Korean Les Paul Truss Rod Nut
Discussion in 'Epiphone Les Pauls' started by Brooklyn1971, Apr 15, 2016.
  1. Brooklyn1971
    Brooklyn1971 Junior Member
    2
    0
    Apr 15, 2016
    While stationed in Korea about 15 years ago I picked up a Les Paul Standard. Recently there has been a buzz in the lower frets. I took it to my local guitar store to ask them if they can help with the problem. They told me it is a truss rod issue, but it is a brass nut and then did not have the correct tool to adjust it without damaging it. I should have asked more questions, but left. Now I want to just buy the right wrench and bring it to them to fix. I live in the middle of nowhere Georgia so my music store options are very limited. Does anyone know the correct size (I am assuming it would be in millimeters). Also, has anyone heard of a brass nut tool VS a non brass nut tool? That was a new one for me. Any additional info would be helpful too (where to purchase...etc).
  2. Brooklyn1971
    2
    0
    Apr 15, 2016
    Thanks for the feedback! Looks like the 2nd rod. I agree that it is BS and I need to find someone that can actually help.
  3. Alty
    Alty Senior Member
    589
    501
    Oct 9, 2013
    ^^ See above....:)
    Never heard of a 'Brass Nut Tool', sounds like they do have tools but not mechanical ones.
  4. Bytor1958
    Bytor1958 Senior Member
    7,238
    12,337
    Jan 9, 2013
    I wouldn't go back if they don't have the right "tool" for the job.
    You could also try a deep well socket with a extension, if there's room.
  5. Seannn
    Seannn Junior Member
    2
    0
    Sep 29, 2017
    7mm. I have an 89 and 97 Kor Epi
  6. GuitarMechanic
    GuitarMechanic Senior Member
    952
    449
    Dec 9, 2010
    RUN............... away from that shop FAST
    fumblefinger likes this.
  7. workerunit
    workerunit Senior Member
    585
    261
    May 8, 2011
    I bet your Epiphone was made by Samick, probably has a long neck tenon too.
  8. dmvksv
    dmvksv Senior Member
    431
    337
    Jul 6, 2013
    I have a Korean Hamer that had the same issue. I got a 7mm tool off of Amazon, it worked great. I know some of the older Ibanez's used a 7mm also.
