Lots of People Looking For/At Low Wattage Amps!
Discussion in 'The Squawk Box' started by hipofutura, Oct 1, 2009.
  1. Slick
    Slick Senior Member
    2,504
    2,722
    Aug 18, 2009
    Fender Pro Junior (15w) - I've got one and its great, only problem is no master volume so at home I use an attenuator but it still has the guts for small gigs :thumb:
  2. Torren61
    Torren61 Senior Member
    12,437
    16,754
    Dec 25, 2008
    The funny thing is that low watt amps have been used in the studios of you favorite bands for years. Page, Richards, Walsh and Gibbons have recorded some of the baddest and most memorable guitar parts on low watt amps. The arena rock era required higher watt amps but that's not what the big boys preferred in the studio. It's not all that hard to make a small amp sound large.
    What IS new is the marketing end of low watt amps. Amp manufacturers have finally recognized the desire of the "stay-at-home" guitarist for an amp that he can crank without getting arrested or evicted.
    The pitfalls that I see are quality issues. Are you getting bang for your buck? Are you getting TONE for your buck? I think the answer is still shaping up.
  3. Lungo
    Lungo Silver Supporter
    6,382
    9,228
    Feb 19, 2009
    A couple more low wattage amps to add, both right at $400:
    Carvin Vintage 16 - 5watt/16watt tweed amp, 12" speaker with reverb
    Mahoney Orchestrator, found it on musictoyz.com:
    The Orchestrator amp is based on a 1950's style Mullard push-pull circuit with slight modifications using vintage Germanium transistors .... AC125 and AC126 on the front end and two AC128's on the output side. It also features both driver and output transformers that mimic the sound we are familiar with. The speaker box contains a custom made Weber 6.5" 4 ohm twin cone driver speaker. The amp is powered by a standard size 9 volt battery. Its power output is approx 1 watt.
    truckermde likes this.
  4. TeleDog
    TeleDog V.I.P. Member
    8,913
    2,858
    Jan 6, 2009
    I'm still looking!
    I have a freaking half stack and the thing is way, way too loud for this place! I rewired a valve jr (sounded like it was farting as you turned the volume up), but I'm still waiting for a couple parts.
    I heard lots of good things about the AC4, but I don't know if the reviews are biased by the whole "Vox" thing. Never tested the Class5 by Marshall.
    The thing is sometimes when I just wanna play a bit, it's nice to have a little amp that won't get the police called as a matter of national emergency, it's frustrating!
  5. BillB1960
    BillB1960 Senior Member
    15,908
    21,224
    Jun 1, 2008
    The more I see some of the newer low wattage amps coming out the more I realize Crate got it right with this little sweetheart, the Vintage Club 20:
    15W all tube (sans rec), cathode biased, reverb, 10 in. speaker, external cab jack, headphone jack, US made & built like a tank. I bought 2 of them for $220 and sold 1 for $250 less than a year later. I still have the other and it's great for home use.
  6. Paragon
    Paragon Senior Member
    1,288
    41
    Apr 10, 2008
    Vox Valvetronix VT30 - Modeling amp easy to go from fender cleans to high gain, 10" speaker, adjustable from around 1-30W. The VT15 has a smaller 8" but I think the VT30 sounded better with the larger speaker and 15W through the VT30 should have less power hum/buzz than the VT15 fully cranked.
  7. GibbyTel
    GibbyTel Member
    45
    10
    Oct 2, 2009
    Ballparking it, the VT15 should get to about 106db and the VT30 to about 109db, not a big enough difference to worry about unless you're always running them cranked.
    At a studio setting where you'd worry about a little power hum/buzz you're only using maybe 1 watt and there shouldn't be any difference in the hum, unless there's something wrong with the smaller amp.
    I really liked the VT15, especially for the money.
  8. LPGEM
    LPGEM Senior Member
    397
    24
    Jul 1, 2008
    The company is Songworks. Owned and run by Tris Mahaffey. The only ALL tube amp is the 1/4 watt. The others including the 3350lt and hi/low watt plexi are 1 pre amp tube fed to a pre amp tube acting as a power tube for that section. It is than fed to a Solid state power section. My bad. I just found out that the name has changed from Songworks to Mahaffey Amplifiers.
