Keep Your Guitar in Tune : changing and stretching new strings
Discussion in 'Guitar Lessons' started by Malikon, Nov 18, 2012.
  1. Malikon
    Malikon Henshin! V.I.P. Member
    69,068
    192,468
    Jan 21, 2010
    I've adjusted Strats that were in tune. You just need to make sure that the screwdriver is a perfect fit, so it doesn't strip the screwhead.
    ...but that applies to any situation where you use a screwdriver.
    The proper screwdriver head in the proper screw, can't strip out,...in my experience. It grips too well to 'skip' across the screw.
    ...that being said,..if I were tightening the claw (which would raise the string pitch even higher,..increasing the tension)...then yeah I'd loosen the strings first.
    ...that was one of the things the bugged the sh*t out of me about Strats,...actually maybe the only thing. I had to do setups on it at least once a month because the saddles would move.
    And then instead of adjusting 2 screws (like on an LP) you're adjust 12 tiny little allen screws,..2 in each saddle.
    That got real old real quick. :laugh2:
    I prefer the sound and feel of an LP,..but I LOVE how much easier they are to setup.
    Well cut nut, proper relief in the neck via T-rod adjustment, and set the bridge/string height? That's it,...You're off and racing.
    No constant tuning and retuning,..adjusting a couple things, retuning,..adjusting a couple things,..retuning.
    Strats are great guitars,...but damn they're a lot of work to keep running in a perfect and optimal state.
    ...at least in my experience. It became a real chore keeping it optimal 100% of the time.
    1 person likes this.
  2. MooCheng
    MooCheng Senior Member
    6,258
    9,038
    Sep 2, 2013
    yeah they do tend to move, loctight or nail varnish on the threads stops 'em loosing an they can still be adjusted later if you want to, Dont use paint, I found out that was,nt a good idea :)
    like the vid' btw
  3. AJBehrens
    AJBehrens Junior Member
    5
    1
    Jan 28, 2015
  4. Plant
    Plant Member
    51
    39
    Feb 15, 2011
    Has anyone else ever been tightening the low-E, without noticing that it wasn't in the nut, and was being wound against the headstock leaving a dent?
    No, just me being a plonker then :slash:
  5. Plant
    Plant Member
    51
    39
    Feb 15, 2011
    Is it possible to over-tighten a string when putting it on? My D string sounds a but twangy (as if it isn't actually tight enough, even though it is in tune) and I am wondering if I damaged the string by tuning way past the D (I wasn't paying attention)?
  6. 357mag
    357mag Member
    52
    12
    Mar 4, 2008
    Nothing wrong with import guitars. Having a $2500.00 Gibson isn't gonna make you sound or play better, nor is it gonna stay in tune any better. It's all bull****.
  7. Thugstrings
    Thugstrings Junior Member
    19
    11
    Jun 13, 2017
    Bookmarked. Thanks for sharing this!
  8. Malikon
    69,068
    192,468
    Jan 21, 2010
    no problem.
    I see a lot of people complain about how Les Pauls wont stay in tune and I honestly never have that problem, not with any of them. So I don't think it's the Les Pauls. :laugh2:
    jeff_farkas and parts like this.
  9. NorlinBlackBeauty
    NorlinBlackBeauty Senior Member
    9,333
    27,069
    Oct 29, 2017
    Nice vid, especially for those who have not done this.
    I've been at this a long time. I've always looped the string under and over at the start to insure a secure lock. Makes them a tiny bit harder to remove, but they are not going to slip.
    Lemon oil is a subject of some debate. I used it back in the day - no longer. The acidity can have a negative effect should any make its way into the frets. Martin guitar specifically states to avoid lemon oil. They recommend 3 in 1 oil or what is currently used at the factory (been there 3 times) Dr. Duck's Ax Wax (no wax in it).
    I use a tiny drop on a clean cotton rag, rub it in to the wood one or two sections at a time to clean finger grime, then buff what little excess is left off. No real need to let it soak in. Your mileage may vary ...
    I pull the strings to stretch as well, but only 2 or 3 times. I may try more.
    This may be mentioned here as well - wash your hands well before playing (and changing strings) if you are able. Carefully wipe your strings down after playing with a clean cotton cloth. Your strings will thank you for it by lasting longer.
  10. andydgg
    andydgg Junior Member
    18
    11
    Sep 24, 2013
    I've just started putting vaseline on the nut and saddles at string changes, keeps in tune now when bending. I've just put on some elixir coated strings and my finger tips are still grey after playing, the fretboard is clean.
  11. andydgg
    18
    11
    Sep 24, 2013
    I've snapped a high e string when changing it by tightening it too much, use an electric tuner now, makes life so much easier.
  12. NorlinBlackBeauty
    9,333
    27,069
    Oct 29, 2017
    Not sure I'd want any petroleum product soaking into the bone nut (assuming that is what the Epi has). Pencil graphite works very well.
  13. Malikon
    69,068
    192,468
    Jan 21, 2010
    I think Epi uses a nylon or plastic nut.
    Bone is a bit too high end for a stock Epi.
    ...actually I can't think of any guitar that comes with a bone nut stock. Usually it's Corian or some type of synthetic bone on the higher ends guitars. I think ESP/LTD uses Tusq (last time I looked was years ago.)
    Most regular guitars seem to use nylon or plastic nuts though. And with plastic being made from petroleum I really don't think it's going to harm anything.
    ..that being said don't coat the nut with giant globs of it, a little bit goes a long way. I use a q-tip to get it down in the slot then I wipe away any excess. And once the strings are seated in the slots I wipe it again so there's nothing residual, the only vaseline is under the string in the slots.
    jeff_farkas likes this.
  14. parts
    parts Senior Member
    13,125
    24,365
    Oct 13, 2010
    i Use dry powdered graphite..for many years,, I have bone,,brass and stock nuts..
    Never a creak or problem..
  15. jeff_farkas
    jeff_farkas Senior Member
    32,884
    21,311
    Nov 1, 2008
    I can't say that I've had issues with either my LP or 339 staying in tune. When I change the strings I make sure to stretch them properly and bingo.. they stay in tune.
  16. andydgg
    18
    11
    Sep 24, 2013
    epi and gibson aren't bone nuts, I don't know how vaseline would harm bone anyway.
