Limba 6 Multiscale + Filter'Tron
Discussion in 'Luthier's Corner' started by charisjapan, Jun 5, 2017.
  1. archey
    archey Senior Member
    998
    839
    Nov 28, 2010
    Beautiful work!
  2. charisjapan
    charisjapan Silver Supporter
    1,454
    1,403
    Jul 10, 2011
    Was pondering how to thickness the neck before carving. The Limba 6 will be a soft-V profile, and the other (to be announced) Padauk will be a C profile. I don't have a bandsaw, and rasping it down is tedious ... and potentially uneven. I had some other work to do on a gift to my daughter, so used the router table with a 12mm radius roundover bit, then a dishing bit to give me a 25mm neck thickness as a starting point for the carves. Next, marked centerlines and a pair of reference lines, just to get me in the ballpark.
    We'll see how this works out! o_O
    And notice the brace? Got tendinitis ... top of my right thumb is numb, and any extension is REALLY painful. Was prescribed Loxoprophen Sodium, and 3 days later seems to be getting better. Life goes on ... but after 60 there are (ahem) issues.
    :cheers2:
    n32 and mux164 like this.
  3. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Started playing with the neck carve up at the headstock. It's not a "V" yet, but I think the headstock transition might look something like this. I used a chisel, the Stew mac rasps, and mostly a card scraper. All this was kind of impromptu ... just stepped into the shop "for a second" and found myself needing to see what the headstock would look like. Perhaps some of you guys know the feeling?
    Went down to the heel, and found that I got over-exuberant on the router table. [​IMG] It's about 4mm beyond my mark ... guess I wasn't paying attention. After looking at things, I think I can salvage the situation by just carving the body back a bit. That heel area was kind of undecided anyway, so ... Shhhhh .... don't tell anybody!
    mux164 likes this.
  4. charisjapan
    1,454
    1,403
    Jul 10, 2011
    On a tangent, I loved working with Padauk so much that I bought a slab of it for a body to make a "Padauk 6" of approximately the same design as this guitar. My daughter asked me to make a few accoutrements for her condo (as if I haven't already done a "few things!") ... a small wall shelf, matching keyhook, and matching coathook. She "commissioned" (gratis?!) something "special," as he knows I have a stash. Well, I'm a softy, so chopped up my precious Padauk. Hope I can finish it before I go next week!
    But a few days ago, I won an auction for a gorgeous, humongous pieces of Padauk ... $40!! I am not seriously considering a one-piece guitar build, but this is certainly big enough for it.
    Cheers!
    n32, mux164, unclelonghair and 2 others like this.
  5. mux164
    mux164 Senior Member
    2,625
    1,879
    Sep 1, 2012
    Great save with the heel of the neck I have done that a couple of times, but since my guitars were chambered I couldn't do what you did so I re topped it.
    That padauk is gorgeous, makes me want to build with something else apart from pine
  6. fatdaddypreacher
    5,777
    3,784
    Feb 5, 2011
    dude, you are all over this guitar building thing. that is perhaps the finest fret board i have seen.....definately one of the finest i've seen in quite a while. your work is impeccable.
  7. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Awww, (looks down, shuffles feet) shucks. 'Twern't nuttin'.
    Thank you FDP! I really like the detail work, but sure hope I can get the larger pieces and finish done anywhere near as good. Those are my weak areas, and kind of dreading that part. You might say the Padauk pieces for my daughter are "practice," lol. (but don't tell her that!)
    :cheers2:
    fatdaddypreacher likes this.
  8. mux164
    2,625
    1,879
    Sep 1, 2012
    Hey Randy looking great, do you have a source where you got the template for the multi scale fret slots? I'm thinking I might have a crack soon
  9. charisjapan
    1,454
    1,403
    Jul 10, 2011
    I'll have to get to my office tomorrow to dig it out ... I made my own hybrid spacing. But it is essentially the same as a normal nut, just have to eyeball the path to the machine post. Here is the headstock design, which I *think* is correct. I just printed this out 100% and held it against the nut and made a pencil mark.
    Cheers!
