Is it safe to "mute" a tube amp with a dummy headphone plug?
Discussion in 'The Squawk Box' started by Rick, Mar 6, 2018.
  1. Rick
    Rick Senior Member
    739
    745
    Apr 17, 2015
    I can get some surprisingly good sounds from the line out on my 5150iii and using a cab impulse. The louder the better... But would it be safe to "mute" the amp by plugging a guitar lead into the headphone jack so that I can crank it and monitor the affected signal through my interface (leaving the cab connected of course)?
  2. cybermgk
    cybermgk Singin' the body lectric Platinum Supporter Premium Member V.I.P. Member
    13,959
    18,764
    Jul 7, 2011
    The amp mutes the speaker out when the headphone jack is engaged, which implies a built-in, internal load sink. So I don't see why that would be an issue.
  3. DarrellV
    DarrellV About as sharp as a bowlin' ball! -NPM Premium Member
    18,304
    42,992
    Nov 1, 2016
    Or just plug a set of cheap headphones into it for a load and throw them into a drawer to hide the sound....
    bulletproof likes this.
  4. spitfire
    spitfire Senior Member
    1,846
    2,072
    Sep 21, 2009
    I doubt the amp relies on the load of the headphones to work properly. But, you could plug in a lead with a small dummy load on it, like 600 ohms to simulate headphones. Doubt it is needed though.
