Keep Your Guitar in Tune : changing and stretching new strings
Discussion in 'Guitar Lessons' started by Malikon, Nov 18, 2012.
  1. Malikon
    Malikon Henshin! V.I.P. Member
    66,788
    183,742
    Jan 21, 2010
    It's a long video, basically a lesson on:
    strings themselves
    string changing
    stretching
    different ways to tune; Relative and Harmonic.
    I know I try to keep my videos short, but this topic I felt needed expanding on to cover related topics. And basically be a lesson instead of just a quick demonstration.
    So this is an actual 30 minute lesson.
    Hope you enjoy. :dude:
  2. River
    River Senior Member
    57,250
    91,262
    May 19, 2008
    Malk promises, Malk delivers.
  3. Dr.Distortion
    Dr.Distortion V.I.P. Member
    5,283
    5,744
    Dec 6, 2009
    I use almost the exact same procedure.
    1) I do knot my strings (wrap them back under and over the string going into the post)
    2) I keep my string tight by running the string under the bottom of the side my thumb and over the top of my ring finger on my right hand and twist my hand to make the "Z" shape...
    Great video Malk... :thumb:
  4. Malikon
    66,788
    183,742
    Jan 21, 2010
    thank ya Sir.
    2 people like this.
  5. LiveSimply
    LiveSimply Senior Member
    844
    644
    May 23, 2011
    It's great that you take the time to make these videos, Malikon. When I started in electric guitar the web was a great reference tool for stuff like this, so I'm sure there will be many folks that will be very appreciative.
    Couple of questions- Do you not find any benefits from lubricating the bridge and nut before putting on the strings? I gather you didn't if the nut was "properly cut", as I believe you put it. As a follow up to that, what are the tell tale signs if a nut not being properly cut? Is it an intonation thing or strings going out of tune? Have you found bone nuts or any other type of nut material to help the strings stay better in tune?
    Thanks.
    2 people like this.
  6. Malikon
    66,788
    183,742
    Jan 21, 2010
    I like bone and corian nuts myself, but that's just me.
    Improperly cut nut?
    When it's doing what mine is starting to do, (you can actually see and hear it in the video.)
    The D string is starting to bind up, and the high E is starting to have a slight buzz when it's open, almost sitar'ish.
    Won't be long before I need to replace it but it's held up since 2010 so I'm not really complaining, it's still the stock Epi nut.
    No I've never lubricated the bridge.
    I only lubricate the nut if I absolutely have to.
    A truly well made, properly made nut,...is a thing of beauty. It really is. And honestly you don't see it very often and I've 'paid' to have nuts replaced that looked like they were made with a hacksaw. Finding a guy that really knows how to make a proper nut? .... idk,...I haven't found one yet in person.
    On a truly righteous nut the strings only sit about halfway in the slots, literally it seems like half the string is 'above' the nut. And the fall off on the nut will match the angle of the headstock, maybe just a tiny bit further then the headstock angle.
    So really the only point that the string touches the nut is the very, very front, right where the string touches it and slopes down. Seriously that's it, just a tiny little point of contact.
    And when it's done right the strings wont pop out of the nut,...you'd think they would but they don't.
    I've only seen a few guitars in my time that really had a perfect nut installed. But once you see them and play them, then you go back and look at Epi nuts and see the strings are like 1/8 buried into the nut,....you start to realize what a POS it is.
    Then you look around the guitar store and you start to wonder why it seems like every guitar company has sh*tty nuts poorly cut, out of crappy nylon type material.
    7 people like this.
  7. LiveSimply
    844
    644
    May 23, 2011
    thanks
    1 person likes this.
  8. onehippie
    onehippie Senior Member
    8,004
    37,212
    Apr 28, 2010
  9. Mrmri
    Mrmri Junior Member
    1
    1
    Oct 21, 2012
    Thank you!
  10. joba
    joba Premium Member
    1,403
    2,136
    Mar 15, 2012
    Bookmarked , Thx.
  11. Sin Nombre
    Sin Nombre Senior Member
    8,322
    29,321
    May 21, 2009
    If you are changing strings on a Strat with a floating trem do you remove all the strings at the same time?
  12. Malikon
    66,788
    183,742
    Jan 21, 2010
    I used to. As long as you're not changing string gauges the bridge should return to the same spot.
    Generally with Strats people take the backplate off for string changes (many just leave it off, and lose it.) If the bridge doesn't return to exactly where you want it, it's pretty easy to adjust the 2 claw screws that the bridge is anchored to, to raise or lower it.
    (loosen the screws = raising, tightening the screws = lowering)
    4 people like this.
  13. Sakamoto
    Sakamoto Senior Member
    1,225
    1,552
    Jul 29, 2010
    Thanks Mal!
  14. onehippie
    8,004
    37,212
    Apr 28, 2010
    everyone that has finished studying the guide lines in the tune up thread should immediately come here
    this should be a sticky
  15. Malikon
    66,788
    183,742
    Jan 21, 2010
    a sticky eh?
    :hmm:
    I'm still waiting for my VIP status. :laugh2: :laugh2:
    I keed, I keed,...I prefer being an underdog.
    4 people like this.
  16. Backwoods
    Backwoods Junior Member
    8
    2
    Nov 3, 2012
    Thank you Malikon, this guide was great. As someone just beginning their journey with guitar, this was exactly what I was looking for. I haven't attempted my first string change yet, but when I do, this video is bookmarked. I did try the string stretching technique today though. Thanks again for taking the time to create the video and share some of your knowledge.
  17. lunchbox
    lunchbox Senior Member
    6,851
    9,289
    May 29, 2011
    Well done dude!
    Since I've been using Ernie Ball Rock 'n' Roll 10's (steel core, pure nickel wound), I find it hard to play anything else. Very similar to the DR's that you like.
  18. Echo
    Echo Member
    98
    41
    Oct 26, 2012
    Great job!!! :thumb: I expected everything and got even more :D
  19. 6stringelectric
    6stringelectric Senior Member
    152
    207
    Mar 27, 2012
    Great video. I'm sure it will help a lot of people who are just starting out on guitar.
    It took me a while when I first started (no helpful videos back then) to figure out the best way to change my strings - and I eventually came up with a method very similar to yours.
    2 people like this.
  20. onehippie
    8,004
    37,212
    Apr 28, 2010
    Malikon you's V.I.P in book of our
    incoming to yall
    2 people like this.
