How to Use the Controls on a Les Paul
Discussion in 'Tonefreaks' started by Splattle101, Jun 12, 2009.
  1. Smylie
    Smylie Junior Member
    24
    16
    Feb 13, 2012
    All I can say is WOW.... Tweeted this vid out..... It's awesome!
    1 person likes this.
  2. 1981 LPC
    1981 LPC Senior Member
    2,109
    1,417
    Dec 8, 2010
    Another good one:
    [ame=http://www.youtube.com/watch?v=YUdq59CRcxk]Single-pickup guitar review round-up: modern electrics vs 1957 Gibson Les Paul Junior - YouTube[/ame]
  3. Splattle101
    Splattle101 V.I.P. Member
    8,635
    4,127
    May 30, 2008
  4. Guitar Garage
    Guitar Garage Senior Member
    219
    62
    Feb 8, 2014
    What a great thread thank you for posting this!! I love the playing example videos as well.
  5. MrMountainHop
    MrMountainHop Member
    96
    121
    May 28, 2014
    Very well put. Thought it was worth repeating!
    Thanks for the great post.
    steveb63 likes this.
  6. GitFiddle
    GitFiddle Senior Member
    10,845
    13,332
    Jun 2, 2010
    Thought Joe B. did an excellent job on the same subject.
    [ame="http://www.youtube.com/watch?v=ZkGCvLstPrE"]https://www.youtube.com/watch?v=ZkGCvLstPrE[/ame]
    3 people like this.
  7. xrr
    xrr Senior Member
    140
    69
    Apr 16, 2014
    wow that's a nice tutorial !! I need to experiment with this...
    But it makes me think that it's not robotic tuners that I'd like on my LP...
  8. knucklebut
    knucklebut Member
    42
    28
    Dec 2, 2013
  9. Splattle101
    8,635
    4,127
    May 30, 2008
    I find it works for Fenders, Marshalls, Vox, Orange, what have you. If it's not working for you with a Mesa then...try something different. :D
  10. iakbil
    iakbil Junior Member
    27
    7
    May 23, 2014
    This is a great thread! Thank you so much Splattle101 :) I am learning something every day on MLP :)
  11. Bill Hicklin
    Bill Hicklin Senior Member
    7,350
    9,709
    Nov 3, 2014
    Anyone have similar suggestions for a master-tone axe like an Explorer or Vee?
  12. Splattle101
    8,635
    4,127
    May 30, 2008
    As a general rule, from the guitar you can always cut treble. You can't add it.
    So if the amp isn't set bright enough for what you need, you can't do anything about that from the guitar. You'd have to readjust the amp.
    But if the amp is set too bright for what you want, you can cut the treble by turning down the tone control.
    So if it were me, I'd set the amp so the darkest sound from the guitar sounds good. That means adjusting the amp to suit the neck pickup. When you go to the bridge you can turn the tone down if you need to.
  13. garybaldy
    garybaldy Senior Member
    1,669
    815
    Apr 10, 2011
    I always start with all controls on guitar set at approx 6 to 7 (and vol pedal backed off a bit). You can add or cut anything then. Why does everyone start from dimed? This is an incredibly long thread for something so simple.
  14. Otto tune
    Otto tune Senior Member
    2,325
    1,811
    Jul 19, 2014
    Too much to comprehend all at once, so I did a Copy/Paste to a document. I need to sit down and try stuff one at a time.
    Thanks.
  15. Bottleneck
    Bottleneck Senior Member
    640
    782
    Dec 2, 2010
    and another:
  16. Stoneburst
    Stoneburst Member
    93
    89
    Oct 18, 2014
    +1. JD Simo is the best old school Les Paul player around now, bar none, and probably the best guitarist of my generation. His tone, touch, technique and overall command of the instrument are just insane, and his joyful reverence for the music that inspired him comes across in every note he plays.
  17. tdarian
    tdarian Senior Member
    1,354
    1,148
    Mar 8, 2011
    Where do you guys end up with your Tones numerically on the dial?
    I usually have the Neck Tone rolled back to #8, or "Off" for The Woman Tone.
    I usually have the Bridge Tone no higher than #6.5, but it is often down around #4.
    Volumes are all over the map, usually always under #10 with an amp set to clean up or get angry via those controls.
    I've got a set of WIZZ PAFs, a MSSC wiring set-up with the Russian caps all of which I find way more responsive than what was stock in 2011.
    After you set up yours by ear how do the numbers look?
  18. Splattle101
    8,635
    4,127
    May 30, 2008
    With a given amp at given settings, the actual control positions vary widely from guitar to guitar, depending on the taper of the pots and the pickups. But it also varies widely with different amp settings.
    For example, I might turn up the guitar to 10, then turn up the amp until it JUST crunches when I hit a big chord. At those settings, a little nudge of the vol control will produce a clean sound. But if I crank the amp then I might have to turn the guitar down to 2 to get a really clean sound.
    It all depends, and I am always adjusting the amp by ear, just like I tune by ear even if I'm using a tuner. That's because I don't care if the machine tells me it's in tune; if my ear tells me it's out of tune then it is! I don't play for the benefit of the machine. It's the same with the amp and guitar settings. I don't turn down to 5 and insist it's clean if it isn't. :D
  19. MG-10
    MG-10 Member
    87
    21
    Jun 29, 2014
    Thanks! Great info.
  20. nedcronin
    nedcronin Senior Member
    378
    275
    Jun 7, 2011
    This is pretty much the best thread ever!
