Loose press in bushings from Kluson tuners
Discussion in 'Epiphone Les Pauls' started by JB1978, Sep 30, 2017.
  1. JB1978
    JB1978 Junior Member
    20
    1
    Sep 24, 2017
    image.jpg Epiphone LP 2001 Custom
    Swapped out old stock grovers for the vintage style klusons
    Installed conversion bushings. They look good but some are too loose...they fall right out when flipping guitar over
    How do I fix this ?
  2. Rocco Crocco
    Rocco Crocco Senior Member
    6,400
    7,431
    Feb 8, 2013
    Wrap the bushings in plumbers tape to "shim" them.
    JB1978 likes this.
  3. Freddy G
    Freddy G V.I.P. Member
    10,071
    19,538
    Mar 18, 2007
    line the holes with CA glue...let it cure and then try. If still too loose, ad another layer of CA
    fumblefinger likes this.
  4. JB1978
    20
    1
    Sep 24, 2017
    Seems like this could work. Ever seen it done ?
  5. JB1978
    20
    1
    Sep 24, 2017
    I'm ignorant on the matter but I've read you're never suppose to glue it...not sure
  6. Rocco Crocco
    6,400
    7,431
    Feb 8, 2013
    ^Yes I did it on an Epiphone Les Paul.
  7. JB1978
    20
    1
    Sep 24, 2017
    Oh I misread it. I see what you're saying now...hmm
  8. JB1978
    20
    1
    Sep 24, 2017
    Did they ever come out after ?
  9. Freddy G
    10,071
    19,538
    Mar 18, 2007
    right ...i did not mean to glue them in
  10. JohnnyN
    JohnnyN Old School Premium Member
    3,774
    10,243
    May 15, 2010
  11. Rocco Crocco
    6,400
    7,431
    Feb 8, 2013
    no.
  12. JB1978
    20
    1
    Sep 24, 2017
  13. JB1978
    20
    1
    Sep 24, 2017
    I wanted to do the least invasive option
    This worked beautifully!!
    Thank you so much for your help
  14. Rocco Crocco
    6,400
    7,431
    Feb 8, 2013
    Glad it worked!
  15. JB1978
    20
    1
    Sep 24, 2017
    IMG_3228.JPG Continuing to work on my 01 Epi LP...
    Got the press in bushings problem solved thanks to Rocco!!
    Now I've noticed a little play (loose)in 2 of my tuning keys. Not at the key where you turn but at the post on the headstock. You can jiggle it back and forth and hear it rattling
    How can this be fixed?
  16. chasenblues
    chasenblues Senior Member
    19,140
    25,663
    Apr 2, 2007
    Have you strung it up yet?
  17. JB1978
    20
    1
    Sep 24, 2017
    Yes but didn't notice it loose, never thought to check. It has no strings on it currently ..in construction mode
  18. chasenblues
    19,140
    25,663
    Apr 2, 2007
    Did/do you only notice the rattle when the strings are off?
  19. JB1978
    20
    1
    Sep 24, 2017
    Honestly I do not know if it's loose with the strings on. I was string it up and then Let you know
