Is it possible to put whammy bar on my les paul studio?
Discussion in 'The Custom Shop' started by toonmokka, Jan 7, 2008.
  1. mrbr000takular69
    mrbr000takular69 Member
    33
    0
    Oct 26, 2008
    +1
  2. ellem52
    ellem52 Senior Member
    196
    4
    Oct 25, 2008
  3. coreydm676
    coreydm676 Senior Member
    2,354
    571
    Aug 13, 2008
    hes on trailer park boys right now:laugh2:
  4. jhollon
    jhollon Senior Member
    202
    0
    Mar 31, 2008
    this dude is getting his money's worth out of that whammy. every two or three seconds by my count.
    Randy is rolling over now!!!!!
  5. patrick ginnaty
    patrick ginnaty Senior Member
    916
    110
    May 31, 2008
    I'm about to put a Bigsby on a Studio that I'm putting together for a friend. His last Studio had a Bigsby, he liked it. The last Studio was maroon, this one is black.
  6. franci8
    franci8 Member
    59
    1
    Oct 2, 2008
    It could be an awesome addition but you would have to have balls to do it - I would cry if I had to deface by Zakk Wylde Epi
  7. TheWellGoodShow
    TheWellGoodShow V.I.P. Member
    3,131
    19
    Jul 10, 2008
    i want a bigsby
  8. coreydm676
    2,354
    571
    Aug 13, 2008
    dude look at the headstock its a epi
  9. Sky
    Sky Senior Member
    4,986
    765
    Oct 5, 2008
    Or you could just possibly get a Agile AL-2000
    On;y $279.00 and they have Floyd Rose
    Personally I like the white with gold
    Check them out here Rondo Music Home Page
    The Floyd Rose start on page 8
    I'm sorry if this didn't help but people compare these Agile's to Epiphone Les Paul's
    - Jordan
  10. BillTrantos7
    BillTrantos7 Junior Member
    5
    0
    Jan 6, 2010
    hi guys.. I have a J&D LP and I want to put a whammy bar.Is it possible?And if it is..is it difficult or it demands a lot of money??thank you in advance.. :slash:
  11. Indyclone
    Indyclone Senior Member
    3,599
    1,652
    Jan 11, 2010
    it's as easy as reading all of the posts in this topic that precede yours.
  12. _pete_
    _pete_ Senior Member
    205
    16
    Jan 8, 2008
    I'm not familiar with the brand. Can you post a pic of it?
    I assume you're wanting a Floyd Rose so to answer your questions with that in mind:
    If it's a normal LP copy then yes, it's possible.
    It's not extremely difficult but you have to be precise and very careful.
    Hard to say what a shop would charge for it but if you were in my area, I'd do it for around $125 USD.
  13. Graemewoodman
    Graemewoodman Senior Member
    129
    3
    Apr 17, 2010
    just buy a gibson les paul axcess they have a floyd rose and a shaved heel so you can reach up to the 22 fret easily
  14. SouthernJammer
    SouthernJammer Junior Member
    8
    0
    Jul 16, 2010
    Why don't you get a Bigsby? There are now these plates that cover, or not, the original tailpiece holes. They also eliminate invasive routing. Just a few tiny holes on the side of the body around the strap button. If you want it to stay in tune, try wedging a quater between a section of the spring - an old trick that worked wonders on a '79 ES-335 a friend of mine has.
  15. longan
    longan Senior Member
    1,506
    430
    Jun 20, 2010
    I think the Bigsy is the best option, you only need a special plate and B7s fit straight on.
  16. darth Nihilus
    darth Nihilus Senior Member
    106
    17
    Mar 18, 2009
    A Kahler will stay in tune just fine. Just remember after you bend a string, do a quick dive on the bar and the string you just bent will return to pitch.
    Not a big deal.
  17. Rock
    Rock Senior Member
    548
    187
    Oct 15, 2009
    Epiphone has the "Epiphone Les Paul Plustop PRO/FX Electric Guitar."
  18. dspelman
    dspelman Senior Member
    9,785
    5,664
    Apr 30, 2009
    Call Gary Brawer in San Francisco (or just email him) and ask. At a guess, you're looking at a couple of hundred dollars for the routing required plus the cost of the trem. Might as well go Floyd or Kahler if you're going to do it.
    There's another route -- you might just dump the current Epi and pick up one of the NEW epi LPs that has the Floyd already there. I think it's called the Epiphone Les Paul Plus Top PRO/FX, and it'll be $699:
    And yet another option: Rondo Music has the AL-3100 CSB Flame Floyd:
    Notice that this is a 24-fret guitar, which gives you better access to the upper frets while moving the bridge and bridge pickup a bit closer to the neck pickup. The 24th fret is about where the 22nd fret would be in relation to the bottom of the cutaway on a standard LP. Multi-layer binding on body and headstock, ebony fretboard and real MOP inlays. Alnico V pickups. Agile AL-3100 CSB Flame Floyd at RondoMusic.com $439.95 and SO worth it. If you get tired of the LFR in there, you can switch to a German OFR. It'll fit.
  19. tolm
    tolm Bigsby Junkie
    3,762
    2,383
    Jul 20, 2008
    As per other posts, Bigsby B7 installed using the Vibramate V7 or one of the kits from ZZGuitarWorks. Easy as pie.
    Having said that, I drilled holes and mounted mine straight to the wood but I was *really* sure I wanted a Bigsby. :)
  20. El Toro
    El Toro V.I.P. Member
    1,961
    74
    Aug 20, 2007
    Roman Rist has 3 of the "top loading" Floyds for LPs that need no routing.
