How Many Of You Put Foam Under Your Pickups?
Discussion in 'Pickups' started by izzwardo, Jan 3, 2014.
  1. izzwardo
    izzwardo Member
    51
    60
    Apr 7, 2013
    I recently was watching a video on you tube of Slash's AFD visiting Semour Duncans shop and I noticed there was foam under his neck pickup so I googled it and found numerous articles about it. I have read that it can add sustain, and better harmonics to your guitar. How many of you have done this to your gibbys and have you noticed any difference? I just finished putting foam inserts under my pickups in my 04 Gibson Les Paul Standard (see pics)[​IMG]
    cherryles and Graham H like this.
  2. Flyfish-mt
    Flyfish-mt Senior Member
    1,171
    620
    Nov 20, 2012
    Interesting, I'll keep an eye on this thread.
  3. mgenet
    mgenet Cheese Burger = Earth Silver Supporter Premium Member
    10,759
    14,511
    Sep 18, 2010
    I thought the foam was to help keep the PUPs level to the strings so
    one could achieve better tonz. That's my input.
    Anyone with more experience?
    11 people like this.
  4. WholeLottaIzzy
    WholeLottaIzzy Senior Member
    4,342
    8,119
    Jan 11, 2013
    This made me genuinely laugh aloud. I think this is hilarious. It sounds like Slash is a cork sniffer. If someone can prove it then I'll admit I'm wrong. But until then.... :laugh2: :laugh2::laugh2:
    3 people like this.
  5. marvar
    marvar Senior Member
    665
    523
    Jan 19, 2011
    That's the only reason I do it- and yes it helps the tone a bit, not a real significant amount, ime.
    I don't think the foam itself contributes to sustain or anything magical- just gives the pickup a full length 'window' of the stings.
    And, it gets on my nerves to see an un-level pickup!:laugh2:
    5 people like this.
  6. wheelsdeal
    wheelsdeal Senior Member
    656
    550
    Jan 25, 2012
    I find it unlikely a piece of foam would contribute to the sound but honestly i dont know.I would think its used for insulation purposes.Nice LP btw.
  7. Scott_UK
    Scott_UK Senior Member
    164
    75
    Feb 27, 2012
    Me too as I've never heard of this before!
  8. BadLuck&Luke
    BadLuck&Luke Senior Member
    136
    118
    May 15, 2012
    Same as the poster a few before me, I've only heard it being done to keep the pickups level to the strings. This isn't a problem on Les Pauls anyway due to the top carve and/or neck angle.
    I can't see that it would do anything for the tone. Happy to be proved wrong though.
  9. rjshare
    rjshare Senior Member
    4,935
    5,033
    Feb 13, 2011
    i'm sure its just for levelling purposes - i have it Under some p90s and i believe it is/was quite common practice with them, rather than using a spring to push up against the adjusting screws.
    2 people like this.
  10. THDNUT
    THDNUT Senior Member
    15,025
    20,926
    Feb 5, 2012
    Once I get my pups adjusted just so, I foam them in with "Great Stuff". :laugh2:
    6 people like this.
  11. EDS1275
    EDS1275 Banned
    4,385
    3,662
    Nov 24, 2013
    I needed to do just that with my EBMM Luke signature. The EMG's on that guitar are screwed right to the body so the only way for me to adjust their heights, level them out in relation to the strings while maintaining a stable base was to use foam. However I never put foam underneath pups for OP's reason
  12. The_Sentry
    The_Sentry Senior Member
    27,005
    9,328
    Dec 12, 2008
    I did that for a while. I honestly don't think it makes all that much difference with a solidbody electric.
    Peace
  13. mgenet
    10,759
    14,511
    Sep 18, 2010
    My P-90s on the Studio are not level. Looks wrong.
    Other guitars not so much.
    Now where did I leave that foam...
  14. tonepad
    tonepad Senior Member
    145
    56
    Nov 12, 2013
    Definitely a common trick for SG bridge pups. They are usually quite slanted in relation to the string plain. It does help with those guitars, but only in leveling the playing field so to speak. The difference for a LP would be minuscule in that regard.
    1 person likes this.
  15. keiffer76
    keiffer76 Senior Member
    538
    314
    Jan 2, 2013
  16. chrisuk
    chrisuk Senior Member
    2,649
    1,924
    Sep 19, 2010
    I'm pretty sure on the SD video it says Slash had the foam in there no try to cut down on microphonics and when Seymour finishes re-potting the pickups he throws the foam out.
  17. Waldquelle
    Waldquelle Senior Member
    205
    100
    Nov 18, 2012
    I do, because I have Soapbar P90s and only the springs arent enought to keep it stable.
    2 people like this.
  18. CRobbins
    CRobbins Premium Member
    7,040
    9,054
    Feb 20, 2012
    I've heard it being done to help control feedback on semi-hollow body guitars.
    I also have foam beneath the pickups on my Pbass.
  19. GitFiddle
    GitFiddle Senior Member
    10,816
    13,242
    Jun 2, 2010
    I like to run my pickups foamless. They run cooler that way. :cool:
    3 people like this.
  20. Bristol Posse
    Bristol Posse Senior Member
    2,230
    2,845
    Jul 26, 2010
    I can see it acting as a vibration absorber which would potentially make an unpotted pickup less reactive to the guitar but in high gain might cut back on microphonic feedback
    In a potted pickup I cant see it doing much of anything
    Leveling the pickup to a perfect plumb line might be worthwhile if it is categorically the angle of the pickup that is causing horrible sound
    I can't see a reason to do it myself, I like how my guitars sound with the pickups at whatever angle they happen to be at and I'd be worried about killing the life, part of which comes from vibration, in my unpotted pickups
    Its funny because in P90 guitars I've read plenty of purists claim that foam is the lazy mans way of avoiding wood shims and that the foam kills the tone of the pickup vs straight into the guitar
    YMMV
    C.J., geetarfreek82 and Quill like this.
