How To Measure Pickup DC Resistance
Discussion in 'Pickups' started by matt@msscguitar, Feb 12, 2014.
  1. C_Becker
    C_Becker Dat Gibson smell
    1,943
    1,856
    Jul 7, 2015
    Compared to the 8 or more kOhm of the pickup, the resistance of the wire is very, very small. The wire is probably below 1 Ohm resistance, so you can ignore that.
    1 person likes this.
  2. oildrops
    oildrops Junior Member
    8
    0
    Jul 14, 2015
    I just installed new pots and pickups. The neck sounds full output, but the SD SH-5 in the bridge sounds like it's not getting the full output. I measure 13.5k for the SH-5 (duncan states Bridge: 14.1 k). Could there be a short somewhere, or does this seem normal? Could there be a grounding issue somewhere and still get the correct resistance reading?
  3. matt@msscguitar
    matt@msscguitar V.I.P. Member
    9,652
    6,505
    May 5, 2008
    Could be an issue with the switch, but if possible, post a pic of the electronics cavity so we can see if anything looks suspect.
    Also, the difference from 13.5K to 14.1K could be the temperature at the time of metering. That doesn't raise any flags with me at all.
  4. oildrops
    8
    0
    Jul 14, 2015
    I posted a pic in this thread http://www.mylespaul.com/forums/lut...nstalling-new-pots-could-use-some-advice.html, but posted in the luthier forum by accident. I just checked through all the wiring and tugged on every wire to check to cold joints. I unhooked the tone pot from the bridge pickup, which made no difference. I checked the lugs on the switch, and made sure they weren't touching. I re-soldered the pickup hot and ground, and the bent lugs on the pots. The only thing I can think of that I didn't check is where I grounded all the shielding together for the switch. I can't access it unless I de-solder everything because I didn't leave myself enough slack, so I was leaving that as a last resort.
  5. freefrog
    freefrog Senior Member
    1,242
    686
    May 21, 2011
    14.1k in parallel with two 500k pots (volume and tone) is supposed to become 13.347k.
    Here is a useful tool to check it if necessary: PARALLEL RESISTOR CALCULATOR
    So, if the SH5 has a problem of output, it's apparently not a question of grounding. :hmm:
  6. matt@msscguitar
    9,652
    6,505
    May 5, 2008
  7. Wraptail
    Wraptail Senior Member
    2,170
    1,427
    Jul 23, 2007
    Great point that isn't mentioned often.
  8. peanutavalon
    peanutavalon Senior Member
    509
    731
    Jul 2, 2010
    I just did my cc les paul bridge only using the already wired method..it read 7.77.
    Then I did my benchmark ro using the same method...it read 4.04. I realize the benchmark runs have the lower output E buckers but that is a substantial difference to me. The funny thing is the E buckers are just as loud and more articulate.....Any input on this one guys? thanks
    edit...never mind..someone suggested putting my cable in the guitar input...solved the problem and the pickups read 7.34.
