How many customize their LPs??
Discussion in 'Epiphone Les Pauls' started by jeff_farkas, Nov 9, 2017.
Is it worth it?
  1. Yes
    58 vote(s)
    87.9%
  2. No
    8 vote(s)
    12.1%
  1. jeff_farkas
    jeff_farkas Senior Member
    32,800
    21,273
    Nov 1, 2008
    1 I plan on the 50's wiring and 500K pots all the way around. And I had planned on the toggle switch as well. Get it all changed over.
    2 My plan was to check with the tech and if he thinks it's needed I was going to have him put a bone nut in. But, the black sounds cool from an athletics point,
    The upgrades aren't needed but I want to do them to make this my guitar. It's just the touches that will make me love it that much more.
    Thanks.
    Jeff
    Jymbopalyse likes this.
  2. DB Chuckster
    DB Chuckster Member
    58
    50
    Feb 6, 2015
    Put a JB/Jazz set in my epi lp Classic and was a massive improvement. Put the Whole Lotta Humbucker set in a walnut SG and that thing is insane. Upgrades to epis are totally worth it.
    jeff_farkas likes this.
  3. AudioWonderland
    AudioWonderland Senior Member
    436
    281
    Nov 1, 2010
    Replaced the pots/caps with an RS kit 50's style and the pickups with a set of antiquties I have owned forever in my Standard. Everything else is solid. No need to change
  4. BadMojo
    BadMojo MLP Vendor
    247
    267
    Nov 11, 2017
    If it makes you want to play it more.. it’s definitely worth it.
    Do it up!
  5. leifpaul
    leifpaul Senior Member
    953
    482
    Sep 25, 2007
    hmm, more like upgrading on my part
  6. Destroythevoice
    Destroythevoice Senior Member
    121
    55
    Nov 7, 2016
    Didn't read the entire post yet to know if you purchased them yet.. but I actually am a huge fan of the SH-1 59 neck pickup and the SH-5 Custom or SH 6 for bridge pickups combo. (I'm a metal player.. But these are very versatile pickups in my experience)
    Who and jeff_farkas like this.
  7. jeff_farkas
    32,800
    21,273
    Nov 1, 2008
    A member is selling me a pair so I'm all set. But thanks for the advice.
    Jeff
  8. Jymbopalyse
    Jymbopalyse Senior Member
    2,258
    4,796
    Oct 3, 2016
    I've made similar modifications to two of my three Epi's.
    And like you, they weren't needed, but it did make me feel more a part (funny apart almost means the opposite) of my guitar. Sounds silly, but I can't even bare to part with the old clunker Custom I picked up to try some of these upgrades on.
    Sounds like you have a tech all lined up and the modifications are inevitable.
    Be sure to let us know what you think of the mod's once you have had a chance to play it!
  9. jeff_farkas
    32,800
    21,273
    Nov 1, 2008
    Will do.. the tech I had originally wanted to do the job is no longer in business so I have to use a local guy, He does good work and the prices are decent.
    Jeff
  10. Koebiguitar
    Koebiguitar Member
    33
    15
    Jul 29, 2017
    You bet
  11. Koebiguitar
    Koebiguitar Member
    33
    15
    Jul 29, 2017
    Good advice Kumpel
  12. scozz
    scozz Senior Member
    3,300
    3,823
    Sep 3, 2007
    I do on some, some others I have are stock.
  13. truckermde
    truckermde Senior Member
    14,462
    20,900
    Oct 21, 2012
    I used to change everything on my guitars, mostly because I enjoy doing it.
    I'm not doing as much lately. I have a Yamaha that is completely stock, except for the knobs and p'up covers; so strictly cosmetic. My LP is stock except strictly cosmetic swaps, like knobs, switch-tip, and tuner buttons.
    Hell, I'm a bit surprised to admit that three of my four electric guitars have the stock p'ups, and the one with an upgrade has only the bridge p'up swapped out.
    I guess part of the reason I'm not doing it is because I simply can't find the time anymore, and another reason is that guitars have gotten so darned good lately.
  14. Petergrifindor
    Petergrifindor Senior Member
    349
    389
    Mar 30, 2015
    I went from this:
    to this:
    Your guitars, your rules.
  15. arc anjil
    arc anjil Senior Member
    268
    132
    Feb 11, 2013
    I replaced the knobs with reflectors on my honeyburst, gives it a vintage-y look.
    I need to replace the nut - it's sticking on the G and B strings, and I'm thinking of replacing the Probuckers with Pearly Gates....
  16. Pal
    Pal Senior Member
    1,203
    1,693
    Aug 20, 2013
    I changed pots, caps, wiring and pick ups on my 2013 LP Trad Pro not long after I bought it.
    It has been my #1 for years now.
  17. JDG
    JDG Junior Member
    2
    0
    Dec 13, 2017
    I did a lot of work on my 97 Epi Les Paul. I changed tuners, added Tusq nut, changed neck pickup to GFS Lipstick Humbucker, changed Bridge pickup to GFS Dream 180, changed all pots to Alpha Pots with coil tapping, added a traditional stopbar in place of the vibrato, changed pickup frames to chrome, changed the finish from Gold Flake to Vintage Aqua.
    I love it, the neck and body was great as most Epis are but the pickups, hardware and electonics were pretty cheap. I posted before and after pics in another thread but I will post them again. I could've went with better pickups and pots but I liked the GFS pickups just fine and I really wanted to keep the cost low.
  18. kasu
    kasu Senior Member
    1,484
    1,785
    Mar 16, 2010
    My Goth. Wouldnt have gone though the trouble if it hadnt been a great LP to start with. Beside the obvious.. A bone nut, Nashivlle bridge and IronGear pups. Played around with vinegar and dissolved steal wool to age/darken the wood and finished it off with a few layers of nitro.[​IMG]
    [​IMG] [​IMG]
  19. GuitarMechanic
    GuitarMechanic Senior Member
    952
    449
    Dec 9, 2010
    I have that same one and I like it.
    Had a broken wire inside so 1950s wiring here we come.... Probably change pickups too
  20. sasquatch
    sasquatch Premium Member
    1,742
    423
    Jun 29, 2008
    Some parts need replacing right away,
    However, most of the time the guitars come with no problems.
    This was a need and desire all in one,
    and the outcome couldn't have been
    any more to my liking.
    Have FUN and jeff_farkas like this.
