Less Plus wiring change
Discussion in 'Gibson Les Pauls' started by Zzini, May 7, 2017.
Tags:
  1. Zzini
    Zzini Junior Member
    3
    0
    May 7, 2017
    new to the site, so not if this is posted in the right area, finally nearing 60 years old got my first les paul, less plus 2015. Loving it. This model has coil tap/split switch, this might seem odd but i want the coil tap to only work on the neck pickup, dont care for the bridge at all on single coil plus if the coil tap only affects the neck i can go from humbucker treble to single coil neck using the pickup selector switch and also mix the humbucker sound with the single coil with the pick up selector in the middle. I loved this combination on my epiphone plus top pro. Is this possible very simply? It seems just removing the wires from the bridge to the switch at the switch and taping them would do this. Thanks.
  2. ARandall
    ARandall Senior Member
    11,791
    7,183
    Apr 16, 2012
    If the switch does both pickups, then simply removing the bridge wires will do what you want. Taping as long as the connection is soldered is needed as you guess.
  3. Zzini
    Zzini Junior Member
    3
    0
    May 7, 2017
    Thanks for the quick reply, yep the switch does both pickups
  4. LPSPP
    LPSPP Senior Member
    885
    685
    Nov 14, 2011
    switch it back when you go to the bridge pickup
  5. Zzini
    Zzini Junior Member
    3
    0
    May 7, 2017
    Not sure i follow the "switch it back" thing, maybe just not thinking well today, lol
