How to repair neck binding on '55 Les Paul?
Discussion in 'Vintage Les Pauls' started by jdmp, Nov 25, 2017.
  1. jdmp
    jdmp Member
    74
    69
    Nov 24, 2015
    I was playing my '55 Lester last week and a chunk of the neck binding fell off. It's a Dave Johnson refin that I bought from Marks Guitar Loft a few years ago. It had been refretted but Mark had gone to some effort to preserve the binding and nibs. What do you guys suggest for re-attaching the binding? Some photos below, including a photo of the full guitar for your viewing pleasure!
    Blue Blood likes this.
  2. RAG7890
    RAG7890 Premium Member
    14,653
    23,298
    Jul 11, 2010
  3. Sharky
    Sharky Senior Member
    4,990
    4,305
    Jan 19, 2012
  4. Jumping@shadows
    Jumping@shadows V.I.P. Member
    1,292
    2,111
    Sep 15, 2012
    A touch of super glue and some masking tape and you’re good :)
    deadlyweasel likes this.
  5. sk8rat
    sk8rat Senior Member
    10,091
    12,887
    Sep 28, 2014
  6. tigger
    tigger Senior Member
    415
    461
    May 6, 2017
    The correct glue is, I believe, Duco cement or similar, slightly diluted with acetone.
  7. jdmp
    jdmp Member
    74
    69
    Nov 24, 2015
    I'm going with the premierguitar.com article. Have ordered some Titebond 2. Should be gluing later in the week. Thanks everyone.
    Thumpalumpacus likes this.
  8. tigger
    415
    461
    May 6, 2017
    Note that your binding is celluloid, while the binding in the article is normal ABS. Celluloid cement with acetone will actually melt the ends and merge them together.
    IGRocker, sws1 and RAG7890 like this.
  9. Left Paw
    Left Paw Senior Member
    4,056
    2,451
    Dec 29, 2013
    When in doubt about your ability to do this well, have a pro look at it.
    The_Nuge, jerry47 and RAG7890 like this.
  10. jimi55lp
    jimi55lp Senior Member
    1,966
    287
    Mar 24, 2007
    Clean the edge of fret board, neck side and back of binding piece and mask off edges well then dampen the binding back with acetone and quickly set it in place with a strap or clamp until dried. It will only take a couple of minutes to set. You can seal the cracks on each end the same way by dipping a razor blade or pin in acetone to apply in the crack. Again you should mask the neck and fret board very carefully to protect them.
  11. Leña_Costoso
    Leña_Costoso Senior Member
    734
    692
    Aug 28, 2017
    ditto acetone to melt binding into itself - works great
  12. jdmp
    jdmp Member
    74
    69
    Nov 24, 2015
    Acetone it is. Will give it a shot today. Wish me luck guys!
    pinefd likes this.
  13. pinefd
    pinefd V.I.P. Member Premium Member V.I.P. Member
    9,214
    13,643
    Mar 23, 2007
    I think that’s the right approach, but just make sure you’re extremely careful, since acetone will eat into lacquer, and can make a mess out of the binding itself if you’re not careful. So, mask everything off real well. And best of luck!
    Frank
    RevWillie and Sharky like this.
  14. jimi55lp
    1,966
    287
    Mar 24, 2007
    Be extremely careful!
  15. jdmp
    jdmp Member
    74
    69
    Nov 24, 2015
    Still haven't done this...might give it a try this weekend. For the acetone application, I was going to dip a cotton bud then just one quick wipe on the back of the binding. Is that enough? Also, was going to use fingernail polish remover as acetone. Is that OK, or should I find some hard core acetone solvent at a chem supplier?
    Finally, is the blue painters tape good enough for masking?
  16. Sharky
    4,990
    4,305
    Jan 19, 2012
    in Germany fingernail polish remover is free of acetone
  17. tigger
    415
    461
    May 6, 2017
    Honestly I don't think acetone alone will keep it in place. I would get duco cement, dilute it with acetone a little, put small amount on the fretboard side and the broken binding ends, set in place. Then carefully smear the break lines with acetone to try to make the surface melt together.
  18. RAG7890
    14,653
    23,298
    Jul 11, 2010
    Since it’s a Vintage Guitar I’d get it done professionally, unless...........
    :cheers2:
    2manyGuitars and IGRocker like this.
  19. d1m1
    d1m1 Senior Member
    2,359
    2,553
    Oct 30, 2012
    tried to contact spirit healer or a homoeopath? it works :laugh2:
  20. yamariv
    yamariv Senior Member
    1,402
    716
    Jul 26, 2015
    For that guitar OP why don't you just take it to a Luthier?? They would do this day in and day out, their experience alone would be worth the $100 or so they may charge..
    RevWillie and RAG7890 like this.
