Lighten My LP (?)
Discussion in 'Vintage Les Pauls' started by gitapik, Nov 13, 2017.
  1. howlermonkey
    howlermonkey Senior Member
    200
    176
    Nov 19, 2013
    Speaking of straps......has Buckethead gone away from his strechy strap to help his back?
  2. gitapik
    gitapik Member
    46
    20
    Nov 13, 2017
  3. RAG7890
    RAG7890 Premium Member
    13,958
    21,751
    Jul 11, 2010
    Sell it & go find yourself a nice CR8 & do any upgrades. You’ll probably come out square.
    A good CR8 will weight in at ~ 7.5lbs.
    Only thing to consider is are you liking the tones on your ‘69 which the weight etc. contributes to?
    Good luck.
    :cheers2:
    RevWillie likes this.
  4. gitapik
    gitapik Member
    46
    20
    Nov 13, 2017
    I was at the point of getting another guitar, but this strap put an end to that.
    I'm sure I'd love the CR8, but, yes: I love the tones on my '69 which the weight etc contribute to. Plus it's got sentimental value. Feels like coming home.
    RAG7890 likes this.
  5. Oatie
    Oatie Member
    44
    25
    Dec 5, 2017
    I seen a Les hog back on a Norlan that the owner used a hole saw and drilled out 4 or 5 holes and then he used the plastic toggle switch covers to cover the holes he drilled. It took some weight off he said. Drilled to the maple top in his hole saw plug cut outs. It looks clean, just has 5 or 6 round plastic covers on the back including the toggle switch cover. Looks good because the tech used the right router bit to recess the covers.
    He calls the guitar "Swiss Miss" .
  6. gitapik
    gitapik Member
    46
    20
    Nov 13, 2017
    "Swiss Miss" is right...
  7. Yehuda Kotton
    Yehuda Kotton Junior Member
    9
    32
    Sep 2, 2010
    this guitar had the back sliced off, chambered, then re-capped from the back. Sounds great.
    Bramley likes this.
  8. gitapik
    gitapik Member
    46
    20
    Nov 13, 2017
    Yeah...this is the video that made me think about gittin' it done after reading the description. Does sound great, doesn't it? I like his playing and videos. Very "instructive".
    Got my strap from Nick at Leatherhead for now. See where I'm at when I'm 90...
    Bramley likes this.
  9. NorlinBlackBeauty
    NorlinBlackBeauty Senior Member
    4,115
    8,849
    Oct 29, 2017
    ^^ Has always worked for me.
  10. kakerlak
    kakerlak Senior Member
    1,517
    557
    Feb 5, 2014
    This. If it's got Grovers/Schallers, go back to Klusons. An aluminum tailpiece will help, too. Not going to make a huge difference, but doing those two things to my wife's SG really did make a noticeable one. Every bit helps and the reversible ones are worth doing if it's killing you.
  11. Bramley
    Bramley Junior Member
    21
    15
    Mar 18, 2011
    I rescued this '69 body which had been " weight relieved " by some fool then discarded.. I capped the holes with 1/8" mahogany and veneered the back, but of course a solid colour is then necessary. The neck and all other parts were courtesy of the Gibson repair dept dumpster downtown Nashville. It's a very resonant and great sounding guitar.
    gitapik, DADGAD and Britbender like this.
  12. DADGAD
    DADGAD Senior Member
    8,993
    10,823
    Aug 11, 2010
    If you get a wider strap and still want to remove wood from it at least make it useful and put a B bender on it. Mine only took about half to 1 pound off the weight so I would never do it otherwise. Mine is a ‘71.
  13. gitapik
    gitapik Member
    46
    20
    Nov 13, 2017
    Nice. What's the weight, now?
