Is it possible to put whammy bar on my les paul studio?
Discussion in 'The Custom Shop' started by toonmokka, Jan 7, 2008.
  1. toonmokka
    toonmokka Junior Member
    6
    0
    Jan 7, 2008
    Is it possible
    And if it is can you tell me how to do it?
  2. BCRGreg
    BCRGreg V.I.P. Member
    12,491
    9,725
    Apr 2, 2007
    Not one that works.
  3. BitchBoy
    BitchBoy Guest
    a kahler
  4. WildeStarr
    WildeStarr V.I.P. Member
    3,040
    738
    Sep 7, 2007
    You can put on a Floyd Rose or Kahler, but they will require lots of work/routing. Most people don't want to do this to a Gibson. Here is another option. I put one of these on a Gibson LP a few years ago, and I was surprised... it actually works pretty good and stays in tune. No modification to the guitar body is needed.
    Les Trem Stop-Tailpiece Tremolos at Stewart-MacDonald
    The Les Trem is a high quality spring-tension tremolo for Les Paul® and other guitars with a Gibson style post-mounted stop tailpiece. The unit is easy to install in the guitar's tailpiece post bushings, without woodworking. The arm pivots the hinged rear string-mounting bar to sharpen or flatten the strings approximately one-half step.
    The Les Trem has a Bigsby-like feel and bending range, and requires 3-1/4" post spacing. It includes M8 metric and 5/16-24 mounting posts, plus hardware and instructions. The adjustable-length arm can be swung down out of the way when not in use. Note: The Les Trem is not designed to replace combination bridge/tailpieces such as our #0217 LP Junior bridge and #0198 Schaller bridge.
  5. toonmokka
    6
    0
    Jan 7, 2008
    How much would it cost to put whammy bar on my epi les paul studio?
    Like have an expert put it on for me
  6. drewbertca
    drewbertca V.I.P. Member
    2,506
    17
    Dec 6, 2007
    there's the stetsbar.....they look to be expensive though....$300 to $350...non invasive though
  7. WildeStarr
    3,040
    738
    Sep 7, 2007
    I have seen the stetsbar. Ugly and expensive.
  8. dwagar
    dwagar V.I.P. Member
    7,735
    966
    Jul 14, 2007
    probably not as expensive as routing out and ruining the value of the guitar though.
  9. WildeStarr
    3,040
    738
    Sep 7, 2007
    See post #4
    :wave:
  10. Tristram
    Tristram Member
    46
    0
    Aug 22, 2007
    You might be able to have a good tech install a Bigsby on you Paul.
  11. _pete_
    _pete_ Senior Member
    205
    16
    Jan 8, 2008
    This was really not that hard to do.
    I used the routing templates from Stewart McDonald, a plunge router, and a small drill press.
    BTW, it's a 12 year old Epi LP that I picked up om Ebay for under $270 w/case and SD 59's.
  12. dizmal
    dizmal V.I.P. Member
    485
    4
    Dec 29, 2007
    now see thats wat i would get but meh
  13. PraXis
    PraXis V.I.P. Member
    24,906
    24,329
    Dec 14, 2007
    Just get a digitech whammy.. it has the divebomb effect and you don't have to mod your baby
  14. Duster340
    Duster340 Senior Member
    125
    15
    Jan 2, 2008
    If you can fine one with the plate the Washburn Wonderbar actually bolted up to a Les Paul without routing. Ace Frehley used a Wonderbar on his Les Paul's with Frehley's Comet. I can dig up a pic later if you would like. I'm in the process of putting one on an Epiphone Les Paul Studio at the moment. I'm just having a problem finding the the right bolts (metric) with the right size head.
  15. hedzeppelin
    hedzeppelin V.I.P. Member V.I.P. Member
    1,299
    20
    Apr 23, 2007
    Les Pauls look fuggin' ugly with trems.
    It's like puttin' teats on a boar hog.
  16. Big John
    Big John it's all about the shirt V.I.P. Member
    7,242
    6,423
    Mar 18, 2007
    Alex seems to like it...
  17. WildeStarr
    3,040
    738
    Sep 7, 2007
    Yeah, if you want or need to do it, just do it. I would not do it to my 77 LP Custom, but I would be OK doing it to a newer low priced model.
  18. Duster340
    125
    15
    Jan 2, 2008
    I finally had the time to put the Wonderbar on my Epi LP Studio. It looks huge but does the job and I can always take it off and put the guitar back to normal and you would never know the Wonderbar was ever on it. No routing or drilling, with the plate under it you just bolt it all together.
      File size:
      85.6 KB
      262
  19. dwagar
    7,735
    966
    Jul 14, 2007
    Gibson seems to have a few at Namm, maybe you can buy one in the near future.
  20. Willy
    Willy Senior Member
    283
    4
    Nov 6, 2007
    I put a Stetsbar Black Max on my Epi. It is OK at holding the tune, better than Strat bridge but not as good as a Floyd Rose. Since I have installed the Stetsbar I have noticed the sustain of my guitar has taken a serious nosedive. I can't even get the sustain to remain for longer than about 1 beat in any fret above the 12th fret. Bends above the 12th fret have also lost their tone. I wouldn't recommend getting a Stetsbar, I regret laying out the unjustifiable amount of cash. On a positive note, The owner/operator of the company is very accommodating and helpful, I just wished this product was more of what I was looking for.
    Next string change, I am putting my TonePro's bridge and stop piece back on.
    WILLY
