jtm45 ceriatone ppimv
Discussion in 'Amplified Parts' started by porkster, Jun 6, 2017.
  1. porkster
    porkster Junior Member
    28
    24
    Sep 17, 2015
    I just bought my dream amp & took it home plugged my stratin & its very bassy & when driven its not the jtm45 overdrive its muddy & sounds blocked up, its a ceriatone with a post phase investor master volume, , i have tried different settings with the mids & treble on 0 & bass on 1 & its not to bad but not as bright as it should be, i was thinking is it because its a new amp & needs to be run in
    my, speaker is a celestial vintage 30 singe cab a orange.
    i don't know if its faulty tubes or what, any input would be much appreciated.
    thanx forum..
  2. AmplifiedParts
    AmplifiedParts MLP Sponsor
    50
    11
    May 24, 2010
    That's a tough one. Different tubes can definitely have a different effect on your overall tone be it bass, treble, or mid response but your situation sounds more severe. This could also be something else entirely. I'd suggest bringing it to a reputable tech so they can go over the layout and check for issues.
    bulletproof likes this.
  3. Kris Ford
    Kris Ford Senior Member
    4,650
    3,812
    Dec 17, 2011
    MIGHT be the cab??
  4. tigger
    tigger Senior Member
    266
    215
    May 6, 2017
    Did you try emailing Nik?
  5. porkster
    28
    24
    Sep 17, 2015
    nik suggest to change the v1 cathode cap to a 1uf which should take the flub out when pushed & give me the jtm45 overdrive heavenly roar i long for...
