How To Beef Up Your Strat Tone A Simple Wiring Mod Tutorial
Discussion in 'Fender' started by ibanezcollector, Aug 19, 2012.
  1. RaSTuS26
    RaSTuS26 Senior Member
    3,064
    2,284
    Apr 16, 2011
    Best thing (rather than derailing this thread) would be to create a thread in the Intro section and just answer the well wishers as they come along.
    Introductions - MyLesPaul.com
  2. woodmusic
    woodmusic Junior Member
    12
    3
    Aug 16, 2013
    Yes, sorry, was just joking.
    Anyway, I hope there is more input here on this great Strat mod.
    Regards.
  3. Patugart
    Patugart Junior Member
    1
    0
    Nov 15, 2013
    Hello I have a fender S S H guitar can I do this mod?
    the mod works ith a pushpull pot for my guitar thanks a lot =)
  4. woodmusic
    12
    3
    Aug 16, 2013
    This is for single coil pickups, to make them sound like humbuckers.
    You already have a humbucker. If you want to do it just with the
    single coils pickups, there are some other mods.
    Here you have this mod and some others:
    SOME SERIES, PARALLEL, AND OUT OF PHASE SWITCHING TRICKS
    And here you have some mods for HSS guitars like yours:
    https://sites.google.com/site/phostenixwiringdiagrams/hss-guitars
    1 person likes this.
  5. Hipatch3
    Hipatch3 Junior Member
    6
    0
    Aug 8, 2009
    cant find this mod anywhere and your pics arent working..
  6. chasenblues
    chasenblues Senior Member
    19,000
    25,283
    Apr 2, 2007
    This is the picture of the back of the switch.
    This might be useful also common selector switch layouts.
  7. twst1up
    twst1up Senior Member
    4,087
    5,674
    Nov 30, 2010
    I've been wanting to drop an x2n in my strat....this might be an option to they first
  8. chasenblues
    19,000
    25,283
    Apr 2, 2007
    I tried to do the mod in the picture,But my hands shake and i couldn't solder on the back of the switch:(. don't let the pic fool you its a mini switch and its very cramped on the back.
  9. Hipatch3
    6
    0
    Aug 8, 2009
    word thanks chasen
    im confused by this step though - "Next we will need to solder the two wires in the middle of the switch to the appropriate grounds(labeled above) this is where you will use the heat shrink or electrical tape, make sure these two wires dont touch anything else."
    where do i ground the middle and bridge?
  10. woodmusic
    12
    3
    Aug 16, 2013
    Hi,
    Here you have the same mod, but better explained. It´s
    "PROJECT THREE - TWO PUPS (OF THREE) IN SERIES":
    Also, on the top of the page, you have a picture of a
    push/pull pot with each lug labeled so you don´t get
    confused. Imagine you hold the external end of the pot,
    the shaft, on top facing towards you; therefore A and D
    lugs are on top, and C and F lugs are on the bottom.
    Here´s where you have to solder the bridge and middle
    ground wires:
    Move the middle pup negative lead to LUG "B" lug.
    Move the bridge pup negative lead to LUG "E" lug.
    I hope you get it now. Good luck!
    Cheers.
  11. Hipatch3
    6
    0
    Aug 8, 2009
    awesome figured it out, i was hoping to get a brighter 'bridgier' humbucker tone from this mod but its more jazzy quacky middle position tones but still very cool.
    I also added a little jump wire so i can have tone control for the bridge pup
    thanks for the help wood :)
  12. woodmusic
    12
    3
    Aug 16, 2013
    Hi,
    Did you try the bridge and neck combination which is activated
    by placing the pickup selector in the bridge position? This
    combination sounds brighter and not quacky. It shouldn´t
    sound quacky because these pickups are further apart. Mine
    doesn´t, and has a brighter tone than the neck and middle
    combination. Neck and middle sounds fatter and a bit quacky,
    not as much as in standard configuration though, and yes, it´s
    a warmer fatter jazzy tone.
    Of course, the tone you get depends on the pickups you use.
    My bridge pickup is a Seymour Duncan ssl-5, David Gilmour´s
    pickup, which is a hot pickup, and when in series with the
    neck pickup, I get an even warmer hotter humbucker type of
    tone but still bright and not quacky.
    Cheers.
  13. lighterfluid97
    lighterfluid97 Member
    35
    4
    Nov 12, 2012
    Very, very cool! Looking at the switch used and the thick tone coming from the amp, I'm assuming that this is what Joe Perry had on his strat when they performed "Train Kept A Rollin" on 'Midnight Special' in 1974
    [ame=http://www.youtube.com/watch?v=ZxXI2BPRzaA]Re: AEROSMITH - Train Kept A Rollin' ,1974 - YouTube[/ame]
  14. greybox
    greybox Junior Member
    1
    0
    Oct 5, 2014
    I did this mod today but ended up using a 3 position mini switch, down is regular strat sounds, up is the modded sounds - cool accident, when mini switch is on off and reg switch is in positions 3-5 it mutes the guitar - perfect for in between songs or when changing cord/cables/pedals/amp setting - etc!
    The mod works awesome by the way! Thanks!
  15. Martinfrias
    Martinfrias Senior Member
    172
    184
    Mar 20, 2013
  16. Darkstream
    Darkstream Junior Member
    4
    2
    Apr 15, 2015
    I love this mod, can I achieve the exact same mod with a push/pull switch?
    I've seen a diagram for one, but for position 3 it has bridge and middle parallel ran in series with the neck, which is opposite of yours.
    Any reply and help with a diagram would be greatly appreciated, thanks.
    -Cheers
  17. J-E-M
    J-E-M Member
    93
    73
    Mar 23, 2015
    I've tried this mod before, and I found that if the neck and bridge pickups have similar output strength a quacky tone is the result. When I tried a hotter bridge pickup - about 60% more resistance than the neck pickup - there was hardly any quack at all. Either way, cool tones.
    These days I'm using substantially overwound pickups - they're already quite beefy in sound, so a series connection between the neck and bridge pickups would be insane. :eek:
  18. Frogfur
    Frogfur Senior Member
    13,170
    19,486
    Jan 18, 2013
    Very informative, and interesting thank you.
    I took the easier route and added a blender pot,madter volume and tone to mine and thst works for me.
    But this is really groovy too.
  19. KP
    KP Senior Member
    16,477
    18,120
    Apr 30, 2008
    Yeah, Fralin Blender as well on my MIM. I have a push-pull on my Partscaster for neck/bridge combining.
  20. paco1976
    paco1976 Senior Member
    2,254
    1,609
    Oct 24, 2013
    Amaaaaaaazing mod!!!! Best Strat sound ever.
    Made it today and still can't believe how good the bridge pup is sounding now.
