How to Use the Controls on a Les Paul
Discussion in 'Tonefreaks' started by Splattle101, Jun 12, 2009.
  1. matonanjin
    matonanjin Member
    38
    25
    May 30, 2012
    I must agree.:applause:
  2. P A U L
    P A U L Member
    83
    26
    Aug 30, 2015
    Just ran across this and what a pleasure to read info that someone has it right.
    The whole magic thing about the LP is the tone and volume control and mix.
    Billy Gibbons once said, "you are never going to know what real tone is until you start messing with the volume and tone controls on the guitar".
    One of Hendrix's clean sound tricks was to roll off the guitar volume with his fuzz face on and it enhanced his clean tones, crank up the volume when away from the pedal and presto fuzz. I can't believe for years I had Strat knobs on 10, I guess that is a newbie's thing as it took me a long time to start using them.
    The LP is truly a touch of heaven for the experienced player. Thank you Gibson and Les!
    1 person likes this.
  3. flannelflag
    flannelflag Senior Member
    513
    835
    Feb 13, 2016
    I have a question/problem with my volume control on a 2016 T. I'm not sure I can even explain it but here goes. When I'm set middle position, the only volume control I get is with my bridge volume knob. BUT, and here's the part I don't get, If I have my bridge turned down and my neck turned up, my volume does increase when I switch from bridge to middle setting. With my bridge turned all the way down though, I can crank my neck pickup to full volume and still get nothing on my middle setting. When I switch to just the neck pickup though, the neck volume control functions as it should. This is my first LP so I'm not sure if I'm simply misunderstanding my controls or if I have an issue with my wiring/electronics. I hope this explanation makes sense to somebody because I'm baffled.
  4. Splattle101
    Splattle101 V.I.P. Member
    8,636
    4,134
    May 30, 2008
    I'm not entirely certain what you're describing but it doesn't sound quite right to me. There are two common, conventional ways for a Les Paul to be wired: vintage and modern. They behave differently on the middle position.
    With vintage, if you put the pickup selector in the middle position, and you turn either volume to zero, the guitar volume should drop to zero. Turn either volume all the way off, and you've turned the guitar off.
    With 'modern', if you try the above, your sound should change and lose treble, but the guitar will remain on. You'll still have sound (a very distinctive and odd sound, but sound nevertheless).
  5. flannelflag
    513
    835
    Feb 13, 2016
    The "vintage" wiring is exactly what it's doing. I just explained it poorly. Sometimes I don't translate well to the written word which would be funny, if English weren't my first language. :) I've learned over the past couple days that with a little tinkering with knobs n switches, I can get an awful nice transition from loud to soft with just a quick flip from bridge to middle. Thanks for the explanation, Splattle.
  6. QReuCk
    QReuCk Senior Member
    303
    120
    Jun 20, 2013
    I would not call that vintage vs modern. What your describe is just the effect of having volume pots wired as a voltage dividers (what you call vintage) vs reversed (what you call modern). To my understanding, all Gibson Les Pauls have volume pots wired as voltage dividers from stock. The reversed volume pots are sometimes refered to as "indonesian wiring". I had it stock in a Greg Bennett AV6. Unfortunately, what it does to your tone when rolling off volume is not only decreasing the output, but also lowering the load impedance of your pickups, removing from them any sort of resonant peak there might be, which IMO translates pretty well into removing all the life from the sound.
    By the way, although this is kind of related to the topic of maximizing the usage of the controls of the guitar, this topic is better adressed in a thread about the relative merits of wiring schemes than in this one I think.
  7. valvestate
    valvestate Member
    48
    28
    Jan 25, 2016
    It's 2016 and this post is still very very helpful! As a new user of LP guitars, this opened up a lot of spectrum of sounds!
    Thanks a lot @Splattle101!! :thumb::fingersx:
  8. Splattle101
    8,636
    4,134
    May 30, 2008
    You're most welcome, sir! Glad it's been of use to you. :thumb:
  9. kmasters68
    kmasters68 Senior Member
    1,317
    345
    Aug 6, 2015
    OK, like my input even matters at this point with this mega thread. I tried this last night. The tube amp I was using is a monster tone machine and it helped a lot, but I'm sure it will work similarly in a big rig.
    LP middle position>boost>tube amp.
    1) Bring the amp to break up not past.
    2) Engage a good boost pedal (you should have screaming guitar tone at this point)
    3) Roll neck to 7.5 or so
    4) Roll bridge to 5 or so
    5) Ride the treble tone knob to taste.
    I tried this with a LPC 68 and a 2008 STD. What I got was vintage tone like I couldn't believe. Plenty of headroom and note clarity. I enjoyed flipping to the neck for boosted soloing or leaving it in middle position and turning up the bridge volume. I didn't use the bridge alone at all. When going from an authentic vintage tone to the high gain attack of the neck or rolled on bridge in middle has authority! Then back into the vintage mode.
    I've always thought that rolling the volume "takes away".
    NOT ANYMORE!
  10. texas special
    texas special Junior Member
    24
    3
    Mar 26, 2016
    Many thanks, very useful post.:applause:
    Splattle101 likes this.
  11. barchiola
    barchiola Senior Member
    266
    101
    Dec 11, 2008
    Great post, thanks!
  12. SoCal Flood
    SoCal Flood Silver Supporter
    209
    353
    Aug 3, 2017
    Amazingly helpful thread, thanks!
  13. gitapik
    gitapik Member
    46
    20
    Nov 13, 2017
    Excellent, excellent post, Splattle101. Cheers! :cheers:
  14. hopeyeu
    hopeyeu Junior Member
    4
    0
    May 7, 2018
    Excellent tips cheers Splattle :)
  15. Classicplayer
    Classicplayer Senior Member
    2,235
    1,181
    Sep 6, 2007
    I've read and re-read the original posting and comments several times and still believe it to be the most practical and helpful writeup on dialing in a Les Paul that I have ever seen on a forum about Lesters.
    I can't say I end up with the same exact settings as the OP detailed, but my own settings are in the spirit of the elements detailed in Spattle's original thesis.
    Using his template, I find I can apply it to my Les Pauls and it makes little difference with any amp. His post also reveals that it may involve some minor tweaking of the amp itself; which I discovered usually is the case with me...because there is a certain idea I always carry in my mind of just how I want my Les Paul to sound when I use my tube amp.
    Classicplayer
    Thumpalumpacus likes this.
