I don't think that it can be too low as long as the intonation is right on. I know that Joe isn't the best in the world, but I believe hat he knows a lot about setups.
    brianbzed likes this.
  6. Christosterone
    Christosterone Premium Member
    2,728
    2,372
    Jul 12, 2016
    As @mudface said, you got the absolute perfect Lester..
    Wow
    -Chris
    mudface likes this.
  7. alnico59
    alnico59 Senior Member
    1,061
    789
    Nov 25, 2014
    Yeah, Gibson is moving away (thankfully) from the high neck set that usually requires a top wrap. Yours is good to go.
  8. jc2000
    jc2000 Senior Member
    6,212
    2,973
    Jul 16, 2013
    I would like that on mine...
    Charlize likes this.
  9. rdbear7d
    rdbear7d Senior Member
    164
    93
    Jan 23, 2012
    That looks great man..
    here's a pic before bsw kit from Faber..
    After
  10. PierM
    PierM Black & Gold Premium Member
    2,848
    4,317
    Aug 19, 2016
    If you have all setup as you want, and this is the result, you are lucky because could be you have a neck joint in the 4.4/4.5° angle, instead the crazy 5° that they use for USA models. :)
  11. motorboy1
    motorboy1 Member
    50
    17
    Mar 25, 2011
    I have a 2017 Traditional and bridge is the same. My action is 1/16 low E and just under for high E. I still have a little to go maybe 1/32 on the bridge if necessary. Perfect in my opinion. Stop piece is flush with body and strings are not hitting the bridge..
  12. Jefferson389
    24
    12
    Jul 14, 2017
    Thanks for everyone's responses.
    I ran into another thing with this guitar- I was looking at the neck relief when adjusting the truss rod and I noticed that the relief at the high e sides might be slightly different. However, it's very close and it was tough to tell if there really was a difference. I'm just a bit paranoid because I had another guitar with a twisted neck before. So I had two techs look at it, and the first one said he didn't see any indication of a neck twist based on checking the relief. But the second guy sighted down the neck and said he saw a very slight twist, but that this was pretty normal and something you'd find on most guitars. What do you guys think?
  13. gball
    gball Senior Member
    603
    513
    Feb 23, 2016
    Probably just fine. The proof is in the playing and if it sets up and intonates correctly and plays and sounds right then you are good to go. As for the bridge height, as others have said that one looks about perfect. Both my '16 Trad and '79 Custom look just like that. FWIW so does my '17 SG Std.
  14. jlb32
    jlb32 Senior Member
    5,026
    4,104
    Oct 17, 2009
    To many the optimum setting is to have the bridge sitting on the body of the guitar or as low as possible. Added sustain and clarity many state. In the case of your guitar, you are great. The lower the better seems to be the preferred.
  15. bryvincent
    bryvincent Senior Member
    1,019
    437
    Oct 16, 2008
    that bridge is actually still relatively high compared to most historics with real vintage style abr posts. but it is lower than most USA Gibsons.
    the nashville-style post/thumbwheel makes it look low. if you convert it to vintage-style posts it would look high or about average height.
  16. PierM
    2,848
    4,317
    Aug 19, 2016
    Different neck angles.
    mudface likes this.
  17. jlb32
    jlb32 Senior Member
    5,026
    4,104
    Oct 17, 2009
    I have Nashville and ABR bridges that sit super low or at the body. Depends on the guitar.
  18. brianbzed
    brianbzed Senior Member
    2,160
    966
    Aug 14, 2008
    Check out Joe's Carvin demo dvd.He talks in detail about his favorite old Gibsons with a low bridge and tailpiece.
  19. mudface
    4,473
    13,039
    Aug 29, 2016
    The Nashville on my Custom. The reflection throws it off but it's about as low as it goes:D
  20. bigtimelp
    bigtimelp Junior Member
    21
    6
    Oct 15, 2017
    You scored man! That's a nice low angle, exactly what you want.