  9. Belzeebub
    Belzeebub V.I.P. Member
    2,721
    56
    Apr 1, 2008
    Here's my humble contribution to this thread...
    Epiphone Valve Jr. combo, 5w class A, 8" Eminence speaker best of all...
    $60.00 out the door.
    Equipment used in the video - Squire bullet strat, Boss DD-6 delay and of course the EVJr.
    [ame=http://www.youtube.com/watch?v=ZNalTriCtcw]YouTube - Blues2[/ame]
  10. jonesy77777
    jonesy77777 Senior Member
    1,647
    325
    Oct 23, 2008
    My 18 Watt tube Atomic Reactor amplifier sounds better than any other amp I have tried with a PodXt live board. It is essentially an all tube power amp. They have larger models, and though they are relatively unknown, those that do know of them love them.
  11. ElhazGuy
    ElhazGuy Senior Member
    1,063
    357
    Sep 15, 2009
    Amazing tips to people like me, who's thinking of buying some little amp.
    Thank you for the precious informations.
  12. tn1dagger
    tn1dagger Member
    72
    0
    Jun 7, 2008
    dont forget the matamp minimat
  13. rumbling_groover
    rumbling_groover Senior Member
    760
    37
    Aug 6, 2008
    What about a some older models like a Gibson GA15RV or a Trace Elliot Velocette these can be found for good prices secondhand.
    Then there are the more boutique THD Univalve, Cornford Harlequin and Cornell Romany.
  14. Deftone
    Deftone Senior Member
    12,312
    9,584
    Feb 22, 2008
    Hiwatt makes a 7 & a 20 watt head:
  15. patrick ginnaty
    patrick ginnaty Senior Member
    916
    110
    May 31, 2008
    I've been plugging straight into a 12 W SF Princeton Reverb with a JBL K120 speaker.
  16. hipofutura
    hipofutura Senior Member
    6,986
    2,425
    Feb 8, 2009
    Patrick, Fender & JBL. It doesn't get any better than that! I've run D120's in a Bandmaster and D110's Super Reverb. I presently have an E120 in my 35 year old Traynor YRM-1.
  17. Quill
    Quill Senior Member
    4,548
    3,038
    Sep 15, 2009
    Really nice sound, Belzeebub.
    The Velocette! I love those little amps. If you can get one that someone else has repaired/upgraded - the stock transformers tend to blow on those - you are in good shape! I once had two of them: the green one with the cloth grill and two EL?? power tubes, and the beautiful and fairly rare black one with the chrome grill that would take just about any power tube that would fit - like a budget Univalve! (but the Univalve would really be worth the money, I think.) Had to get the transformer replaced in the green one ... got the plastic tube sockets replaced with ceramic ... the pcb needed some work ... the repairman swore he'd never work on one ever again ... but once that was done, it was fantastic! One of those things I regret selling all the time.
  18. leeplaysblues
    leeplaysblues Junior Member
    3
    1
    Oct 21, 2009
    I like both the Mesa 5:25 Express and the Blues Junior. Play both at home and live and they cover the bases.
    Had a Hot Rod Dlxe 2 settings on and impossibly loud for both home and on stage (mic ├ęd).
    The Mesa is my favourite
  19. Skit
    Skit Witch Doctor Premium Member
    4,806
    3,889
    Jun 10, 2009
    I have a Little Lanilei 3350LT and love it. I'm waiting on delivery on a Peavey Classic 20 from the bay.
  20. Cygnus X1
    Cygnus X1 Senior Member
    6,570
    2,966
    Jul 18, 2009
    I'm all over it.
    It's called the Cygnus-7.
    PTP wired (actually terminal strips), 6V6/6L6/etc. family of power tubes, single ended, high gain capable...
    designed from the ground up as a low watt single ended amp.
    mourguitars likes this.
