Is it a good idea to satin finish a neck
Discussion in 'Epiphone Les Pauls' started by themanuser, Oct 23, 2012.
  1. themanuser
    themanuser Junior Member
    11
    0
    Jul 1, 2012
    Hello :thumb:
    I have a Epiphone Les Paul Standard and i like to satin finish it (aka: my hands
    are getting wet when i play sometimes.. :hyper: )
    SO iam asking you people if can i satin finish my neck and still guitar looks good or not :D :D
  2. Hack
    Hack Senior Member
    16,168
    43,546
    Jul 15, 2010
    I dont see where that would change the looks of it. Go for it!
    ...and we are going to need to see this guitar you speak of!
  3. Kynlore
    Kynlore Member
    36
    0
    Jun 10, 2012
    Looks good is subjective. What one person thinks looks good, another may not.
    I feel mine is faster though without it.
  4. SJM
    SJM Premium V.I.P. Member Premium Member V.I.P. Member
    5,298
    5,316
    Apr 17, 2011
    I don't do it but a lot of people do. Use some very fine steel wool if you decide to do it.
    Welcome to MLP. :photos: please.
  5. Papa
    Papa Senior Member
    768
    972
    Jun 1, 2009
    Yes, Welcome!
    Just remember to tape over your pickups with some masking tape.
    I've used steel wool, fine sandpaper, or Green Scotch Brite pads at one time or another for different projects.
    In any case your pickups don't need the dust.
    Good luck
  6. DagerOne
    DagerOne Senior Member
    2,173
    871
    Oct 16, 2009
    I have an Epiphone Ultra II, and the neck has a satin finish from the factory. It's one of my favorites based on feel.
  7. bloodied_fingers
    bloodied_fingers Senior Member
    239
    108
    Aug 27, 2012
    I did this to my neck with a green scotch brite type pad. Took about 30 seconds and the feel is 20x nicer to me now.
    I'm still trying to decide if I want to do the rest of the body.
    You know if you end up not liking it you can pretty easily buff it back up to a nice shine.
    1 person likes this.
  8. mazzith
    mazzith Senior Member
    212
    104
    Oct 11, 2012
    When I have my custom guitars made by Carvin I get a oil tung on my necks, feels so good in my hands.
  9. LesLuvva
    LesLuvva Senior Member
    1,826
    1,850
    Aug 27, 2009
    I've done it with a green scotch-brite scouring pad. Doesn't take long, and you don't have to do it very long before you get the desired result. The finish on the neck will look a bit different, much less glossy.
  10. lucifarion
    lucifarion Senior Member
    191
    38
    Jul 12, 2010
    I'm getting a new Les Paul Standard in two days, the first thing I'm doing when I get it is a satin neck (with a stinger lol). The satin neck is a good idea if like me your fret hand gets sweaty while playing. It stops your hand from sticking to the neck, I've done this to a few Epi's in the past... and even a few F guitars that had glossy neck finishes. It feels so much better then the heavy poly finish on Epi necks, and it will allow your fretting hand to move faster up and down the neck.
    Green scotch bright pads are better then steel wool... If you use steel wool it's a good idea to give it a quick wet sand afterwards to limit the scratches.... scotch bright pads don't really need this as they are much gentler.
    Happy fretting
  11. DHK68
    DHK68 Senior Member
    108
    122
    Feb 16, 2012
    Specficially talking Epiphone, with the thick poly finish, I would sand the neck back just enough to stop the sweaty sticking-hand effect. As for looks, who's gonna see the back of the neck except you?
    I sand mine back - the neck itself, not the fretboard, you can just move around easier, feels smoother plain n simple, it just adds to the playability. We're not talking about vintage collectables here, so make it easier and more practical to play. You won't ruin the neck, just take off the shine on the poly finish.
  12. harpman54
    harpman54 Senior Member
    615
    555
    Aug 23, 2009
    My Ultra II has the satin neck, and I got to where I liked that neck so much I went and did the necks on a few more of my guitars. The satin necks are faster, and simply feel better to me. I don't worry about the looks because nobody but me sees the back of the neck.
  13. Thumpalumpacus
    Thumpalumpacus Senior Member
    74,962
    181,592
    Nov 28, 2010
    Yeah, I've satined a couple of necks. Any more, I shop for them that way.
  14. Comanche
    Comanche Senior Member
    8,804
    26,525
    Mar 5, 2012
    Fender is doing a gloss finger board with a satin neck.
    I like it.
  15. 56GT
    56GT Senior Member
    3,374
    3,483
    Jul 19, 2012
    themanuser with sweaty hands... :hmm:
  16. MrKensei
    MrKensei Senior Member
    2,151
    1,828
    Nov 13, 2011
    I dont think it will do you any harm. Looks wise depends on the colour imo.
    My Zakk has a satin finished neck and it feels awesome. However both my standard and my mockingbird have gloss necks.
    On the standard the poly finish sb feels really thick and a bit tacky at times so I am thinking of sandingbt back.
    The BC rich pickups n the other hand has a much better feeling poly and I dont have any urge to fix that. It's my workhorse/jam session/ soon to be gigging guitar and feels great even after a couple od hours playing in the lower registers (0playing rhythm for a metal band means a lot of time spent in the same spot on the neck).
  17. straybeat
    straybeat Senior Member
    2,629
    1,460
    May 11, 2011
    My hand turns certain necks to all-out gum for some reason? My 3 Epi's that came with satin necks were great! Never had a problem with them at all.
  18. Fuelish
    Fuelish Senior Member
    2,731
    1,171
    Jan 27, 2008
    So, then .... would your hand sliding up and down the neck "buff" it back up over time? Well, assuming it gets played with any regularity...just wondering, although feeling no need for a satin neck as far as playability...I just pick 'em up and play 'em as is, it's all good:cool:
  19. straybeat
    2,629
    1,460
    May 11, 2011
    I know that whenever I buff up junior it starts to... uh-oh... nevermind. :laugh2:
  20. nzo
    nzo Senior Member
    268
    85
    May 17, 2010
    Yes, over time with playing, the gloss comes back.
