Lose sustain with Aluminum tailpiece.
Discussion in 'Gibson Les Pauls' started by joesatch, Jul 29, 2013.
  1. joesatch
    joesatch Senior Member
    4,099
    2,711
    Apr 3, 2009
    When i switched to aluminum, i lost sustain. It is true. When i switched back to the heavy tailpiece, notes rang longer and harmonics were stronger.
    1 person likes this.
  2. slapshot
    slapshot Senior Member
    22,960
    23,630
    Aug 21, 2010
    locking studs
  3. joesatch
    4,099
    2,711
    Apr 3, 2009
    I have them. Screwed down tight as hell. Can't get 14th fret pinch harmonics on the 3rd string. With the heavier tailpiece i can.
  4. christianpaulanderson
    christianpaulanderson Senior Member
    398
    219
    May 8, 2013
    Rub bacon all over the aluminum tailpiece and jesus will fly out of the clouds and bless you with great tone. :hippie:
    14 people like this.
  5. Frogfur
    Frogfur Senior Member
    11,830
    16,354
    Jan 18, 2013
    Ok..then stick with that if it works for you. I personally switched to an Aluminum stop bar only because someone gave me one. I find that it brightened the sound to what ears i have left. Worked great and I'm sticking with it. Also added a ABR Bridge with nylon Saddles which together really gave me a balanced sound that is fantastic.
    Mine-
    [​IMG][/URL][/IMG]
    Sorry the photo is so large.
    4 people like this.
  6. River
    River Senior Member
    57,250
    91,237
    May 19, 2008
    Makes sense to me.
  7. LenPaul
    LenPaul Premium Member
    2,689
    3,297
    Jul 13, 2012
    Same for the 13th & 15th frets?
  8. joesatch
    4,099
    2,711
    Apr 3, 2009
    Just overall the difference is noticeable. I'm gonna look into a brass tailpiece. Not worried about weight atm.
  9. dspelman
    dspelman Senior Member
    9,444
    5,158
    Apr 30, 2009
    What does?
  10. River
    River Senior Member
    57,250
    91,237
    May 19, 2008
    More sustain from a more massive tail piece.
    3 people like this.
  11. splatter
    splatter Senior Member
    4,292
    3,490
    Sep 26, 2009
    callaham ( spelling) makes one out of stainless steel .
    It just makes sense to me . Its like with a floyd rose . The heavier the block the more sustain .
    http://www.callahamguitars.com/abr1.htm
  12. dspelman
    9,444
    5,158
    Apr 30, 2009
    I have heavy brass tailpieces on a couple of guitars. But on most of them the bridges are also fairly heavy and dense, and on a few they're screwed into a 10 ounce hunk of brass bolted inside a rout in a solid mahogany body. Now we're talking sustain.
    4 people like this.
  13. AxeBuilder
    AxeBuilder Senior Member
    2,184
    1,506
    Dec 29, 2011
    Why did you switch to Aluminum in the first place?
  14. joesatch
    4,099
    2,711
    Apr 3, 2009
    Its an R7. Came with it. Already put the callaham bridge. (albeit had to go to work on it with a file cause the machining sucked.)
  15. joesatch
    4,099
    2,711
    Apr 3, 2009
    OK i just bought the Callaham tailpiece. $107 ouch. I hope this solves it, its machined out of steel. Might also be time for a brass nut, hmm.
  16. lunchbox
    lunchbox Senior Member
    6,113
    7,517
    May 29, 2011
    I like the stock zinc tp's. I've never had a problem with tone or sustain from them.
    I did notice a huge difference having an aluminum wraparound on a CS Special; it was thin sounding. Cool in it's own way, but too thin for the type of music I play.
    I have zinc bridge and tp with locking studs on my current Standard, and it sounds great.
  17. River
    River Senior Member
    57,250
    91,237
    May 19, 2008
    I think you've got it.
  18. frankv
    frankv What Are You Waiting For? Premium Member V.I.P. Member
    13,813
    11,821
    Aug 25, 2011
    2 people like this.
  19. frankv
    13,813
    11,821
    Aug 25, 2011
    I was always under the assumption that the reason folks went to or want the light weight tail is because that is how the Holy Grail of guitars was setup.
    So this is the first time I am actually reading that some will deviate from that original setup. Usually a LP owner will "upgrade" his guitar to be more like the '59 not less...
    Perhaps this starts a trend? I have a worn heavy tail piece I was thinking about installing on my 81.. Only because since I put the aged tuners on her I dislike the brand new look of my Faber lightweight tail. Not because of tone or lack of sustain.
  20. voggin
    voggin Senior Member
    746
    715
    Jul 10, 2012
    Maybe the cycle has started again. I remember in the late 70s early 80s, everything was about "sustain", from pancake bodies to neck-through construction to heavy tailpieces to brass nuts. I believe at one point Yamaha would let you special order an entire Ford Anglia built into the body of an SBG 3000. I remember my poor soaking-wet 130 lb 16 year-old frame trying to wear some of those monsters on a strap.
    2 people like this.
