Les Paul Strings hitting pickup and Open low E string buzzing
Discussion in 'Pickups' started by tsquared17, Jul 19, 2017.
  1. tsquared17
    tsquared17 Junior Member
    1
    0
    Jul 19, 2017
    In the 17-23rd fret range, the strings when played, are hitting the neck pickup/humbucker.
    Specifically, low E string hits the pickup starting at fret 18, A string at 20, D at 21, G at 20, B at 18, High e at 17. At these points, the string when pushed down are not hitting the fretboard for the most part, because they are hitting the humbucker.
    Is there anyway I can fix this? Also, open low e string buzzes, im thinking i might just need a higher nut, but I don't know, maybe it's related.
  2. C_Becker
    C_Becker Dat Gibson smell Premium Member
    1,786
    1,576
    Jul 7, 2015
    -Use the two screws on the neck pickup mounting frame to lower it ;)
    -a good starting point for pickup height IME is: 1,5mm treble side, 2,5mm bass side with the string pressed at the last fret. Distance measured from pickup to bottom of the string
    -press down the low e at the third fret, the string should now have a minimal distance to the first fret. Thickness of a sheet of printer paper. If it touches the fret, the nut is cut too low. Fill up with super glue for a temporary fix.
  3. chasenblues
    chasenblues Senior Member
    19,148
    25,684
    Apr 2, 2007
