Is this CS a fake?
Discussion in 'Historics & Reissues' started by arturocivit, Sep 7, 2017.
  1. arturocivit
    arturocivit Senior Member
    588
    344
    Sep 11, 2011
    Hi there guys, I think it is, but just wanted the opinion on experts here, I know, there's the tune-o-matic that matchs the ones used by any Gibson but just wanted to be sure because last thing I heard, chinese knock off are coming with that as well and binding on fret ends, attaching a few images.
    Thanks
    Arturo 21397202_10209161424343091_225611863_n.jpg 21397433_10209161424383092_1220731422_n.jpg 21397202_10209161424343091_225611863_n.jpg 21397433_10209161424383092_1220731422_n.jpg 21397674_10209161427343166_514798598_n.jpg 21439294_10209161585587122_892133496_o.jpg 21441345_10209161427423168_2100310685_o.jpg 21476217_10209161427383167_893422775_n.jpg
  2. DarrellV
    DarrellV Make the Switch for the Better! Silver Supporter Premium Member
    10,419
    12,936
    Nov 1, 2016
    Looks legit to me based on the few points I've learned.
    Big diamond inlay , proper nut with strings resting on top. Truss rod cover looks good.
    Proper wiring and bridge.
    Look at the side of the nut.
    Is it cut into the binding , not setting on top?
    Imho it's real .
    arturocivit likes this.
  3. DarrellV
    10,419
    12,936
    Nov 1, 2016
    Never mind.
    I can see the nut cut in from the pic.
    Yup. Good.
  4. Sct13
    16,587
    19,037
    Sep 18, 2011
    At first glance it looks fine...
    That square hole in the cavity says its got a maple cap...But whats that do-jigger on the pot...and that grey wire sticking out...?
  5. DarrellV
    10,419
    12,936
    Nov 1, 2016
    Looks like the switch wiring.
    Black, white, and red.
    That looks like a terminal strip soldered to the top of the pot?
  6. arturocivit
    588
    344
    Sep 11, 2011
    It's a friend's guitar, he started a post on facebook asking if its real or not, you can image 50% says legit so, not sure I've learned a lot here but this one feels fishy, but not sure why
  7. DarrellV
    10,419
    12,936
    Nov 1, 2016
    You can always contact Gibson and run the serial number past them.
    I have heard of others doing this by email or phone call.
    They can tell you exactly what you have.
  8. arturocivit
    588
    344
    Sep 11, 2011
    That sounds great, thanks!!
  9. Sct13
    16,587
    19,037
    Sep 18, 2011
    If its an 03' then the switch plate is wrong.....it may be a 13'
    So they use vinyl insulated wire in these? I have too many historics I guess...
  10. Tim Plains
    Tim Plains Senior Member
    12,304
    7,263
    Feb 11, 2008
    Real, I'd say 2013, wiring isn't original.
  11. Sct13
    16,587
    19,037
    Sep 18, 2011
    I KNEW IT !!!
    LOL! :run:
  12. Bobby Mahogany
    Bobby Mahogany Senior Member
    17,657
    23,568
    Feb 25, 2012
    Should have a COA as well.
    But those get lost too.
  13. Crotch
    Crotch Support MLP Veterans & Vendors Double Platinum Supporter Premium Member
    9,864
    11,514
    Jan 13, 2012
    Looks cool to me too but that Gibson Custom stamp on the "volute" area is something I haven't seen before. I mean I've seen it, just looks a little off. But you guys who have chimed in know more than me.
  14. DarrellV
    10,419
    12,936
    Nov 1, 2016
    Not me!....:dunno::laugh2:
    Crotch likes this.
  15. PierM
    PierM Premium Member
    1,982
    2,119
    Aug 19, 2016
    Totally legit.
  16. jamman
    jamman Premium Member
    9,022
    7,239
    Oct 1, 2010
    I'd say it's real but 100% it's had some mods done to it . Those pots are OLDER type since they have the Gibson logo stamped on at least 2 of them . That AFAIK isn't/wasn't used in 2013 . Plus it's not original soldering .
    The route cut can be squire and have a mahogany top, IIRC. but it's not a solid 1 piece body .
    the TR cover sits pretty low ,imo . Like a 60's neck . So if it's got a slim neck .... If not :hmm:
    Does the CS shop still use that Logo today ? Haven't seen a new Gibson CS LP Custom lately .
    What is the Fret board made of ... That would help in determining the year made . 2013's (unless a special run) normally use Richlite FB's.
    If the case is original , it's a newer type Lifton RI case .
    seems to be some conflicts about the guitar ...Calling Gibson may give a better focused answer .
  17. PierM
    1,982
    2,119
    Aug 19, 2016
    It's a 2013 regular custom.
    Richlite FIngerboard.
    Neck is a rounder gently '50. Not really fat, but not a slim.
    Case is correct
    Logo on the back is also correct and still being stamped these days.
    Wiring has been touched, so I would also check the pup. They should be the typical 490/498 set.
    arturocivit and DarrellV like this.
  18. PierM
    1,982
    2,119
    Aug 19, 2016
  19. mudface
    mudface Senior Member
    2,256
    2,975
    Aug 29, 2016
    "Fake it's not".........says YODA.
  20. THDNUT
    THDNUT Senior Member
    14,430
    19,482
    Feb 5, 2012
    I don't know. It has some weird ghostly swirls in the paint on the back of the headstock that resemble a cell phone.
    DarrellV and ht-57 like this.
