How To Bias an Amplifier ??? and Why ???
Discussion in 'The Squawk Box' started by BOBBO, Mar 11, 2008.
  1. lexluthier
    lexluthier V.I.P. Member V.I.P. Member
    1,326
    347
    Jun 15, 2007
    I've had a Hunt Dabney Bias Probe (the original one) for nearly 20 years and it still works great. Need a meter if you get one of those, though.
    Some of the new bias meters that also measure plate voltages are real nice if you don't want to poke around the tube sockets with a meter to find out the plate voltages.
    Lately I've just been using the WeberVST bias calculator instead of doing the math.
    Weber Bias Calculator
  2. coldsteal2
    coldsteal2 V.I.P. Member
    37,066
    14,419
    Sep 6, 2007
  3. Soldano16
    Soldano16 Senior Member
    295
    6
    Nov 18, 2007
    I think you may be wrong. That could cost a life.
  4. twinrider1
    twinrider1 Senior Member
    3,080
    1,353
    Apr 29, 2007
    I went with Amp-Head and was very happy with my experience. Great instructions and well built. Quick shipping and packed to survive a UPS lunch-break soccer match.
    I bought the "Dual Bias Tester-MPD" which shows voltage too.
  5. LPV
    LPV Senior Member
    8,767
    4,568
    Sep 23, 2008
    It is wrong, but its also besides the point. You adjust the bias with the amp turned ON. You can get killed if you are ignorant to the dangers, or you just plain f*ck up.
    As a side note, if you swap tubes and you amp sounds the same and the tubes aren't glowing like 100w bulbs, your bias is probably not too far off
    . Look for harsher tone (over bias) and really hot tubes (under bias) as an indicator of improper bias.
    Amp techs are our friends.
