How do you like your Strat tremolo set up?
Discussion in 'Fender' started by I Break Things, Jun 11, 2017.
How do you set up your tremolo?
  1. Floating
    16 vote(s)
    43.2%
  2. Decked but still able to dive
    12 vote(s)
    32.4%
  3. Completely blocked. I hate that thing!
    8 vote(s)
    21.6%
  4. Rat's hind end
    1 vote(s)
    2.7%
  1. I Break Things
    I Break Things Senior Member
    3,495
    6,782
    Nov 27, 2016
    So being a new owner of a Strat, I've had a lot of fun tinkering with it and getting it set up in a way I like it. I did a lot of research on setting up the tremolo and trying out a lot of the suggestions I read around the web. My Strat has a vintage style 6-screw trem, so it took some tinkering, but I've got it floating and I can pull it up so the G goes to an A#, B goes to C#, and E goes to F.
    So, my fellow MLPers, how do you like to set up your Strats and why?
    Who, Falconbill and truckermde like this.
  2. truckermde
    truckermde Senior Member
    14,228
    18,292
    Oct 21, 2012
    I do the wood block ala Clapton.
    I like a hardtail, but believe the springs, and the resonance they create, form part of the signal chain, and contribute to the sonic difference between a Strat & a Tele.
  3. I Break Things
    3,495
    6,782
    Nov 27, 2016
    Strats are definitely unique. I've had a lot of fun playing around and getting all these sounds I can't get from my LP.
    Telechamp, Kris Ford and truckermde like this.
  4. DarrellV
    15,498
    33,214
    Nov 1, 2016
    Also the type of plastic used in the pick-guard and the number of and direction of the plys contribute to the toanez!
    I posted a write up on this in the Stratoshere pick guard thread!
    And i quote;
    'Many folks that take up fixing their Strats overlook the importance of the pick guard.
    Unlike Gibsons in general, Strat pickups are mounted to that thin piece of plastic and hang in open space underneath..
    Unlike wood, the plastic will pick up vibrations from the strings and your amp and transfer them to the pickups.
    This is a part of what gives the Strat a unique tone..
    So choosing the right formula, thickness, number of plys, etc. is of VITAL importance if you want the magical Strat Toanze to pour out of your new investment...
    The wrong molecular structure of the polymers or improper ply lamination could result in a dreaded tone turd!
    Choose wisely.....'
    Chasenblues about peed his pants! Strats are awesome!
  5. jimmyjames
    jimmyjames Senior Member
    2,104
    2,061
    Apr 22, 2013
    A little float floats my Callaham's boat :cheers2:
  6. Guitaraxe
    Guitaraxe Senior Member
    738
    344
    Aug 22, 2015
    Fat 50's AmSt....... depends... If It's being used as my main I keep it decked, 5 springs down only but if not I like it floating.
  7. Stevie 202
    Stevie 202 Senior Member
    6,208
    11,926
    Dec 31, 2011
    Jeff Beck Strat......floating.
    If I had another Strat I'd probably deck one and float one.
    I like 'em both ways.
  8. SteveGangi
    SteveGangi V.I.P. Member
    30,887
    57,370
    May 20, 2010
    Mine is floating.
  9. bulletproof
    10,948
    25,195
    Jun 1, 2011
    +1000
    truckermde likes this.
  10. Bud Stoner
    Bud Stoner Senior Member
    1,918
    1,420
    May 20, 2008
    I have three Strats and they're all different.
    1974 modded with a Floyd Rose is floating in a recessed route (I didn't do the Floyd, I just got it that way).
    1995 Am Std decked and can dive has Hipshot bridge installed.
    2008 Road Worn 60's Oly White floats nice and sweet with a steel block and Raw Vintage springs.
    Stevie 202 likes this.
  11. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    I like a float, but rarely use the trem.
    Who likes this.
  12. NotScott
    NotScott Silver Supporter
    1,866
    3,866
    Nov 25, 2012
    All of my Strats have the bridge decked but not blocked. I use 5 springs and tighten them just enough so that bends of a whole-step won't detune the other strings. If I were to float it, I would set it up like Jeff Beck, pulled all the way back results in a half-step up. I setup my PRS like this and like it.
    Thumpalumpacus likes this.
  13. mekhem
    mekhem Member
    36
    15
    Apr 4, 2017
    IMHO - It really depends on the strat. Crappy answer really but each one is a little different in how it responds.
    I have a couple currently: EC strat <decked obv.>, 69 Strat <decked currently w 5 springs> 59 style strat with a 'regular' float and 4 springs. I tried it with 3 and that didnt really work out so well, but with 4 its dead stable.
  14. Telechamp
    Telechamp Senior Member
    2,045
    1,549
    May 26, 2008
    My four - all floating.
    Falconbill and I Break Things like this.
  15. Who
    15,818
    28,139
    Mar 15, 2012
    Floating. A YouTube video from Frudua (or some spelling close to that) takes all the work out of getting set up correctly.
    Telechamp, mekhem and Stevie 202 like this.
  16. I Break Things
    3,495
    6,782
    Nov 27, 2016
    So my MIM Strat didn't come with the spring to keep tension on the arm, and it flopped about while playing. Just got some of those springs in the mail and I like the trem even better now that the arm stays where I want it. :dude:
    I might be converted to a Fender guy after how much I've enjoyed this Strat...:hyper:
    Falconbill and Telechamp like this.
  17. I Break Things
    3,495
    6,782
    Nov 27, 2016
    Nice guitars! What models are they and what's that one at the far end?
    Telechamp likes this.
  18. mekhem
    mekhem Member
    36
    15
    Apr 4, 2017
    This! Definitely. I meant to post it...
    I also use his action trick...
  19. Telechamp
    2,045
    1,549
    May 26, 2008
    Thanks!
    In order: 2011 American Standard, '98 Classic 50's, '04 MIM Agave Blue Std, '08 Road Worn 60's.
    The guitar on the end is a Guild S-284 Superstrat - no floating on that one. It's got a Kahler trem system.
    I Break Things likes this.
  20. Telechamp
    2,045
    1,549
    May 26, 2008
    Yeah, I know what you're saying - those little trem arm tension springs are essential in my book!
    I Break Things and Who like this.
