Les Paul-esque Build - First one, please go easy on me ..
Discussion in 'Luthier's Corner' started by bcguitars74, Feb 6, 2018.
  1. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Well, I'm just clocking on with a quick update, I haven't been stagnating - I decided to go with a different neck them I intended so I've been making myself a jig ..
    Also while I was waiting for glue to set, I tried my hand at book matching a piece of the cut off from the cap with a veneer in mind, anyone have an opinion on whether it would look ok? I'm not sure ..
    the ambrosia maple straight off the bandsaw, looks wicked!
    After I cleaned up the bandsaw marks :( The other spalt has totally come to the surface, there was only about .5mm in it ..
    I also sawed up a piece of walnut but it might be a boring veneer ..
  2. emoney
    emoney Senior Member
    7,024
    3,191
    Jan 31, 2010
    That's a personal choice, really. My go-to is always something less grainy on the headstock. But I've
    also used Maple, Zebrawood, Wenge, etc. And in those instances, it looked pretty good. Nothing beats
    holly, however.
  3. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    This is another piece, I might try and bring the spalt marks closer together and see what it looks like.
  4. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Finally, neck blank finished, truss rod slot routed, wings glued on .. can't wait to get started on the tenon :dude:
    Thumpalumpacus and nuance97 like this.
  5. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Well I got the wings glued on, sanded back and so on and had to decide on the veneer .. I eventually went with a piece that I cut from the leftover wood from the cap. Maybe too 'busy' for some but I like it :)
    I placed the nut and fretboard on to get the position of the 16th fret as advised by @ARandall and have started the tenon cut, still not sure if the best way to cut this .. I don't want to bandsaw the bits off as it will take ages to sand the marks off so will have to route it somehow.
  6. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    I made it on to the tenon, yeehah!!
    I built myself a little routing jig for the neck, nothing fancy, and took off 1/4 mm each side at a time until the tenon was nearly there then sanded the rest until it was snug but not tight.
    I then did the same to the bottom of the tenon until the top was flush with the body
    I then filed the shoulders of the tenon until I was pretty close and then used sandpaper to get closer - I just inserted the sandpaper in the joint, held the joint closed and pulled the paper through on whichever side was stopping the shoulders meeting the body; quite exciting and I thought it wasn't bad for a first go :cheers2:
    I clamped the bits together to get a preview ..
    i was on a roll so I glued the fretboard while I was at it. Although the neck join is pretty much spot on at the 16th fret, I have a feeling that the fretboard is going to extend 1 to 2mm too far and therefore into the space where the pickup ring needs to go :facepalm:
    I suppose if this is an issue then I will have to gently 'thin' the binding at the end of the board, it's 1.5mm thick so a wee bit of wiggle room but not much ..
  7. nuance97
    nuance97 Premium Member
    2,177
    1,235
    Feb 26, 2009
    Looks good man! :thumb:
    bcguitars74 likes this.
  8. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    So, a few gigs later I have time again for updates :)
    :photos:
    Apologies in advance - this post is going to be pic-heavy ...
    :photos:
    I've got quite a bit further - there have been a few potentially catastrophic mistakes but the guitar is for me so it'll be fine - I'm already planning the next one though with a list of "how not to do it this time" notes. The worst ones are all power tool slip-ups :/
    - one when routing the binding channel for the headstock - my "router table" slipped somehow and the channel was cut down to over half the width of the headstock in one place so I had to carry it on all the way round.
    - and two - the orbital sander slipped and sanded too close to the lower side of the rear pickup meaning that there is a gap between the pickup ring and the body at one side. This is the one that's making me most unhappy as I can't fill or make a "feature" here. If anyone has any ideas about this I would LOVE to hear them! I can only think to try and file the pickup ring to "mould" it around the body.
    Edit: just realised I don't have a photo of this yet, I'll upload it in the next couple of days.
    My "DIY router table" - the laminate trimmer attached to a bit of MDF- worked great for trimming the neck flush but slipped somehow on the headstock binding and made it 5 times the size :420:
    I used this to trim the sides of the neck flush with the fretboard and it worked fine taking me from this:
    to this - nice and flush along the sides. I also carved the profile - rough with a rasp first then with a length of cloth-backed sandpaper to round it off. I love working with mahogany, it's so quick and easy to sand :)
    After everything was smoothed off, the headstock was slightly too thin at around 13.5mm so I decided to veneer the back of it as well for extra strength - I rough the outline, bent the bottom on the iron to mould to the "volute" and then glued it on:
    Glued on ..
    And then trimmed and shaped!
    Then it was time for the headstock binding channel, as you can see there was a bit of an issue with the router bit height :(
    I decided to bind it with some bits of walnut to match up (sort-of) with the fingerboard so I ben some more on the iron and glued it on:
    Not quite what I was aiming for but hey ..
    Next up was the truss rod access slot, using a drill was a bad idea :doh: but I managed to clean it up - it'll be lost under the truss rod cover anyway.
