Kit clinic-all brands- routine & fixes
Discussion in 'The Custom Shop' started by Ole'Lefty, Oct 23, 2010.
  1. Barnaby
    Barnaby Premium Member
    8,481
    9,823
    Nov 5, 2010
    Yikes! :shock:
    Looks like the tenon is really having trouble getting in there. If I were you, I might measure where the mortise meets the bottom of the pickup cavity and then check the tenon to be sure that it isn't reaching the bottom of the mortise. You should be able to figure out (with some trial and error) where the problem spots are. Also, spend some time checking that the neck and body angles are consistent.
    From your photo, it looks like the problem is actually with the mortise edge itself on the RH side. Very careful sanding is probably the safest...although, personally, I'd use a very sharp chisel to fit things if the bottom of the mortise is level and at the correct angle.
  2. jordans0nly
    jordans0nly Senior Member
    3,047
    579
    Mar 4, 2010
    Hmm..
  3. Barnaby
    8,481
    9,823
    Nov 5, 2010
    On further reflection, check the mortise sides. If they are straight, adjust the tenon to fit. If they are not, then adjusting the tenon will only make things worse. They may have swelled or changed shape due to moisture, making the fit bad.
  4. jordans0nly
    3,047
    579
    Mar 4, 2010
    Well, hopefully I'll figure it out soon. Ready to get this thing painted..
  5. jordans0nly
    3,047
    579
    Mar 4, 2010
    Alright fellers,
    I've made progress in the past hour or so. Tell me what you think..
    Now, the bottom of the tenon, is sitting just a bit above the cavity. That normal? If not, what to do about it? Seems like I've sanded by tail off, lol.
  6. bfcg
    bfcg Senior Member
    4,376
    174
    Dec 6, 2008
    measure the depth of both parts. Make sure that there is no glue or any other shputz under the fingerboard.
  7. jordans0nly
    3,047
    579
    Mar 4, 2010
    Thanks Bill. Will in a bit.
  8. MBrennan
    MBrennan Senior Member
    175
    58
    Feb 3, 2010
    What was the angle of your neck before you started fixing. Mine is in the 5.5 degree range.
    Also, the tenon seems much thinner than anything I've seen from others that have posted. The factory "fix" was to put maple shims on the sides of the mortise (which I've removed). However; the bottom of the tenon also isn't square with the sides.
    I may try to glue shims on the sides of the tenon, and also on the bottom, and then try to re-shape the tenon.
    I can't believe it's already been a month since I last posted-slammed at work.
    Good news is that the Jr. is in the paint stage. LP-4 kit is on the radar. :thumb:
  9. jordans0nly
    3,047
    579
    Mar 4, 2010
    I have to fill in a few gaps with glue. What's the best way to go about this? I've applied the shellac, sanded it before hand.
    I've mixed my acetone/binding for glue. Thanks guys.
  10. jordans0nly
    3,047
    579
    Mar 4, 2010
  11. MBrennan
    175
    58
    Feb 3, 2010
    Where are the gaps you need to fill? Are they between the body and binding. Also, are you doing a solid color finish or a burst type? How you fill the gaps depends on the final finish choice.
    There are a lot more experienced people than me that can add suggestions, but I'll add what I can. :thumb:
  12. jordans0nly
    3,047
    579
    Mar 4, 2010
    Yea, just a few spots between the body and binding. I'll be doing a tobacco burst with amber and black.
  13. MBrennan
    175
    58
    Feb 3, 2010
    You might be able to make a wood "putty" like Bossman did with yellow glue and saw dust to fill in the voids, then just sand it back.
    http://www.mylespaul.com/forums/custom-shop/111398-bossmans-kit-build-5.html#post2662750
    That way it may still blend in when you put finish over it.
    Or, if the burst will be almost solid next to the binding, you could fill with Gap Filling CA glue and sand it back smooth, spray the black over the fill, and scrape the binding.
    Just off the top of my head.
  14. jordans0nly
    3,047
    579
    Mar 4, 2010
    That does look pretty cool huh? :)
    Might try it.
  15. bossman302
    bossman302 Senior Member
    300
    14
    Dec 8, 2009
    I don't know anything about tobacco burst finishes so if you plan on doing the sides a solid black then you can use anything to fill in the gaps. You can use grain filler, regular putty, or the saw dust and glue.
    If you plan on staining the sides or staying a natural color then I would suggest the saw dust and glue. This will blend in the best. In my case this worked out really well. It stands out in the picture but in person you don't even know its there.
  16. jordans0nly
    3,047
    579
    Mar 4, 2010
    I'll be staining the sides a little. Not too dark, but hopefully will look good.
  17. RubberDucky
    RubberDucky Junior Member
    14
    0
    Jun 10, 2011
    I have been reading through this thread because I am interested in buying a kit. I was wondering if there is one brand that you pros feel stands out above the rest. I want a quality kit at a decent price, just like everyone else! Is there a thread about this? I can't find one. Any advice?
  18. Cpt_Gonzo
    Cpt_Gonzo Senior Member
    2,923
    904
    Dec 27, 2008
    Bulldog bodies is a nice option. Will have some issues but in general, they are the most consistent kits out there in that price region, have the best woods and require the least amount of work.
    Of course, there are some people who got bad kits but Jay is very helpful and friendly and replaces damaged items without trouble.
    Daniel likes this.
  19. RubberDucky
    14
    0
    Jun 10, 2011
    Awesome. Thanks for the advice!
  20. Cpt_Gonzo
    2,923
    904
    Dec 27, 2008
    If you order one, first thing to do is check your neck for straightness and test the function of the trussrod.
