Just to TRIPLE check black (-) and white is (+)
Discussion in 'The Squawk Box' started by cherrysunburst00, Oct 4, 2017.
  1. cherrysunburst00
    cherrysunburst00 Senior Member
    13,637
    23,460
    Mar 15, 2015
    I did a search. I'm OCD. Just to verify: when wiring speakers, black is (-) and white is (+), correct?
  2. The_Nuge
    The_Nuge Senior Member
    1,768
    1,183
    Dec 12, 2010
    With that colour combination, yes!
    You won't break anything wiring it wrong though, but it might soun "thin"!
    cherrysunburst00 likes this.
  3. DarrellV
    15,408
    32,728
    Nov 1, 2016
    One speaker in an amp cab? won't matter. It's AC voltage anyway.
    Only time it matters is when there are more than one speaker playing the same signal.
    Then as @The_Nuge said above, phase becomes an issue and one speaker wired backwards will make it sound thin without much bass.
    Normally you want the speaker cones to move in the same direction when hit with a voltage.
    Speakers are polarized just so you can match them to all work together.
    Put a 9 volt battery across the terminals briefly with the battery positive to speaker positive and notice the cone moves outward.
    Switch the battery polarity and apply the negative battery post to the speaker positive terminal, and the cone will pull inward.
    What happens when they are wired backward isn't dangerous to the amp or speaker, it just results in one speaker cone pushing out on a given signal while the other one is pulling inward at the same time.
    Equal and opposite reactions dictate that the pressure wave created by the outward moving cone, will be swallowed in the vacuum created by the inward moving cone next to it.
    That's all......
  4. cherrysunburst00
    13,637
    23,460
    Mar 15, 2015
    You guys are AWESOMELY AMAZING!!! Thank You.
    northernguitarguy and DarrellV like this.
