In need of serious advice for purchase
Discussion in 'Vintage SG' started by tonewheelz, Apr 25, 2016.
  1. tonewheelz
    tonewheelz Junior Member
    9
    7
    Feb 16, 2016
    So, in my continuing search for a late 60's Gibson SG standard, I've come across a 1967 Gibson SG, of all places, at Guitar Center in Towson, MD.
    This is the guitar:
    Vintage Gibson 1967 SG Standard Solid Body Electric Guitar | Guitar Center
    It's being sold for $2999, and I've gone ahead and put a deposit on it, while I try to do some more research. Lo and behold, I find the exact same guitar here from Woodlands, TX (and it is the exact same guitar down to the serial #):
    https://reverb.com/item/1749609-gibson-sg-standard-1967-cherry
    So, this $5,000 guitar on Reverb Guitar is now a $2999 guitar at Guitar Center. Needless, to say there are a lot of red flags. The tuners are not original (that's okay, I can buy some). The rep at Guitar Center says his repair guy confirms the pickups are original, pots are original, no repairs or breaks that he can see, nor any refrets and he says it plays perfectly.
    So, I'd be ever so grateful for some advice from you all. If I complete the purchase of this guitar from Guitar Center, I can have it shipped to the store in San Francisco, and then take it directly from the store to Real Guitars and have it appraised. I can then take it home and play it, and have the option to return it within 3 days to Guitar Center for a full refund. Of course, I'll be out for shipping & the cost of the appraisal.
    What would you do in this situation? Does the reward of scoring a 1967 Gibson SG Standard at $2999 outweigh the risk of losing what I end up paying for the cost of shipping & appraisal? Any theories on how this guitar being sold for $5,000 from Texas, ended up at $2,999 in Maryland?
    If I do go through with this plan, considering the information I've provided, any suggestions on specifically what I might want to look for, that even the appraiser might miss?
  2. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,293
    7,956
    Apr 4, 2013
    Looks like the Reverb listing "Ended," which means that it didn't sell (at least not through Reverb). It might have sold for less privately.
    Looks like the GC link says it's no longer available either.
  3. michaelinokc
    michaelinokc Senior Member
    6,772
    9,764
    Jan 27, 2012
    Probably because he put a deposit on it.
    1 person likes this.
  4. tonewheelz
    9
    7
    Feb 16, 2016
    That's right, it was posted as no longer available after I put a deposit on it.
    In the pictures, everything looks accordingly. Not sure if I should be so apprehensive about it bouncing from Reverb in Texas to Guitar Center in Maryland for $2,000 less.
    I've been trying to work out in my head how this could have happened. The only explanation I come up with is someone bought it on reverb and realized something wasn't right, and then sold it to Guitar Center and cut their losses. Even then, however, what could possibly lower the value of the guitar this much? Any ideas on what to look for if I go through with this?
  5. bossaddict
    6,293
    7,956
    Apr 4, 2013
    My guess is that the person who got it from the Texas owner didn't pay anywhere near $5K.
    If GC can confirm the Pat sticker pickups (sounds like they have) and maybe black light it to look for repairs, I don't see too much to worry about that you haven't mentioned.
  6. tonewheelz
    9
    7
    Feb 16, 2016
    Thanks guys! Does anyone have any recommendation for a top notch appraisal or luthier in San Francisco that will be able to spot the smallest detail that's out of place?
  7. LPSGME
    LPSGME Senior Member
    3,785
    3,019
    Oct 1, 2008
    The knobs should be top hats not reflectors, and that pickguard doesn't look original to me - shouldn't it have more layers? If the tuners aren't stock then it looks to me like someone may have taken some of the parts off to sell as vintage. So I would wonder if the T-tops are still in there and check before buying. Otherwise a '67 SG is a sweet guitar.I have 50's PAF in my '68 and it sings.
  8. bossaddict
    6,293
    7,956
    Apr 4, 2013
    A '67 should have either reflectors (earlier) or witch hats (later) - definitely not top hats.
    EDIT: maybe you meant witch hats when you said top hats?
  9. LPSGME
    3,785
    3,019
    Oct 1, 2008
    Doh! witch. At least I got the 'hat' part right. :D
  10. Greg's Guitars
    Greg's Guitars Senior Member
    5,353
    2,817
    Feb 11, 2009
    You should check the pot codes and pull the pickups for inspection yourself,order the nifty handheld LED blacklight flashlight from amazon to further your inspection,then your not "relying" on someone else's "word"....
  11. tonewheelz
    9
    7
    Feb 16, 2016
    I thought I'd give you guys an update. The rep finally got back to me with some close-up photos of the frets, and the back of the pickups and the pots. Do the frets look original? Either some of the nibs broke off, or whoever refretted it went to town and didn't care lol
    I can't really read part of the pot code numbers that I'd be familiar with. Are the pots original? The parts that read 137XXXX are covered. It looks like the other part of the pots read CBA 811 1053. Is that a period correct part number?
    https://www.dropbox.com/sh/bpm37zpcm9zuk48/AADB0OJL4ddriDCPq4kT0H5Pa?dl=0
  12. bossaddict
    6,293
    7,956
    Apr 4, 2013
    I think I see 1376XXX on the neck volume pot and I could be convinced that the first X is a 7. The frets look OK to me in terms of nibs/originality.
