How to get solder off pots to read date?
Discussion in 'Gibson Les Pauls' started by Lightningflash, Jul 17, 2017.
  1. Lightningflash
    Lightningflash Senior Member
    1,005
    928
    Mar 30, 2013
    How do you safely get the solder off pots to read the date?
    I'm restoring a 75' Flying V and I got some pots that are supposed to be 1975 pots but can only verify one of them.
    Thanks!
  2. theroan
    theroan Senior Member
    349
    201
    Mar 25, 2009
    There are a few desoldering tools you choose from. There's a wick or braid that absorbs the excess solder or you can use a pump that will suck it away when it's liquefied.Of course this assumes you already own a soldering iron which would be essential no matter what you choose.
    dsmcl77 likes this.
  3. Donal
    Donal ¯\_(ツ)_/¯ Premium Member
    13,456
    13,071
    Aug 25, 2009
    Exactly this, simple and effective :thumb:
    dsmcl77 likes this.
  4. BrianB
    BrianB Senior Member
    3,466
    5,248
    Jun 20, 2012
    I've used something similar to this for years. Squeeze the bulb, heat the solder, solder flows, release the bulb, slurp.
  5. paco1976
    paco1976 Senior Member
    2,290
    1,645
    Oct 24, 2013
    A sponge will work as well. Desolder and the sponge will suck all the liquid.
  6. barchiola
    barchiola Senior Member
    266
    101
    Dec 11, 2008
    before you heat the solder to remove it, dab a little flux on the solder so it will flow more easily. this will make it easier to get more off in fewer tries. dip the desolder braid in flux before you try to use it, another way to have things go more easily.
  7. Dick Banks
    Dick Banks Senior Member
    467
    503
    Apr 27, 2017
    ..or, if you don't have any flux, but you have some LEADED solder, try adding some leaded solder to the existing (most-probably non-leaded) solder to get it to flow quickly. You can probably move it away from the engraved text you are trying to read. Wash your hands after using that leaded solder...
  8. Lightningflash
    1,005
    928
    Mar 30, 2013
    Will the solder pump suck the solder out of the serial # to make them legible?
  9. Donal
    13,456
    13,071
    Aug 25, 2009
    It definatly should, at least the slightly larger ones with a diamater of about 3/4 inch. When I learned soldering some 30 years ago we used to have to desolder components from the boards and it would take the solder out of the holes after the components were removed.
  10. Lightningflash
    1,005
    928
    Mar 30, 2013
    Ok, thanks guys. I have a solder pump on order from Amazon, wish me luck.
    Who likes this.
  11. skydog
    skydog Senior Member
    2,063
    769
    Oct 24, 2007
    You can wipe it away with a wet rag.
    Who likes this.
