Les Paul Traditional ground issues and mystery screw
Discussion in 'Gibson Les Pauls' started by Mr. Satchmo, Dec 7, 2015.
  1. Mr. Satchmo
    Mr. Satchmo Senior Member
    3,267
    3,403
    Dec 20, 2010
    Hi everyone I just had a couple questions. I've had my les paul for 5 year, and for a few years I noticed that it was very noisy. Recently it has become unbearable. The buzzing only goes away only when I touch the pickups, the toggle switch nut, and also the 1/4 inch jack nut but continues when I touch the strings or the bridge/tail peice. Also when I am playing, the guitar will often pop when I move. I am wondering if this could be caused by the ground wire improperly soldered to the bushing of the tail piece?
    Also when I opened the control cavity I saw a small black screw screwed into the hole that the ground wire goes into, is this normal? Is almost seems like someone at Gibson screwed it in in an attempt to push the wire to touch the bushing
    I will be taking the guitar into my local guitar tech to have all the stock electronics and 57 classics replaced with a good quality 50s wiring harness (CTS Pots, vintage Bumblebees, braided wiring) and some new wolfetone Dr. Vintage (I was already going to do this anyways)I will have my tech check the ground wire as well. Anything else I should have checked? I have heard some horror stories Gibson's QC and how some of the ground wires weren't even soldered. Also My other Les Paul is completely silent with the same setup (Cables, amps, pedals etc) and it doesn't pop when I play at the same venues.
  2. guitarjoem
    guitarjoem Senior Member
    497
    259
    Dec 15, 2014
    Sounds like there is a grounding issue at the pickup selector switch or output jack.
    1 person likes this.
  3. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    I was thinking the output Jack right now since it goes always when I touch it , maybe I can get a new one as well
    I removed that screw on the ground wire and lightly tugged at it, it seems to be soldered well so it's probably not the issue.
  4. A string bounce
    A string bounce Senior Member
    709
    309
    Sep 29, 2008
    The additional screw is a mystery!! still doesn't surprise me at all? Before I changed out my original Trad wiring for 50s wiring, it looked liked the soldering had been done by a blind chimp!
  5. Classicplayer
    Classicplayer Senior Member
    2,480
    1,537
    Sep 6, 2007
    The pic above show how my tech fixed a similar problem to your issue. It is a cloth-covered ground wire soldered to all the pot backs and running to a small screw in the cavity. The screw runs into a strip of copper sticky tape and makes contact with shielding foil on the cavity plate back. It is reversible, if need be. I later added Orange Drop caps and it quieted the guitar even more. I hope this is of some help. Ask you tech if this would work in your guitar. He may choose another method as there is more than one way to fix this problem.
    Classicplayer
  6. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    Ive been looping at it and the hole they made is huge and tacky, they probably thought to fill it in with the screw or something
  7. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    The method you show is how I bought my wiring harness too thank you for the suggestion!
  8. Stuart_tate41
    Stuart_tate41 Senior Member
    695
    778
    Jan 3, 2013
    Check the earth with a multimeter. One end of the back of your pots then one end on the tail piece. The easiest way to check if the earth is touching the bushing.
    I had a recent interference issue that wasn't caused by a bad ground. So I shielded all of the cavitys and routes with conductive paint, best decision ever.
    3 people like this.
  9. A string bounce
    709
    309
    Sep 29, 2008
    Initiative is sometimes not always a good thing? :laugh2:
  10. Justin_Case
    Justin_Case Senior Member
    6,025
    3,474
    Apr 29, 2009
    Before you spend any money or make changes to the guitar, I'd suggest trying someone else's amp at another place to rule out your amp / home electrical system.
  11. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    I've had he same issue with multiple amps for years. This amp is new I bought it. My other guitar doesn't have the same issues with the same amps and pedals
  12. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    Also I know it's not just my house, I play at different venues and the popping at least doesn't go away, but the buzz may get softer depending on the quality of the electrical system.
  13. Classicplayer
    2,480
    1,537
    Sep 6, 2007
    When your tech finishes with your guitar, please let us know what his opinion was with respect to the "buzz" and how he fixed it. I have a 2010 Studio Deluxe that despite having shielding work done, still emits more hum than I think should be normal.
    Classicplayer
    2 people like this.
  14. Stuart_tate41
    695
    778
    Jan 3, 2013
    How well is it shielded? Now I've finished mine it really is quite even atgig volume. It's really important to check conductivity across all th ecavitys and writing routes.
  15. ajay
    ajay Senior Member
    845
    547
    Jun 3, 2015
    That screw connected to the cable is doing nothing. I would remove that screw and see what happens. Seeing how all of Your pots are on the plate, there is no reason to ground anything, and I don't see how a screw "grounding" it to Mahogany is going to do a darn thing. I would take that little cable out of the picture and see if that helps. It can't hurt.
    That wire connected to the black screw just looks like a piece of solder, not wire. I can't say that I've ever seen that trick before. I would try losing that little piece of "engineering".
    It also looks like the piece of white wire goes through the hole on the pot connection, and may be touching the plate. I don't think a connection on the pot that touches the grounded plate would do any good either.
  16. Classicplayer
    2,480
    1,537
    Sep 6, 2007
    Would that length of"wire" with the black screw on it lead to the Jack? If so the screw might be a rude attempt to keep the "wire" from moving thus weakening the solder connection on the back of the pot. Just a thought........
    Classicplayer
  17. Classicplayer
    2,480
    1,537
    Sep 6, 2007
    Until I get myself a multimeter, I cannot answer the question. The switch cavity was not shielded with any material, so there could be a problem there. Then too, the volume pots are the type for coil tapping; activated by pulling the knob up.
    I live with it by going no lower than +-8 on the volume controls!?
    Classicplayer
  18. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    I will be replacing my harness to a 50s wiring harness, so I would need to ground to the tail piece bushing then. When I removed th screw it looked like it runs to the back to the bushing. My question now, since I have to ground this way:
    will the solder wire acting as a ground work or would I have to replace with wire
  19. ajay
    ajay Senior Member
    845
    547
    Jun 3, 2015
    I just don't see what it's grounding. The pot that the solder and black screw are connected to is already grounded at the point where the pot is bolted to the plate, so I don't see any reason for the solder and screw to even be there. Nothing is ever going to ground anything if it just gets screwed to Mahogany. I would TRY taking the screw out, and hang the solder in mid-air so it doesn't contact anything. Then, pry the very tip of the White wire up and away from the base plate, and see how it sounds. You have nothing to lose, and nothing is going to blow up just by performing those two actions. It's worth a try!
  20. Mr. Satchmo
    3,267
    3,403
    Dec 20, 2010
    One of my friends made a good observation, perhaps the screw was used to hold the ground wire in place before it was soldered to the tail piece bushing
