Les Paul Classic vs Traditional
Discussion in 'Gibson Les Pauls' started by wilsonho94, Nov 26, 2011.
  1. wilsonho94
    wilsonho94 Senior Member
    135
    2
    Sep 24, 2011
    Hey guys would like to know the difference between these two guitars I know the fact that both aren't chambered and I only manage to try a classic cause I can't seem to find a traditional... but from what I heard the classic is much warmer and deeper that Standard BBpro.. but what's it's difference with Traditional ? Cosmetics? Much appreciate the help thanks ^^ :slash:
  2. Bigfoot410
    Bigfoot410 Premium Member
    11,104
    18,899
    Oct 19, 2011
    Traditionals have classic 57's. Traditional pro has BBpro's and coil tapping. Other than that and the snot wiped off the inlays, the Traditionals are the new classics.
  3. wilsonho94
    135
    2
    Sep 24, 2011
    so technically the same guitar ? but why the bigger price?
  4. budg
    budg Senior Member
    2,676
    1,823
    Mar 15, 2011
    If you are looking at the newer Classics and Clastic Custom, a big part of the price is the fretboard material and maybe slightly better tonewoods.The newer classic has "baked maple" and the traditional has rosewood.
  5. wilsonho94
    135
    2
    Sep 24, 2011
    I'm looking at an older model I guess not the new ones... those with the snot green inlays... Are they chambered?
  6. SlyStrat
    SlyStrat Senior Member
    1,795
    894
    Jan 24, 2009
    2007 is the start of chambered Classics.
  7. Bigfoot410
    11,104
    18,899
    Oct 19, 2011
  8. 87Standard
    87Standard Senior Member
    417
    100
    Mar 10, 2011
    The Traditional is the 'old' Standard. I'm not sure how the Classic differed from the Standards of the time...
  9. rideski
    rideski Senior Member
    2,103
    327
    Aug 2, 2008
    The Traditional's are the old 80's era Standard actually. The Trad's have big necks ('50's neck) while the Classic is the slimmer '60's neck. The Classic also come with the hotter pups (ceramic).
  10. 6stringer
    6stringer Senior Member
    2,028
    3,556
    Dec 24, 2009
    My Trad. Pro has a classic '57 in the neck position, and a BB III at the bridge.
  11. wilsonho94
    135
    2
    Sep 24, 2011
    Any way I can change the snot green inlays?
  12. cap217
    cap217 Senior Member
    413
    70
    Jan 7, 2011
    Traditionals are solid standards, like the 80s and 90s. They have fat necks, speed knobs, 57 classic and classic +, nashville bridge.
    Classics are 60's RI in a cheap way. Ceramic pickups, ABR bridge, greenish inlays, thin 60s neck.
  13. Bigfoot410
    11,104
    18,899
    Oct 19, 2011
    Yes, somebody just had it done with pics here for $120....can't find the post.
    Ok so I have this whole Traditional, classic and standard thing mixed up......so the old standard is the standard and the Traditional is the new old standard which makes it the new standard unless it's chambered, then it's a new standard and not the old which is a classic...not the classic classic but a classic nonetheless......and that leaves the classic classic which is made out of old stratocasters and snot! :headbanger:
    YoshiJimbo likes this.
  14. 6stringer
    2,028
    3,556
    Dec 24, 2009
  15. colchar
    colchar Banned
    33,835
    74,656
    Oct 26, 2009
    They are not solid, they are weight relieved (but not chambered).
  16. wilsonho94
    135
    2
    Sep 24, 2011
    So technically the Classics are actually the old Traditionals ? And what's the story behind the green snot inlays? Do you guys also agree that the classic has the classic tone of the LP back in the 60's? (I'm talking about the old Classics not those with the maple fret board)
  17. Latearrival
    Latearrival Senior Member
    1,314
    761
    May 28, 2011
    Correct! They are weight-relieved like the Standards were in the 80's and 90's
  18. Leiste
    Leiste Senior Member
    1,205
    1,566
    Aug 27, 2010
    Personally, I'm not too fond of the pups - they're too dull & lacking character!
    Furthermore, the neck is too thin (but some like that. . .). The effort having those inlays changed is too big.
  19. guitarcase
    guitarcase Senior Member
    571
    73
    Oct 7, 2008
    The 'old' classics had slim 60's neck. Before 93 they had nice inlays. After 93 they put to my mind awfull green inlays in. This was ? to make them look different to the new reissues they were bringing out? Most older standards /classics were drilled to make them lighter, and weights varied hugely. Gibson still do this(except historics), and ALSO have chambered models. Choose between thick or thin neck, and thats probably your answer. Gibson have 3 common(varying) necks. 50s,thickest, 59 and 60,slimmest. You can always change pups, but try changing a neck....The old standards had a 59 neck, the new traditional has a more 50 neck, so not quite the same as the old standard. 57 pups are warm and articulate. BB pros more modern. 500t in original classics powerfull and harsh.
    The old classics were very good guitars, better to me than the standards of that time, but Only if you like slim necks. If you like a middle neck go for an old standard, but check the weight, some are 12lbs, some are 9lb. This doesn't affect tone as such, two the same weight can sound different, but can be restrictive after a few hours playing.
  20. 87Standard
    417
    100
    Mar 10, 2011
    I think there's a lot of misunderstanding about this on the forum.
    Just because a guitar has 9 nine small holes drilled in it doesn't mean it's not 'solid', any more than saying it's not 'solid' because it's been routed for PUs and wiring...
    The body of a traditional weight-relieved 80's or 90's LP IS a solid piece of mahogany, bringing all the benefits (and drawbacks) of making a guitar from a solid piece of wood.
    I find it hilarious that some people see weight-relieving as significant in any way.
    For all practical purposes (body mass, sound conduction, feedback resistance, etc.) the Traditional is a solid body electric guitar.
