How Do You Store It?
Discussion in 'Gibson Les Pauls' started by hockeyplayr, Apr 11, 2011.
  1. hockeyplayr
    hockeyplayr Senior Member
    133
    44
    Apr 6, 2011
    This may sound stupid and may have been asked hundreds of times (i did search and found nothing relevant though) but how do you store your guitars when they are in the case? Upright? On it's back? On it's side?
    I read that storing it upright isn't recommended by all then i read on it's back isn't either. I'm probably just being anal, but i want to make sure i take care of this guitar the best I can, even though its only a studio.
    Thanks
  2. nauc
    nauc Senior Member
    12,555
    8,477
    Oct 29, 2008
    i just keep mine like this, in a corner...
    im afraid ill step on it if its laying down
    and if you stand it up and it gets knocked over, the headstock can break even if its in the case
  3. Ledheadforlife
    Ledheadforlife Senior Member
    8,861
    6,444
    Mar 15, 2009
  4. Kalamazuu
    Kalamazuu Senior Member
    6,685
    3,551
    Dec 1, 2010
    Personally I think they'd be find on their back too, as they are solid and in a case, cellos, basses are put on their sides because they are more stable and it doesn't warp the back, but violins and violas are stored on their backs in the cases and are fine. Overall I don't think it will make much of a difference. also cellos and bases generally have soft cases and are stuck upright facing inwards in a corner, on the side is kinda just between sessions/ when you get up for a second. Or on a rack.
    Hope that helps
    Kzoo
  5. bobarino
    bobarino Senior Member
    3,396
    2,417
    Jan 17, 2011
    i just leave 'em out of the case, hangin' from their headstocks.
  6. QuicksilverSS
    QuicksilverSS Silver Supporter
    12,917
    11,398
    Aug 6, 2009
    I have mine laying in the clothes basket on top of my socks as we speak.....:rolleyes: true....:D
  7. acstorfer
    acstorfer Senior Member
    19,608
    21,126
    Oct 21, 2008
    Flat, afraid it might fall otherwards. And don't forget the humidifier!
  8. planks
    planks Senior Member
    15,039
    6,233
    Feb 16, 2010
    I have my cases standing on their side, easy to pick them up.
    On it's back or upright should be fine as well, as long as when it's upright you make sure it can't tilt.
  9. zontar
    zontar Senior Member
    10,209
    3,910
    Dec 8, 2008
    In the hardshell case, standing up off the floor (in a basement--don't want cold or water getting to them) and there are barreoers on each side it (And my other guitars) won't fall over.
    No humidifiers for my solidbodies--(never needed one in the local climate. Maybe you need one where you are.)
  10. Sirzach
    Sirzach Senior Member
    2,846
    1,367
    Jul 21, 2009
    Hardshell case leaning against the wall. I'd put it flat, but with my other guitars and 3-guitar stand between the desk and wall, everything is packed securely against each other and can't fall over.
  11. GitFiddle
    GitFiddle Senior Member
    11,022
    13,812
    Jun 2, 2010
    Mine all stand upright in their cases against the wall in a corner where they can't fall over.
  12. Justin_Case
    Justin_Case Senior Member
    6,000
    3,432
    Apr 29, 2009
    These are Home Depot $99 special racks - works great. Off the floor and you can put other things on them too.
    Roman4405, NHTom, dCi_king and 15 others like this.
  13. Thumpalumpacus
    Thumpalumpacus Senior Member
    76,014
    186,253
    Nov 28, 2010
    Wall hooks work for me. But our climate here has steady humidity, my son's old enough to know better than to mess with them, and my apartment is small. Plus, I need not buy any more art.
  14. BoogieMan_SC
    BoogieMan_SC Senior Member
    209
    56
    Dec 16, 2010
    +1...same thing for the same reasons...
  15. hockeyplayr
    133
    44
    Apr 6, 2011
    Thanks for all the responses, im guessing pretty much anyway is fine it's just a matter of preference. Now its time to find a place in my tiny apartment to put it (i live with three roommates and have little room as it is).
  16. b3john
    b3john Senior Member
    5,204
    3,792
    Jun 5, 2010
    Now I know why they call you Justin Case. :laugh2: :thumb:
    TN..Steve likes this.
  17. Belzeebub
    Belzeebub V.I.P. Member
    2,721
    56
    Apr 1, 2008
    I keep 'em all upright, BUT, they are all securely in place...backed against paneled walls on two sides and bordered by solid, heavy "stuff" on the other two sides - so there ain't a chance these babies are going to fall on their sides - unless the entire wall is comin' down.
  18. Sloppy Joe
    Sloppy Joe Senior Member
    2,140
    2,028
    Apr 29, 2010
    Usually on its side, but sometimes upright.
  19. jamman
    jamman Premium Member
    9,342
    7,559
    Oct 1, 2010
    That's great, thanks for the Idea. I'm going in the morning.:applause:
  20. sonar1
    sonar1 Senior Member
    16,488
    59,313
    Apr 7, 2011
    Same here.
