Humbucker Rings
Discussion in 'Epiphone Les Pauls' started by Andrew J Betry, Sep 5, 2017.
  1. Andrew J Betry
    Andrew J Betry Junior Member
    13
    0
    Jul 9, 2017
    I am looking to replace the plastic trim rings that surround the humbuckers on my 3-pup Black Beauty and I need some help.
    All I see available are singles and two packs (Short/neck position and the tall/bridge position) Do I need to buy 2, two packs to get the three i need?
    and do I use 2 short ones for the neck and middle postion? They do look the same.
    How do I know if I need "Curved", "Angled", or what? I want to get it right.
    Thank you in advance for all the help
    -AB
  2. Who
    17,490
    33,080
    Mar 15, 2012
    Buy two sets.
    Compare what you receive to what you have now. Don't pay extra for "curved". The curves probably don't match your guitar, anyway.
  3. 61LPSG
    61LPSG Senior Member
    1,704
    467
    Oct 31, 2007
    Andrew, welcome to MLP:welcome:
    My guess is 2 short and 1 tall. All the Epis I've had/seen used curved rings.
    One thing you need to be aware of is that Epis use metric hardware and rings. They are slightly different than US (Imperial) parts. The holes will be larger for the metric screws. The dimensions and hole spacing will also be a bit different.
    I'm sure Paruwi will pop in to give you a definite answer.
    Good luck.
    Andrew J Betry and Who like this.
  4. 61LPSG
    1,704
    467
    Oct 31, 2007
    Who beat me to it.
    Andrew J Betry likes this.
  5. Who
    17,490
    33,080
    Mar 15, 2012
    This is critical, and bears repeating.
    If you hope to reuse the existing holes in the wood (of course you do), you want proper rings, and not Gibson rings.
  6. Who
    17,490
    33,080
    Mar 15, 2012
    I realize who is in this video, so I will give him a break.
    That said. 3:00 to 3:07 is scary, looking at the free-end of that scraper! :wow:
  7. Who
    17,490
    33,080
    Mar 15, 2012
    Also, since you're taking such an interest in working on your guitar, I can't recommend this highly enough.
    https://www.amazon.com/dp/0879309210/?tag=mylespaul04-20
    Excellent book, worth reading cover-to-cover, even if you don't intend to do the work that's being discussed in each section.
    fumblefinger likes this.
  8. pbekkerh
    pbekkerh Senior Member
    160
    104
    Mar 17, 2015
    Why are you replacing the rings?
    When I tried to find a replacement for the nicotine/urine coloured plasticrings on mine, I couldn't find any that suited, so I ended up spraypainting them half matte black and it looks really good and original.
  9. Andrew J Betry
    13
    0
    Jul 9, 2017
    ...I got a little sloppy with a dremel :(
  10. Andrew J Betry
    13
    0
    Jul 9, 2017
    awesome!! Thanks
