How Do You Store It?
Discussion in 'Gibson Les Pauls' started by hockeyplayr, Apr 11, 2011.
  1. deadlyweasel
    deadlyweasel Silver Supporter
    1,465
    1,117
    Mar 25, 2011
    I have a devil may care attitude about storing mine...
    thatF-INGflyingVguy likes this.
  2. thatF-INGflyingVguy
    thatF-INGflyingVguy Senior Member
    2,305
    2,647
    Dec 5, 2015
    stacked like cordwood in a trailer
    deadlyweasel likes this.
  3. Justin_Case
    Justin_Case Senior Member
    5,968
    3,379
    Apr 29, 2009
    Nope.....
    I need a couple more racks......
  4. wmachine
    wmachine Senior Member
    547
    418
    Dec 4, 2015
    This is the most space efficient, but goes against all traditional and professional advice not to store them flat. I'll just let it go at that, I'm not going to debate this.
    Carry on.
  5. Justin_Case
    5,968
    3,379
    Apr 29, 2009
    A few of those cases have 35 to 40 year old gutiars in them - never an issue.
    The quality of the case - neck support, and the environment of the room are immensely more important. The vast majority of gutiars having damage over long term storage are humidity and temp changes.
    I used to go to a lot of church flea markets and rummage sales back in the 70s / 80s - You'd cry seeing the amazing pieces that were destroyed by being put in an attic or basement.
  6. bwillard
    bwillard Senior Member
    890
    952
    Jun 5, 2009
    Here is how I store mine:
    bungle and Cygnus X-1 like this.
  7. Left Paw
    Left Paw Senior Member
    4,006
    2,388
    Dec 29, 2013
    This ^^^^^^ But failing to have such a piece of equipment like that, flat or on its side is fine.
  8. Guitpicky
    Guitpicky Senior Member
    119
    113
    Apr 11, 2017
    First I fill all empty spaces between the guitar and case with microfiber covered inflatable air bags filled with nitrogen gas. Then I suspend the case from a 4x12 Brazilian rosewood beam using oxygen free Kevlar cables attached to heat treated aircraft grade titanium hooks. They are raised and lowered using computer controlled precision electronic winches with hand wound motors. This is of course all contained in a hermetically sealed micro-climate with precisely controlled temperature, humidity, barometric pressure, and air quality. The hermetically sealed chamber is enclosed in a double walled triple reinforced earthquake, flood, and fire proof high security underground vault with advanced retinal scanners and 2048 bit military encryption :)
  9. Bigcat2017
    Bigcat2017 Member
    43
    36
    Feb 9, 2017
    I choose electronic dry cabinet, each one can be used for 2 acoustic or 4 electronic guitars:
  10. NorlinBlackBeauty
    NorlinBlackBeauty Senior Member
    6,514
    19,082
    Oct 29, 2017
    If I had that many, that is how I'd do it.
    I keep mine in their cases, sitting on the case hinge edge.
  11. NHTom
    NHTom Senior Member
    666
    786
    Jun 7, 2014
    My inspiration.............
    NHTom
  12. LOSTVENTURE
    LOSTVENTURE Senior Member
    672
    308
    Jun 27, 2011
    Mine are all kept in their cases, stored vertically, in closets with no room for falls, and with motion detectors monitoring for unexpected visitors.
    I was robbed of several guitars a short while back and don't want to go through that again.
    By the way, some of my instruments have been kept like that for over 30 years with no ill effects.
  13. NorlinBlackBeauty
    6,514
    19,082
    Oct 29, 2017
    I've read that it is best to avoid resting on exterior facing walls.
  14. Guitpicky
    119
    113
    Apr 11, 2017
    Especially on the outside :)
  15. Mockbel
    Mockbel Senior Member
    2,360
    2,173
    Nov 2, 2015
    Found this on internet...
    I think any other position is OK.. To be honest I think even this position above is OK !!
    I keep my guitars up on their sides most of time... rarely on their back... as below:
    My question is, if they are on their back, is it OK to put multiple guitar above each other?
  16. Guitpicky
    119
    113
    Apr 11, 2017
    It needs a sticker on it saying "Please don't steal" :)
  17. NorlinBlackBeauty
    6,514
    19,082
    Oct 29, 2017
    Define multiple. Personally I'd not make it more than 4.
    Mockbel likes this.
  18. bungle
    bungle Premium Member
    2,262
    2,426
    Feb 1, 2011
    Either on the wall hangers or upright in cases.
