Ideas For Amp Isolation Cabinet Needed
Discussion in 'Recording Studio' started by jeff_farkas, Jun 6, 2017.
  1. jeff_farkas
    jeff_farkas Senior Member
    32,790
    21,255
    Nov 1, 2008
    I just got a mic for my amp and I found that I need to crank up the volume rather loud to get a good signal to my recording USB/Software.
    My issue is that I live in a duplex and I don't want to get my neighbor pissed off at me so what can I do to isolate the amp so I can crank it up and not bother her.
    I've seen plans for amp cabinets but I don't have any tools to build one.
    So,, and ideas on how to get the job done?
    1 Would facing the amp toward the corner of a room help?
    2 Or how about covering the amp/mic with heavy commutators do any good?
    TIA, as usual
    Jeff :confused:
  2. Freddy G
    Freddy G V.I.P. Member
    10,818
    21,853
    Mar 18, 2007
    Hey Jeff,
    Rather than turning the amp up....turn the gain on the mic pre up.
    northernguitarguy likes this.
  3. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
    I spoke with my teacher and he said it's likely the mic that's bad.
    I'll send it back and try another one.
  4. northernguitarguy
    northernguitarguy SWeAT hOg
    27,470
    44,705
    Feb 22, 2009
    I've been using a H&K Redbox 5 DI for patching into the board when we play live. Sounds great on a recording, as well. It is not the sound of my cab to a tee, but it sounds pretty damn good to my ears.
    This was recorded with moderate volume, certainly nothing to shake through the walls.
    https://soundcloud.com/northernguitarguy/morning-sunshine-turns-to-rain
    jeff_farkas likes this.
  5. ehb
    ehb Chief Discombobulator Premium Member
    24,392
    112,712
    Feb 20, 2013
    Big thick foam pad to sit it on and a refrigerator box over it? ;)
  6. kfowler8
    kfowler8 Senior Member
    4,952
    4,772
    Mar 1, 2011
    There are lots of option but none are cheap if you want it to sound good. Off the top of my head:
    - Two Notes Torpedo Live. I absolutely love this thing. Load box with speaker/cabinet/mic sim. Maintains the character of your guitar and amp. $1,000
    - Rivera Silent Sister. It's a ported ISO cab. Gives you about 15dbs of reduction. I could crank my 50 watt Marshall and still have a conversation over it. With the port you won't get that boxy sound other ISO cabs suffer from. $1,000 with speaker. I've built these for $250 w/o speaker. They really do work well.
  7. Elkoki
    Elkoki Senior Member
    436
    124
    Mar 4, 2015
    put it in the closet and crank it the fuck up
  8. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,143
    182,443
    Nov 28, 2010
    Back when I was doing home recording in an apartment, I'd load my amp in the closet and record it there. Close-mic it, you'll still get a hot sound, but the hanging clothes will still do a good bit to kill the roar. As an added benefit, it was also quieter as heard by the mic -- no ambient noise.
  9. TheDevice
    TheDevice Senior Member
    677
    890
    Sep 24, 2011
    Yeah, I live in a triplex and I've figured out a pretty good dial-able silent recording rig using stuff I already had pretty much. I stuck my Mesa 1x12 in a old road case with two mics - a condenser and a dynamic and filled it with foam. The speaker out from the head is going into a THD Hotplate I got used on CL, it allows me to dial in the volume and pull a direct line. I track with three channels; my condenser, my dynamic and my direct signal. I blend them to taste during mix. Pretty much allows me to record 24/7 although I really like it with an external loudness of 80db measured (45 watt head with master on 9 and a 16db attenuation on the THD).
    All of these tracks have been recorded with that chain:
    https://soundcloud.com/sonny-king-rock-guitar
  10. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
    Thanks for the input.
    I sent back the mic. My teacher thinks that it was defective since it should have been far more sensitive and picked up the signal better than it did.
    My plan is to get the H&K Redbox 5 DI. That looks like the best thing I can get for what I want to do.
    Again.. thanks!!
    Jeff
  11. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
    Getting this tomorrow!!
  12. northernguitarguy
    27,470
    44,705
    Feb 22, 2009
    Right on, Jeffy. Lemmy know if you have any questions about using it.
  13. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
    I'll let you know and thanks for the recommendation. My teacher agrees with it totally!
  14. C_Becker
    C_Becker Dat Gibson smell
    1,870
    1,753
    Jul 7, 2015
    Frogfur and jeff_farkas like this.
  15. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
    Got the Red Box yesterday and it works perfect. Really glad I got it!!
  16. northernguitarguy
    27,470
    44,705
    Feb 22, 2009
    That's great, Jeff! Best recording advice I can offeris to keep the level in 'the green'. I look forward to hearing a clip, when you're ready.
  17. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
  18. jeff_farkas
    32,790
    21,255
    Nov 1, 2008
  19. northernguitarguy
    27,470
    44,705
    Feb 22, 2009
    Sounding clean, you got it figured out! Have fun with it.
  20. nitrodave08
    nitrodave08 Senior Member
    1,823
    1,839
    Sep 29, 2013
    A few bands use the Palmer PDI-03 speaker simulator, abit pricy but you can crank the amp and drop it into a small mixer. It combines load impedance, a signal splitter and DI box especially designed for guitars.
