How much does a 335 weigh?
Discussion in 'Other Gibsons' started by fett, Feb 25, 2018.
  1. fett
    fett Senior Member
    7,606
    6,282
    Jan 21, 2012
    Thanks.
  2. LSAR
    LSAR Pure Evil Premium Member
    1,039
    1,057
    Apr 28, 2012
    Sweetwater seems to show right around the 8 lb mark is average with a few ounces of wiggle room either way.
  3. fett
    fett Senior Member
    7,606
    6,282
    Jan 21, 2012
    Thanks. I have a MIJ, '70's? knock-off with a set neck. It seemed kinda light. The previous owner upgraded the tuners. Guess what? They are genuine Gibson "Flower" tuners. They are worth more than what I paid for the complete guitar.
  4. afjungemann
    afjungemann Senior Member
    726
    592
    May 23, 2014
    How much does an les Paul weigh? ;)
  5. fett
    fett Senior Member
    7,606
    6,282
    Jan 21, 2012
    10 to 12 tons.
  6. rclausen
    rclausen Senior Member
    2,693
    2,075
    Nov 9, 2011
    7.5-8.5 lbs on average
  7. bblooz
    bblooz Silver Supporter
    2,690
    1,197
    Oct 8, 2014
    A lot of the imported knock-offs are true hollow-bodies, or use a lighter wood for the center block. I've seen some with Balsa in the center, which weighs almost nothing (Gibson used this in the Studio Lite series in the '90s and called it "Chromite" - much like they call their masonite finger boards "Richlite" today!). Some of these are in the ES-330 weight range, around 7 lbs!
    LSAR likes this.
  8. SFK
    SFK V.I.P. Member
    8,297
    12,507
    Mar 25, 2007
    My '14 Warren Haynes 335 per Sweetwater weighs 7 lb 10 oz.
  9. Dilver
    Dilver Senior Member
    1,013
    1,516
    Apr 26, 2011
    Off topic, I know, but I own one of these Studio Lites... yes, about 7.5lbs. But the amount of wood removed and replaced with Balsa is actually less than weight relieved guitars. They do sound a little different. Still, Ebony fretboard on a non-white LP Studio, is pretty cool.
  10. rtTX
    rtTX Member
    76
    50
    Sep 12, 2017
    2017 ES-335, Figured Cherry, 8 lb. 5 oz. (after replacing standard Grovers with locking Grovers).
