How to repair neck binding on '55 Les Paul?
Discussion in 'Vintage Les Pauls' started by jdmp, Nov 25, 2017.
  1. jdmp
    jdmp Member
    68
    67
    Nov 24, 2015
    I'm in Sydney Australia. I know luthiers that I trust for setups...nobody that I would trust for this...
  2. jimi55lp
    jimi55lp Senior Member
    1,964
    286
    Mar 24, 2007
    Acetone is what is used to attach the binding and it will hold and also melt the crack seams to blend. I'm not sure if nail polish remover will work since most I've seen are mild or toned down acetone content. Just mask off well and place fret board facing down to prevent drips from reaching neck finish. You just want to dampen the backside of the binding piece and along with the crack edges and quickly place it against the fret board for application holding it until set. The crack seam edges can be melted to the other binding by dipping a razor blade edge into acetone and quickly putting it in between the two pieces makeing it melt or dissolve together. It happens very fast and sets fast also. I've repaired many cracks in jack plates this way. The crack between the neck lacquer and the binding can be drop filed with lacquer not acetone!
    Blue Blood, pinefd and Sharky like this.
  3. jdmp
    jdmp Member
    68
    67
    Nov 24, 2015
    It took a long time, but I finally got this done. I decided to use Jeff Mallia here in Sydney based on some recommendations. I contacted him before Christmas and he was about to shut down shop for a while so I put it off til Jan. I got it to him in mid/late Feb and it took him about 4 weeks. Like a lot of little workshops, you have to be patient. Before I picked up the guitar he told me the cost was $275 but that included a fret crown and setup.
    Before I got the guitar I was a little grumpy. The whole process took ages, and I was being charged alot of money to stick a bit of binding on. When I got the guitar however, I thought the whole project was worth it. The set up was great and was completely worth the extra money. That guitar wasn't at the top of my list before, but now it fully holds it own against all my other guitars. The right setup can really make a difference.
    So, it took ages, cost a lot, but I can totally recommend Jeff Mallia for great luthier work in Sydney. Thanks Jeff!
    RAG7890, Blue Blood, Becker34 and 2 others like this.
  4. jimi55lp
    1,964
    286
    Mar 24, 2007
    I'm so glad you got it to a pro and all turned out well! I just wanted to give detailed instructions to your questioning "how to reattach a piece of binding". These repairs are not for everyone but pure acetone is the method most knowing luthiers would use to make this repair on a vintage 50s LP binding, guards, and jack plates. I don't believe you'll find glue residue under neck binding on these vintage models unless someone has been experimenting or re engineering.
    Blue Blood likes this.
  5. DrSte31n
    DrSte31n Senior Member
    170
    171
    Oct 4, 2016
    Where are them pictures? :p
    yamariv likes this.
  6. yamariv
    yamariv Senior Member
    1,330
    655
    Jul 26, 2015
    PICS!! PICS!! :facepalm:;)
  7. Greco
    Greco Senior Member
    5,485
    8,095
    Aug 30, 2007
    I think you did the right thing if you weren't confident. Although you're right it does seem expensive. FYI acetone from Bunnings will do the job. It'll stick binding to wood and also will re-attach broken bits by melting them together. However, it's important that the binding breaks are cleaned of any brown rosewood/acetone/glue residue otherwise you end up with an obvious join line. Also the binding on necks is so thin (and also this is super old) so it can easily start falling apart if it comes into contact with acetone. Not to mention you need to protect the inlays, finish, and hopefully he did a finish touch up for you if it needed it.
  8. jdmp
    jdmp Member
    68
    67
    Nov 24, 2015
    I just saw the requests for pics. Not alot to show really. Here is another pic of the binding problem...
    Here is a pic of the repair. I've circled the ends of the broken section. You can barely see them. Pretty good work, but it is the set up which really won the day for this job.
    RevWillie, tigger, RAG7890 and 3 others like this.
  9. yamariv
    1,330
    655
    Jul 26, 2015
    Looks sweet! Congrats on the fix and the setup, I think the cost will be worth it in the long run
  10. Thrill
    Thrill Senior Member
    1,150
    745
    Dec 12, 2013
    Nice. Glad you ended up going to a pro, and you picked a good one cause he did a really good job. Just starting reading this thread and seeing you say you were getting acetone and doin it yourself, I thought, damn, this guys got balls of steel lol.
    If it was a normal modern guitar, Id do it myself. But on an original 50s Les Paul? Not a chance. I remember the first time I did binding on a guitar, and trying to match ends using acetone or some binding melted into acetone as a glue, and it turned into a damn mess. I felt bad enough doing it on a cheap $200 Ibanez, I might have jumped off a bridge if it was a $50000 LP.
  11. RAG7890
    RAG7890 Premium Member
    13,945
    21,716
    Jul 11, 2010
    Firstly, I’m also glad you had a Pro do this job.
    Secondly, I don’t understand the $275 comment because, in actual fact, you’re paying for a specific skill level to do the job correctly, along with a set up etc.
    Frankly I’d call that a relatively low price. In USD that amounts to ~ $211 which isn’t much for a Guitar like this.
    Great outcome IMHO. :)
    :cheers2:
    yamariv likes this.
  12. yamariv
    1,330
    655
    Jul 26, 2015
    I agree, you should see the price I just payed for a refret here in Canada..
  13. sws1
    sws1 V.I.P. Member
    710
    735
    Jan 10, 2015
    Did he relacquer the neck? The 2nd picture has alot of yellow up and down the neck. Not so much before. Could be the angle/lighting.
  14. jdmp
    jdmp Member
    68
    67
    Nov 24, 2015
    He did a little overspray around the repair. The colour difference between the photos is just lighting and a different phone/camera.
