Let's Talk Glue
Discussion in 'Luthier's Corner' started by Paranoia, Nov 9, 2018.
  1. Paranoia
    Paranoia Member
    50
    26
    May 15, 2016
    Fair warning, I've not built anything with wood since shop class in high school, and even then, there wasn't much in the way of gluing, so some of this may be a little rudimentary to you. Looking to get my vintage LP build started and then on to my other, more unique ideas!
    Google tells me that LPs back in the day were glued together with urea formaldehyde between the maple cap/mahogany body, and hide glue at the neck.
    The trouble is... I live in Australia.
    Every Australian website I've come across that used to sell the urea formaldehyde doesn't any more, and over the pond won't ship it in. Shipping the hide glue in is a risk - our customs apparently does catch it coming in on occasion and rejects it based on it being an animal product.
    I've only found one brand of hide glue already within the country, appropriately named ubeaut, but there's no mention of gram strength or quality (though the FAQ mentions that 'it stinks', which reportedly isn't a good sign, apparently the 'good' stuff doesn't have this problem so much).
    Now, I'm not set on these glues purely for tradition's sake. If there's quality alternatives with similar properties, or if it doesn't matter, I'm all for giving it a go. I like the idea of these ones because they dry hard like glass and don't suffer from 'creep'. I like the idea of them, most importantly, because they won't be rubbery at all!
    So, my questions to you - what glues do you use? Are there any other glassy, creep-free glues out there? And most importantly - does it even matter at all? I could just grab a bottle of Titebond III or something... Assuming I can even get that in the country too, lol. Just gave the first overseas website a look see and it's a no-go there :slash:
  2. Ratae Corieltauvorum
    Ratae Corieltauvorum Member
    47
    9
    Sep 3, 2007
    Gibson use Tite-bond on all their guitars now, just use Titebond I for fretboards, it's a tad easier to remove, and unless you've worked with hide glue regularly, it's not the easiest to work with
  3. tigger
    tigger Senior Member
    442
    469
    May 6, 2017
    (<--pekelnik in HCEG Hi Ratae!)
    I was afraid of hide glue, but completely love hide glue and fish glue now. The reason is that if you want to be really precise, hide glue allows you to align the two boards after touching them together, but this is harder with titebond in my limited experience. Fish glue is great where you don't care about strength but want to have an invisible glue line and easy clean-up. And I think you should stay away from Titebond III and stick to I for guitar building, I've never used it but that's what people say, apparently III will creep.
    Note that I was lucky enough to find a disused crockpot at home that I'm using to warm up the glue.. It could be that without it it would be much more of a hassle as Ratae says though putting the container under running hot water would perhaps do the trick.
  4. Freddy G
    Freddy G V.I.P. Member
    12,096
    26,497
    Mar 18, 2007
    Just use titebond 1.
    LtDave32 and BPW666 like this.
  5. Blackstar1099
    Blackstar1099 Junior Member
    7
    4
    Feb 7, 2018
  6. Frogfur
    Frogfur Senior Member
    19,136
    33,674
    Jan 18, 2013
    In San Francisco they really like good old model glue in a brown paper bag.
    Discreetness is everything.
    efstop likes this.
  7. Skyjerk
    6,220
    7,453
    Feb 9, 2014
  8. strömsborg
    strömsborg Senior Member
    163
    76
    Nov 25, 2016
    So fish glue is weaker than hide glue? Is there any application on a guitar where fish glue isn't recommended?
    I used only fish glue on the one build I've finished so far and the neck hasn't popped off yet.
  9. LtDave32
    LtDave32 Desert Star Guitars Super Mod Premium Member MLP Vendor
    30,556
    93,410
    Mar 19, 2010
    Aliphatic resin glue (Titebond) bonds with the cellular structure of the wood. It may be a bit slick at first, but it creates a good bond. And it cleans up with water.
    If you're gluing up a fret board to a neck, it's best to use a couple of brads driven into the neck gluing surface as "locating pins" so it doesn't creep. One up near the nut, one down below at the heel. Chop them off with some cutters to leave a sharp nub exposed, press your fret board in place (with no glue, just to get a dent), give it a tap on each end with a plastic mallet, and you've got your indexing. When you glue it up, you'll feel the pins go in the holes.
  10. SlingBlader
    SlingBlader Senior Member
    339
    249
    Dec 7, 2013
    Gibson uses a variety of glues including hide glue depending on the model line. Also, a hide glue joint is far easier to separate than a Titebond joint... by a country mile.
  11. Freddy G
    12,096
    26,497
    Mar 18, 2007
    Dave, that's great advice. But I believe the OP was probably referring to "thermo-plastic" creep. The properties that some glues have to not move at all after they have cured...like hide glue or UF resin.
    SlingBlader likes this.
  12. LtDave32
    30,556
    93,410
    Mar 19, 2010
    Ah, ok..
  13. Skyjerk
    6,220
    7,453
    Feb 9, 2014
    Did you just call Dave a thermoplastic creep?
    Freddy G and LtDave32 like this.
  14. LtDave32
    30,556
    93,410
    Mar 19, 2010
    He wouldn't be lyin' tho..
    Mnbodydoc and Freddy G like this.
  15. Paranoia
    Paranoia Member
    50
    26
    May 15, 2016
    Never met a thermoplastic bloke before :p
    Thanks all for the words of wisdom and the links. I'm gonna get me a bottle of Titebond I, and I'm gonna look into that Jowat UF glue too... but that'll be a job for tomorrow now, I'm heading up to Sydney to catch a concert tonight.
    :band:
  16. pshupe
    pshupe Senior Member
    3,682
    2,605
    Jan 19, 2012
    Isn't that a Radiohead song?
    Cheers Peter.
  17. RAG7890
    RAG7890 Premium Member
    15,043
    24,197
    Jul 11, 2010
