Kit clinic-all brands- routine & fixes
Discussion in 'The Custom Shop' started by Ole'Lefty, Oct 23, 2010.
  1. RubberDucky
    RubberDucky Junior Member
    14
    0
    Jun 10, 2011
    Is it common to have a bent neck? Why is that?
  2. Cpt_Gonzo
    Cpt_Gonzo Senior Member
    2,923
    905
    Dec 27, 2008
    Not common, but it happened to some guys. Jay will replace anything broken, though, as I said.
  3. bradland
    bradland Senior Member
    226
    88
    Oct 29, 2009
    Ok guys here's the latest in the ongoing saga of my George M kit...
    A quick summary-
    Removed the FB because the kit neck was crap, bought a very nice neck from BFCG:dude:, ordered new binding (for the neck) from ALLPARTS, punched dot markers out of Fender tortoise picks, and before gluing the new binding I started looking very closely at fret spacing. Realized several things are not right...
    This is where I am currently-
    First I noticed the 1st fret is too far from the nut, based on Bartletts vintage fret spacing chart, the exact amount is irrelevant please continue reading. I decided if the 1st fret is far off how can I even measure all the rest? So I decided to use the same chart to make my own fret spacing ruler, which realized two things...
    1. The fretboard has 3/32" too much material at the nut.
    2. Frets 1,2,3, and 4 are all off various amounts (approx half the width of the fret) too close to the nut. Number 2 is the worst at a little over half the width of the fret itself.
    So the 3/32 at the end of the FB is a simple fix. This pulls the other 18 frets right where they should be. But what about frets 1 through 4? I really don't think I'm over analyzing this, am I? I guess this is why this project is taking so long, I'm too meticulous, patient, and BUSY!
    Thanks in advance for any help!
  4. ievans
    ievans Senior Member
    702
    118
    Dec 21, 2009
    Before you do anything, make sure you're not dealing with the issue of there being no standard 24.75 Gibson scale. Gibson's scale hasn't been exactly the same over time. It could be 24.625 using the rule of 12, or it could be 24.75 using the rule of 18.
    David Collins has a good post laying out the problems in this thread here:
    http://www.mylespaul.com/forums/luthiers-corner/131930-fret-slotting-templates.html#post2518089
    The point being that your fretboard could be fine, but it isn't using the same calculation as the Bartlett plans.
  5. bradland
    226
    88
    Oct 29, 2009
    It's very cool you took the time to create that template. I'm sure it's an invaluable tool for the avid builder. I DL'd it and I'll have it printed full scale on Monday. Thanks again!
    If I remember correctly I think George was shooting for '59 spec so I have a feeling I may end up looking for a new FB...
  6. bradland
    226
    88
    Oct 29, 2009
    Yes sir you are correct! I finally had the file printed full scale and the FB is based on the Martin Short Scale 24.84".
    So I guess I'm OK, I think...:fingersx:
    ievans likes this.
  7. ievans
    702
    118
    Dec 21, 2009
    So I guess the next question is, how's the bridge location? In other words, is the 12th fret 12.44" from the nut and bridge?
  8. bradland
    226
    88
    Oct 29, 2009
    Have not drilled for the bridge yet. I wanted to resolve this before going further. glad I waited!
    You are obviously very knowledgeable in the many different scales and methods by which they are calculated. What can you tell me about the Martin Short 24.84"? Should I be concerned at all or is this a non issue for a LP kit?
  9. bradland
    226
    88
    Oct 29, 2009
    Also wouldn't it be 12.42" ?
  10. ievans
    702
    118
    Dec 21, 2009
    Right, sorry. 12.42.
    I'm hardly an expert on the different scale lengths, really. I just collected the info for that template.
    With that said, my take is that having an LP with a 12.84" scale is not an issue. It's so close to a "normal" LP 12.75/12.625 scale length that you won't notice it, and I doubt anyone else would unless you told them.
    So set your bridge location based on your particular fretboard and continue on. :thumb:
  11. Juan7fernandez
    Juan7fernandez Senior Member
    467
    115
    Jul 31, 2009
    Pictures didn't work.
  12. Dirk$Diggler
    Dirk$Diggler Senior Member
    267
    248
    Jun 7, 2010
  13. captcoolaid
    captcoolaid Senior Member
    11,426
    3,913
    Nov 29, 2008
    Thanks Dirk for doing this. I have a question. everyone was talking about the neck angle. Is this because of A the body angle. B) the tenon angle or is it the mortice on the body angle. The reason I ask is I could with my limited room and very limited neck skills do the tenon sand and the body angle however the mortise is where I would have an issue.
  14. armann
    armann Senior Member
    1,033
    42
    Apr 20, 2008
    I have a problem with my Les Paul.
    When I turn any knob the guitar looses sound and then it comes back in.
    It's like one wire isn't connected really well.
    Any ideas ?
    Thanks.
  15. Daniel
    Daniel Banned
    7,710
    14,182
    Jun 26, 2010
  16. jordans0nly
    jordans0nly Senior Member
    3,051
    579
    Mar 4, 2010
  17. silverkw
    silverkw Senior Member
    1,935
    761
    Apr 24, 2010
  18. jordans0nly
    3,051
    579
    Mar 4, 2010
    Have no idea what to do man, really. At a loss for words. Over two years, money spent on tools, paints, other things. Gone. Also about to get laid off...
  19. Dirk$Diggler
    267
    248
    Jun 7, 2010
    Sorry to hear about the kit. On the bright side I think you might have saved some serious money in the long run. The GM kits were a B***h to complete and a money vampire as for all the modifications that had to be done. You might be better off getting a kit that actually is possible to complete. :)
    I had a GM kit made and also ordered a JR kit. The LP I'm very happy with but the guy who put it together swore never to touch one again. As for the JR kit...well George Gorodnitski (George M) never shipped it. I sent him lots and lots of reminders and asked for a refund but I suppose he is happy with all the cash he managed to get before he got banned from the forum.
    The moral of this story being that these kits bring bad luck! Good riddence to bar rubbush! :(:(
  20. jordans0nly
    3,051
    579
    Mar 4, 2010
    But parts I bought were with that guitar too. Especially the Tulsa MOP inlay. Makes me sick to my stomach.
