Likelihood of 7lb 9oz 335 being neck heavy?
Discussion in 'Other Gibsons' started by HermioneGrandeur, Nov 18, 2018.
  1. HermioneGrandeur
    HermioneGrandeur Senior Member
    116
    39
    May 21, 2014
    Just pulled the trigger on a 2018 Memphis Antique Red ES-335, 7.5 lbs... really hope it doesn't neck dive, but I guess I can switch the Grovers to Klusons it it does. (Lightweight guitars that have good balance are sort of my thing, 7.5 lbs was one the lighest ES-335's i saw. I sold a 2013 Dot ES-335 because the truss rod sort of maxed out and the high E string would slip off the fret real easy, the string spacing wasn't that great. Hopefully this more carefully selected 2018 model will get me back on the 3x5 train. Reason I fear neckdive is once I bought a midtown custom that was super heavy and also neck heavy as well.
    Although the Epi Sheratons/Epi 335's I've tried it at GC tend to have ahem "ass-dive" if that is a thing :O
  2. Burny FLG
    Burny FLG Senior Member
    281
    190
    Jun 24, 2017
    Played a doz before this one, most had some neck dive. Mine has some more noticeable when first purchased. Now meh.
  3. HermioneGrandeur
    116
    39
    May 21, 2014
    Interesting... most people say ES-335's don't really have neck dive, how heavy is your current one? I notice you have klusons on yours... im planning to swap the grovers on mine if there is neck dive with klusons, apparently 5 oz at the end of the headstock can make quite the differnece
  4. AlanBiker
    AlanBiker Senior Member
    101
    198
    Dec 8, 2017
    My 335 Dot has no neck dive and it has locking Grovers on it, I'm considering a Bigsby which would probably ensure it can't neck dive.
    Alan
  5. Burny FLG
    281
    190
    Jun 24, 2017
    Sorry can't tell the weight . All the ones I played weighed similar to this one. All much lighter than my old 83 LPC. Neck dive was apparent in a poly shirt jumpin up and down though.
  6. SFK
    SFK V.I.P. Member
    8,373
    12,715
    Mar 25, 2007
    Mine weighs 7 lbs. 10 oz. and isn't neck heavy at all.
  7. Biebers_Monkey
    Biebers_Monkey Junior Member
    26
    23
    Jun 21, 2013
    Relocate strap buttons. They get put where they are "Pretty", not functional.
  8. modavis99
    modavis99 Silver Supporter
    625
    660
    Oct 10, 2011
    I bet it's fine I have one a few ounces heavier that's perfect
  9. Have FUN
    Have FUN Senior Member
    1,684
    2,054
    Apr 27, 2011
    May be with heavy locking tuners ...
