How do I record several different instruments into separate tracks on Garageband?
Discussion in 'Recording Studio' started by Grad, Dec 31, 2010.
  1. Grad
    Grad Junior Member
    8
    0
    Dec 7, 2010
    I have a Macbook Pro and I want to be able to carry it to a friends' house and record some of our jam sessions. Is there a way to record several guitars, some vocals, and a harmonica all at the same time into Garageband? Can they go in as different tracks so I can adjust them later? If not...can I buy a cheap mixer and connect it to a USB interface like a Line 6 or M-Audio Fast Track which will feed the audio into Garageband?
    Thanks in advance!!!
  2. mattD
    mattD Member
    82
    23
    Aug 19, 2009
    how you arm multiple tracks will depend on which version of GB you have. you can record up to 8 tracks simultaneously, to my knowledge. however, if you have a 4 channel usb interface then you will be limited to 4 armed tracks.
    Here is GB '11
    [ame=http://www.youtube.com/watch?v=6EhaHFY4rRU]YouTube - How to Multi Track in Garageband 11, iLife 11[/ame]
    and the same guy showing older version of GB:
    [ame=http://www.youtube.com/watch?v=21DUC_x_z5g]YouTube - How to record multiple tracks at a time using Garageband[/ame]
    for what it's worth Lewin has a ton of good GarageBand tutorials. There is even a series on mixing.
  3. BMS
    BMS Senior Member
    4,693
    616
    May 18, 2009
  4. northernguitarguy
    northernguitarguy SWeAT hOg
    27,483
    44,744
    Feb 22, 2009
    I agree and think gb is limited to 8ch. multitrack and the number of inputs on your interface....going beyond that will require logicpro which i am not ready to mess with yet
    one trick: run your guitar into an a/b/y box and send the two feeds into your interface, say channel 1&2. Enable the multitrack recording and you can record two guitar tracks at a time...
  5. Esspweb
    Esspweb Junior Member
    3
    0
    Dec 29, 2010
    Thanks mattD. Thank you so much.
  6. gehlmauer
    gehlmauer Junior Member
    1
    0
    Jan 7, 2011
    we have an electronic drum set and we plan to record the drum parts through midi into logic via a midi interface. i would like to be able to record each drum pad into a separate track so that each drum part can be treated independantly, i.e. different compression or eq for the kick, snare etc.
    _______________
    VLC Download
