Les Trem 2 with Bigsby arm
Discussion in 'The Custom Shop' started by Number6, Jan 11, 2014.
  1. Number6
    Number6 Senior Member
    186
    150
    Feb 4, 2010
    Just FYI.
    Had a Duesenberg Les Trem II last year and I liked it, but there was an amount of play in the arm that I couldn't fix (stop the play and it was too tight to move up and down). Also didn't like the look of the arm and the way it attached to the trem. Awkward visually. Took it off and gave it away.
    Decided to try again because I really wanted a trem and the other LP options didn't grab me. I know people here like a Les Paul with a Bigsby but I just do not like the look of all that metal. Also difficult to string them. Tried a Stetsbar and sent it back (it was awful...loose arm whatever I did and there was no way to get a decently low action because the whole unit was too thick top to bottom). Didn't seem very well made, to be honest.
    Anyway, got another Les Trem and ordered a Bigsby arm and mounting screw at the same time (trem from Germany and the arm from Arkansas...both arrived the same day). Hoped I would be able to combine the 2.
    The latest Les Trem is better engineered than the one I got last year. The arm is attached better. But as I had the Bigsby arm I took it apart and reassembled it with it. Fits nicely and looks better, IMO.
    Result, IMO, is Les Paul trem perfection. Does what a Bigsby does but far less bulky and garish. Also has a very low string angle over the bridge (same as doing a Bonamassa stringing around the stoptail) so less friction than a Bigsby and stringing is super easy too. String ball ends just slip in from the top.
    Here are pics. The pickups are Duncan Phat Cats....this is a rockabilly guitar now.
  2. harrie 0492
    harrie 0492 Senior Member
    901
    464
    Jan 21, 2009
    It looks much better with a Bigsby b7, but he thats me a Bigsbyfreak.
  3. pfox14
    pfox14 Senior Member
    484
    168
    Apr 22, 2012
    Very slick looking in gold. Nice job
  4. rabidhamster
    rabidhamster Senior Member
    5,505
    4,974
    Jun 4, 2008
    Cool I like the bjgsby arm on it. It's a little disconcerting, but not in a bad way - it looks like there's just a bigsby arm inexplicably attached to the stop tail. A tremolo springing from nowhere.
    As much as I like the look of a bigsby this is really cool! When you drop pitch does it raise the strings up or roll them forward like a bigsby?
  5. Number6
    186
    150
    Feb 4, 2010
    It rolls like a Bigsby. The base plate is fixed firmly in the stoptail holes and the bit that the string ends fit into rocks on a pivot bar.
    It's one of these with an Allparts Bigsby arm.
    Google Image 'Duesenberg Les Trem' for more pics if you're curious.
  6. cain61
    cain61 Senior Member
    829
    220
    Sep 16, 2009
    I'd love to hear a sound clip of that thing.
  7. Ole'Lefty
    Ole'Lefty Premium Member
    5,206
    1,718
    Oct 25, 2008
    Is there anyone in the USA that actually sells them? I want to try one on my Epi "Custom Shop" Dot in gold like yours.
  8. Number6
    186
    150
    Feb 4, 2010
    Gigged it the other night...worked a treat. For getting them in the USA I believe the shop I linked to in post 5 will ship there. Otherwise try contacting Duesenberg and see if they have any agents or outlets there.
  9. Ole'Lefty
    5,206
    1,718
    Oct 25, 2008
    Thank you- I was able to order from that vendor. Don't really know how much I paid-they did not have an on-site currency conversion. It still seemed affordable -about 98 Euros including 30 EU shipping to USA. I might try the bigsby handle mod too, but I want to wait until I install the present configuration. This trem has its own clean look-more "tech" than Bigsby but not cluttered either. Going on my Epi Dot, a 2009 with original gold and curly top-"passed through the Epi Custom Shop."
  10. Ole'Lefty
    5,206
    1,718
    Oct 25, 2008
    If you could further help, do you have part numbers for the Bigsby arm conversion? The arm is pretty obvious but not the screw or other connecting hardware. Thanks.
    I found the arm and found Bigsby screw/washer/nut in gold as well. Is that what I need?
  11. Number6
    186
    150
    Feb 4, 2010
    I got this and this.
    Did a bit of experimenting with washers and stuff (including the brown one that came with the trem) but I seem to have it right now. Personal taste and YMMV and all that. I gigged it and just used it without ever thinking 'I need to adjust that later' so I'm happy.
    A good set up for the money, and it reverses back to a normal LP in about 10 minutes if you wish.
  12. Ole'Lefty
    5,206
    1,718
    Oct 25, 2008
    Thank you--Les Trem is on its way from Germany and Bigsby handle and hardware coming from Arkansas.
  13. Number6
    186
    150
    Feb 4, 2010
    Hope it works out for you. I'll be interested to hear what you think.
  14. Ole'Lefty
    5,206
    1,718
    Oct 25, 2008
    Les Trem has arrived and I also have the Bigsby parts. Thomann in Germany were fast. The trem unit is very well executed. Plating (gold) is perfect and the hardware package makes good sense. I believe that I will be satisfied with this when installed.
    My thanks to Number 6 for the idea and the help.
  15. Bigsby'd
    Bigsby'd Senior Member
    1,262
    2,307
    Nov 5, 2009
    Nice. I haven't seen this one. Looks well thought out.
  16. Ole'Lefty
    5,206
    1,718
    Oct 25, 2008
    My daily player has a Bigsby licensed 70 so this is just fooling around. But, up close and solid in the hand,;well, yes, it is a pretty impressive piece of work. I am not certain that I will substitute the Bigsby arm- the as designed handle is comfortable and looks better in person than in a photo- the swap only requires an ignition style open end wrench and an allen, then the same wrench and a medium large Phillips.
  17. 1981 LPC
    1981 LPC Senior Member
    2,078
    1,353
    Dec 8, 2010
    Thought I'd share this video of a Deluxe fitted with a Duesenberg Les Trem II. This unit fits on any stop tailpiece guitar. While it admittedly doesn't look as cool as Bigsby B7, from what I've read it's a better design. Better tuning stability and easier to restring. If you've ever tried a Duesenberg you know what quality to expect.
    [ame="http://www.youtube.com/watch?v=cUy9ThTD_RU"]http://www.youtube.com/watch?v=cUy9ThTD_RU[/ame]
  18. Frogfur
    Frogfur Senior Member
    13,159
    19,450
    Jan 18, 2013
    Nice thinking outside the box. I like it.
  19. 1981 LPC
    2,078
    1,353
    Dec 8, 2010
    Nickel plated - by the way. Good!
    For EU customers, it's 80 euro at Thomann (who also ship internationally).
    Good price, I think - compared to a new Bigsby unit + Vibramate.
    You can also find it on eBay. But I can't find it listed in the Duesenberg US catalog posted here: https://www.duesenbergusa.com/specs/index.html. You'd better ask what's what.
    Looks pretty sweet (but note that the TP studs were reused in these photos. Looks silly):
  20. charliebrown
    charliebrown Member
    35
    4
    Jul 1, 2014
    Do you have the part names for the Bigsby parts? I am looking to do the same like what you did but the eBay listings no longer exist. :(