  13. reedy
    reedy Senior Member
    1,048
    616
    Nov 13, 2010
    Doesn't Guitar Center have a pretty decent return policy? If so, when you go to pick it up and check it out, if you think there are issues you don't have to take it. Right?
  14. tonewheelz
    9
    7
    Feb 16, 2016
    You're correct! As in the original post, the quandary was this: Does the reward of scoring a 1967 Gibson SG Standard at $2999 outweigh the risk of losing what I end up paying for the cost of shipping & appraisal?
    It looks like, despite the questionable circumstances, and barring any type of cracks or repair jobs, I've minimized the risk enough where it actually might be worth it.
    I think I'm gonna pull the trigger purchase it to have it sent here and get it appraised.
  15. tonewheelz
    9
    7
    Feb 16, 2016
    So, the guitar arrived this evening.
    Good news is there doesn't appear to be any repairs, breaks, or cracks in the body, neck, or headstock. I went over it with a black light, and the whole thing lit up, including the knobs. So, either the guitar was refinished/repaired a long time ago, or it's simply never been repaired/broken. I also took a closer look at the pots, and although most of the date codes are covered by sodder, I did manage to see the year on at least 2 pots. One reads 13766XX, and the other reads 137664X. So the pots were definitely 1966. This guitar is most likely a very early 1967, or an extremely late 1966. Accoring to the Gibson serial # article the 005300 dates it to 1967, though.
    Now the bad. Some moron before me used an unoriginal bolt/screw that was too long to affix the vibrola arm to the maestro vibrola. The result is it bored a small shallow hole into the finish of the guitar. Deep enough to reveal some wood. Not a deal breaker for me.
    Other than that, the frets are speed bumps. I can't tell if they're worn down, or if it's just vintage fretwire like on my Custom Shop 68 Strat. The bridge was adjusted perfectly, but I had a hell of a time bending in the middle frets. So I adjusted the truss rod relief to add a slight underbow. Now I can dig in under the strings in all parts of the fretboard.
    I've attached some pics of the things I mentioned. Overall, I honestly love it. The nut width, neck profile, the sound of the pickups, are all exactly what I wanted. Unless the people at Gryphon strings find something glaring...I'm keeping this baby.
    Also, here is an original song I recorded tonight with the SG, Highway 1 Fender P-Bass, and EZ Drummer. It's the SG > Dirty Little Secret MK II > OCD v4 > MXR 108 Fuzz > MXR M169 Carbon Copy > 1967 original stock Super Reverb
    https://www.youtube.com/watch?v=JtJbvhir1zI
    2 people like this.
  16. ThinLizzy
    ThinLizzy Senior Member
    523
    545
    Feb 25, 2008
    The guitar is sweet but that song is freakin' awesome! You need to put an album together.
  17. tonewheelz
    9
    7
    Feb 16, 2016
    ThinLizzy, you're far too kind lol. If you listen to any of the other songs on my YouTube account, you'll see that most of my music is all over the place. Not sure it's focused enough for any album.
    So I suppose it's safe to say that the book is closed on the deal. I had the guitar appraised at Gryphon Strings, and they confirmed that the nuts, frets, pickups, pots, etc are original. No breaks or cracks, and estimated its value at about $4500. They did say the fret were pretty worn, but didn't suggest refretting it if I don't have a problem with it. Thus far, it's not a problem for me. I've been putting it through the paces with long bends and haven't had any issues so far.
    I also visited a local ebay seller of vintage guitar parts and got old kluson tuners installed. Once I got the correct vibrola screw, she'll pretty much be period correct parts on all fronts.
    Here's a clip I made trying some big bends. I tried keeping a long one at about 44 seconds.
    https://www.dropbox.com/s/czgplwmv5x7gtyy/sg.mp3?dl=0
    Thanks to everyone for your advice with this purchase. I've been dreaming about this guitar for a long time now. So glad the search is over.
    2 people like this.
  18. bossaddict
    6,293
    7,956
    Apr 4, 2013
    Congrats on a great score!
    Nice track as well. Thanks for sharing. Sounds great!
  19. Crotch
    Crotch Support MLP Veterans & Vendors Double Platinum Supporter Premium Member
    11,200
    15,084
    Jan 13, 2012
    Looks great. Nice score. Put up some full body shots of that beast!
    Pretty sure I had a full blown flashback while listening to your song. Very cool.
  20. tonewheelz
    9
    7
    Feb 16, 2016
    That's hilarious, Crotch.
    I don't think I could have taken any better pictures than one of the previous owners, so I'll post those here lol. (these aren't my records...I wish!)
    3 people like this.