    A quick repair to the worst of the original router slips - I think it'll be OK with a dark burst:
    Then the body binding .. this was a battle. I put it on with CA glue which I think I will avoid in the future. I spent more time separating my fingers from bits of binding and sanding away the CA lines where it ran than I did doing the actual sticking. One part hardened too quickly and left a 1mm gap in the cutaway so I melted a bunch of bits of binding in acetone, left it a couple of days and then filled the gap with the resulting gloop.
    Scraped and sanded the binding and then glued the neck on!
    Next up is grain filling I think.
    mux164, Thumpalumpacus and dcomiskey like this.
  9. emoney
    7,024
    3,191
    Jan 31, 2010
    I usually leave the grain filling until the guitar is ready for finishing. Just sharing in case you were undecided.
    After the neck is set, it's a great time to go ahead and set the bridge/tailpiece, make a nut, and string
    that puppy up to make sure it's ready for finishing. Looking good so far!
    Thumpalumpacus and bcguitars74 like this.
  10. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Ah good call! I was indeed undecided, I'll start on that now.
  11. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    So here are the pickup rings gaps .. :/ I think I will sand the pickup plane until there are no gaps under the rings and then try and blend it in to the rest of the body with some sanding .. might look a bit strange though? Does anyone have any ideas?
    Checked the bridge height - 15.5 mm so just right ..
    But in preparing to mark out for the bridge I noticed some centre line drift :( The pic below shows the glue line and the actual centre line as taken from the fretboard - there's about 3/32" difference at the bridge line so now I'm worried the pickups aren't going to sit correctly under the strings ..
    Thumpalumpacus likes this.
  12. nuance97
    2,177
    1,235
    Feb 26, 2009
    The pickup plane doesn’t have to be perfectly flat as some here would suggest...in fact I don’t think any vintage 50s LP likely had a dead-flat pickup plane. There were variances obviously back in the day since they were hand sanded, but the absolutely flat plane is IMO a myth. The ones that look super flat in photos are more an optical illusion than they are flat.
    I wouldn’t sweat the issue if it were me. I’d just bend the rings to fit as long as you don’t think they’ll snap
    As far as your centerline issue is concerned, hopefully there’s enough wiggle room in the cavities to line the pickups up with the strings. Just wait till you string it up to drill the pilot holes for your pickup rings so you can push the pickup to one side of the cavity
    moreles and bcguitars74 like this.
  13. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Thanks nuance! I think it's also possible to get the curved-bottom pickup rings .. I wonder if they'd be any better.
  14. ARandall
    ARandall Senior Member
    12,000
    7,462
    Apr 16, 2012
    No vintage burst ever used curved rings. They simply screwed flat rings down so they simply bent and conformed that way. Any pics of bursts you can see the slight gaps where the rings don't quite match the guitar top.
  15. emoney
    7,024
    3,191
    Jan 31, 2010
    I would go so far as to even advise taping some sandpaper down on the top and sanding the
    p'up rings to match the carve. It would look better in the end.
    As to the "dead on centerline" issue, I wouldn't lose sleep over it, as you'll be the only person
    that ever sees it once finishing is complete. Just make sure it's accurate and there are no
    playing issues and carry on because quite frankly, from the pics you shared, it looks
    as if the center line of the fretboard you've extended is dead center of the pickup.
    moreles, jkes01 and bcguitars74 like this.
  16. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Ah that's a great idea thanks! I'll finish the top sanding and then do the pickup rings just like that.
  17. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    Made myself a little template to drill the control holes as well .. sits in the control cavity very nicely :)
  18. pshupe
    pshupe Senior Member
    3,388
    2,205
    Jan 19, 2012
    I do this as well, but I just use plain paper and an X at each hole location and mark with an awl. Great looking guitar.
    Cheers Peter.
  19. bcguitars74
    bcguitars74 Member
    67
    65
    Jul 12, 2014
    I stained the body and neck with a brown/red mix first.
    Located the bridge .. I use this old tailpiece to hold the strings so I can locate the bridge properly and make sure my measurements are right:
    I then started the burst, first one ever attempted, and used the hand rubbed burst guide.. much fun! It started off quite light with reds and ambers:
    While I was scraping the binding clean however I managed to bury a blade in my thumb and by the time I'd taped it up the top of the guitar was pretty covered in blood .. I had to darken everything to mask it .. It took me a little while but I've got used to it and I quite like it now :)
    After a LOT of reading, I decided to go with a wipe-on poly. That minwax stuff is mega expensive here so I just bought a tin of oil-based poly and thinned it 50/50 with white spirit.
    I've wiped on 2 coats so far and I'm loving it :)
    The only thing I haven't done yet is drill the volume and tone pot holes, I'm still trying to work out how best to do it. Obviously before the finish would have been better but I just plain forgot .. :doh:
  20. fatdaddypreacher
    5,805
    3,819
    Feb 5, 2011
    you are doing great. each one i build i learn to improve my technique a little more, as that is part of it. don't be too hard on yourself for the misjudgements or slip ups, as they happen. you are exhibiting one of the crucial abilities in any woodworking venture---how to recover from those uh-oh moments. nice work.