  10. mux164
    2,625
    1,879
    Sep 1, 2012
    Sweet thanks, I meant the fret measurements, I haven't given them too much thought even though Andrew and rip thorn has done them and I liked them, but your build has got me thinking about making one
  11. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Oops! Mind was elsewhere. I used FretFind2D, and the link to my design is :
    http://www.ekips.org/tools/guitar/f...7&il[]=27.5&u=mm&sl=multiple&scale=et&o=equal
    Units are millimeters
    Multiple scale 628 - 648mm
    Perpendicular fret distance is 0.33258 ... in other words, 7th fret is my perpendicular
    String width at nut is 35.8mm
    Equal fretboard overhang of 3.6mm
    and used the root 2 calculation method for 24 frets.
    I then saved in multi-page PDF format using A4 paper, and taped the pages together (be careful to use the centerline!). After printing this out, I checked the measurements very carefully, and my HP printer did a spot-on job. I taped this to the fretboard and used a securely clamped flat block as my saw guide. The guitar is not yet together, so can't tell you that the frets are perfect ... but I sure hope so!!
    Cheers!
    mux164 likes this.
  12. Ripthorn
    Ripthorn Senior Member
    1,495
    1,150
    Mar 7, 2014
    This is how I have done it for each of my half dozen or so multiscale builds.
  13. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Used the sanding drum to "adjust" the area under the neck pocket ... to fix the goof I made with the "router method" of neck thicknessing. :p
    Next was a gouge chisel to get basic shape, then the card scraper to clean up there and the headstock ... and just kept going on the neck profile. Not the best way, but had lost of fun making long. curly shavings! ;) Some folks have mentioned Padauk odor, but mine must be a fragrant piece, pleasantly spicy.
    :cheers2:
    mux164 and KnightroExpress like this.
  14. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Got a bit more done on the neck profile, just using the card scraper. It's getting close to a soft-V-to-C that I like. The profile tool is the 1st and 7th frets, and with the fretboard on is 24mm at 1st fret, 23mm at 7th, and back out to 24 past 12th. I will pull the neck and put a straight edge to I and take some more profiles every few frets ... then go down about another millimeter for a somewhat slim profile neck ... similar to the EC strat neck, my favorite.
    Btw, I probably had more than five piles of shavings ... I wonder if Mrs.Charisjapan would appreciate a potpourri? ;)
    Oh, and never, NEVER throw a microfiber cloth on top of Padauk shavings!! :mad:
    :cheers2:
    n32, SlingBlader and mux164 like this.
  15. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Almost three weeks in Hawaii visiting kids, grandkids and "Ohana" (non-blood family) kids. Found a LOT of carpentry, plumbing, electrical and various handyman chores waiting for me ... it's what I do ... and my Ohana help to make sure I feel wanted and needed. ;) I posted a picture earlier of my "Workbench" out on the lanai ... but living in Japan, I'm used to working in tight and uncomfortable places. The view was great, though! :)
    Back to the build, my Ohana-daughter gave me a nice strap for it! Not sure it's a perfect match color-wise, but it IS a high-quality strap, and much appreciated.
    This is my "haul" from this trip. The Odie's Oil and Wood Butter are for this build for sure. The rest are things that are hard to come by in Japan, or very expensive.
    :cheers2:
    n32, jkes01 and mux164 like this.
  16. Blasphemoustrat
    Blasphemoustrat Junior Member
    12
    3
    Oct 24, 2017
    This is a beautiful build man. You have come a long way since building the little amps. Those dots on the fret board are amazing.
    As an aside, have you ever watched any of the crimson guitars builds. He does inlays a lot like that but in a very different manner from the way you did them...
  17. Skyjerk
    5,740
    6,605
    Feb 9, 2014
    Welcome home :)
    Now get to work!
    charisjapan likes this.
  18. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Thank you, kind sir! I was working on the side dots today, and will post pics later.
    Yes indeed, Crimson has some good stuff. I probably do things different because I can't do them right! I'm just hoping this thing will become a playable guitar. ;)
    :cheers2:
  19. charisjapan
    1,454
    1,403
    Jul 10, 2011
    Yes, SIR! :)
  20. Blasphemoustrat
    12
    3
    Oct 24, 2017
    It looks to me like you are well on your way. I def don't think your way on those was wrong. They look stunning. And in the right application i think those clear ones would be really cool.
