Les Paul Build 3 & 4
Discussion in 'Luthier's Corner' started by WezV, Dec 31, 2017.
  1. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    Time for a couple more. both will be alternative les pauls - not normal gibson spec but they will look like something Gibson might have done
    The first will be a 59 inspired, but with P-90 routes ... about as close as i get to proper gibson stuff
    maybe like this
    Number 2 will be more of a challenge - I have done thinlines before, but never with a carved top. I really liked the trapeze on my recent goldtop, so that makes a reappearance here
    Pickups will be non standard - likely staples, dynasonic coils or gold foils - or some mix of those
    the top on the 59 will be a nice bit of lightly flamed sycamore.
    Bodies will both be Khaya. 2 piece is for the custom, 1 piece for the 59
    [​IMG] [​IMG]
    archey, RAG7890, lowatter and 9 others like this.
  2. TheZ
    TheZ Senior Member
    996
    609
    Nov 9, 2009
    Looks like you're off to a great start. Best of luck! Can't wait to see more.
  3. Pesh
    Pesh Senior Member
    332
    165
    May 4, 2015
    Sub'd. Lovely pieces of wood - these look to have the promise of some great builds! I watch with anticipation!
  4. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    I must get back on them soon. My Firebird is nearly done, these are next in line
  5. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    Just spent the last hour or two prepping wood for these two
    all the tops, fretboards and necks are now ready to go, and got a spare top to boot
    The necks and mahogany tops are old stock honduran, a gift from a woodworkers widow. I got loads of big wide planks, some too heavy for bodies and too erratic for necks, but it makes nice tops where the extra weight pushes it a bit towards maple tonally.
    I also got some big long square chunks which are perfect neck wood.And i will be going one piece with dual CF rods this time to make the most of this wood, usually I laminate. the rods will not be solid CF bars, but hollow rods as i think this makes the neck controllable and predictable without making it too stiff
    here is the neck blank
    [​IMG][​IMG]
    roughly cut for 2 long full width tenon les paul necks
    Indian rosewood and ebony to go with them
    Here are the tops - ths started as one long plank. I think B is too nice to paint
    and the sycamore
    bhmcintosh, archey, RAG7890 and 4 others like this.
  6. Fez Bear
    Fez Bear Senior Member
    107
    16
    Nov 27, 2010
    awesome!! looking forward to seeing how this ends up!
  7. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    had a bit of a moment with these. I marked up the weight relieved burst for chambers, and weight relieved the custom which was going to be chambered
    Also,i think my last scale reading was off. because i weighed them again with the same scale today and got the same reading off both bodies again, even after weight relieving one of them. I tried a new set of scales and working backwards i think it was the 2-piece that was 6.4lbs. The one piece closer to 6lb
    The one piece is now 5.7lb, 2 piece is 5.3lb after weight relief, although there is still a bit to do
    I have changed my mind again on going chambered thinline for the custom, i think they will both be weight relieved instead
    dickjonesify, Frack and Pesh like this.
  8. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    i got the one piece for the burst weight relieved. took a lot of holes but its bang on 5lb now so should give 8.5-9lb when finished. you can ignore the pen line, this one was never going to be chambered.
    The sycamore top is also cut and drilled with some template holes to help alignment
    quite a bit of colour variation, some small knots at the waist, and a fairly inconsistent flame - but i like this kinda top
  9. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    i started the carve, contour map method. I still need to add the neck and pickup angles but started the sanding stage anyway
    fairly happy s far[​IMG]
    but the slight flaw at the edge has moved inwards and grown. there was no sign of this on the other side of the wood
    but if your going to have a flaw on a les paul top, it may as well be under the plate :)
    RAG7890 and dickjonesify like this.
  10. dickjonesify
    dickjonesify Senior Member
    4,746
    4,621
    Apr 16, 2010
    That stinks about the flaw but they are looking great. What awesome wood :applause:
  11. Freddy G
    Freddy G V.I.P. Member
    11,323
    23,603
    Mar 18, 2007
    I feel for you about the flaw bro...I really do!
    Otherwise, looks great!
    Eliran likes this.
  12. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    i don't mind too much. It was a cheap top but has a lot of character, its just part of that. rippled sycamore like this is about a quarter of the cost of similar maple over here
    i don't like perfect tops on a vintage style les paul
    smk506 likes this.
  13. elephantrider
    elephantrider Senior Member
    2,699
    2,361
    Oct 23, 2015
    both of those tops are too nice to paint ! looking good for sure.
  14. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    fully carved
    I am actually thinking of changing my plan on this one. Maybe make it totally unbound with a dot neck.
    RAG7890, failsafe306 and Satellitedog like this.
  15. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    got the fretboards prepped for these 2
    The indian is nicely quartered and straight grained. Not sure if i have mentioned it but that's what i aim for with my fretboards ;)
    The ebony is less perfect. It has colour variation and a light flame, but you can just about make out that the grain is still fairly consistent. nothing too erratic going on
  16. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    got the top started for the custom
    It gives me high hopes for the matched set i am saving for a later build
    yamariv and failsafe306 like this.
  17. kboman
    kboman Senior Member
    6,458
    5,699
    Jun 19, 2011
    I love both the flame top and the ebony fb, specifically for the inconsistencies! :)
    Impressive work and I'm looking forward to seeing that Custom finished.
  18. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    i skipped ahead a few steps in the last 24 hours.
    Body got chambered until it weighed 4.1lb. I stained it black inside in case i want to add an f-hole later, but i probably won't
    i glued the top on and decided to go back on my comments regarding double bound customs... its routed for 7-ply binding front and back, still need to finish the bit of the carve in the cutaway though.
    And i have roughly carved the top
    [​IMG][​IMG]
  19. WezV
    WezV Senior Member
    399
    477
    May 17, 2016
    checking the binding fit
    Compared the the 74 custom i have on long term loan
    NylesR, yamariv and dickjonesify like this.
  20. NylesR
    NylesR Junior Member
    8
    1
    Dec 10, 2016
    Most impressive!
    What glue do you use for the top and body?
    I have a few projects I'm starting and they will be my first builds, gathering as much info as I can.
