How are you strapping on your Gibson (or Epiphone) SG?
Discussion in 'Other Guitars' started by e44crowe, Sep 26, 2017.
  1. e44crowe
    e44crowe Senior Member
    442
    329
    Jan 14, 2012
    I have recently picked up a fantastic SG 50s Tribute. It’s great!
    I usually put Dunlop dual design strap locks on all my guitars. LP, Tele, Strat...
    So. Put a pair on the SG and I don’t really like the way the strap sticks out behind the neck. Now the replacement pegs are still better than the tiny stockers and I can use a regular strap with the grolsch washers if I need to.
    What do you do for strapping on an SG?
    Who likes this.
  2. Who
    15,399
    27,054
    Mar 15, 2012
    A) Sell it, get a Les Paul
    B) Move the strap button to the proper location
    C) The Grolsh washer solution.
    If I had an SG, I'd choose B, or probably C.
    I chose A
    HCRoadie and Gold_topped like this.
  3. jkes01
    jkes01 Senior Member
    2,037
    924
    Jan 10, 2011
    I use these as well. Yeah, you can use the washers on the back, Grolsh, Fender, Dunlop, etc. The dual design buttons are designed to work on both their locks and a regular guitar strap without them. The issue you’ll face is that in order to use that strap on your other guitars, you will have to put the regular buttons back on them.
    Not sure if this is suitable, but I know Dunlop sell flush buttons that work with the same locks.
    I know, don’t shoot me. :thumb:
  4. Guitaraxe
    Guitaraxe Senior Member
    735
    343
    Aug 22, 2015
    I've been using Lock-It straps on my Firebird and Explorer.
  5. Benjammin
    Benjammin Senior Member
    19,301
    13,249
    Jul 4, 2009
    I used to use a 3" suede strap with Grolsh washers on my SG, worked like a charm :thumb:
    ant_riv and Thumpalumpacus like this.
  6. e44crowe
    442
    329
    Jan 14, 2012
    Oh I’ve got the LP covered it’s my #1. The SG is for light weight P90 goodness. ,)
    Who likes this.
  7. Biddlin
    Biddlin Senior Member
    1,529
    1,838
    Aug 21, 2012
    I use the stock buttons and make sure my strap is snug. I have no issues with any of my SGs, but then I play with both hands. In 53 years of playing on stage and at home, I have never dropped a guitar. .
  8. SFK
    SFK V.I.P. Member
    8,043
    11,724
    Mar 25, 2007
    I must be the only person in the world who can't work with the Grolsch washers. They always pop off.
    Maybe my straps are to thick?
    Anyway, Shaller strap locks sit a little closer to the body. I use those on my 335 and I like Dunlops on everything else.
  9. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,420
    8,236
    Apr 4, 2013
    For my SGs and DC LP Jr., I leave the strap button where it is (i.e., near the neck heel) and attach the strap in the opposite orientation of how you "normally" would for that strap button. In other words, the finished part of the strap will face the back of the guitar. It will be less twisted that way and less awkward in my experience. If you have a dedicated strap for your SG, you can still use your strap locks and just install them backwards for that strap button. I use the rubber washers.
  10. Telechamp
    Telechamp Senior Member
    2,038
    1,540
    May 26, 2008
    One of these. Simple and works great.
    Hothands likes this.
  11. edselman
    edselman Senior Member
    1,154
    588
    Mar 19, 2010
    This was a “huge” problem when my belly was so big. It made that SG really stick out and the strap literally got pried off the neck strap button. Now that I’ve lost weight, the problem seems to be solved.
  12. paruwi
    19,896
    26,478
    Dec 24, 2009
    Do it the Tony Iommi way....
    Who likes this.
  13. Kris Ford
    Kris Ford Senior Member
    4,754
    4,033
    Dec 17, 2011
    I've owned a SH!T ton of SGs..I have always used the Schaller locks.
    C_Becker, ant_riv and ht-57 like this.
  14. Who
    15,399
    27,054
    Mar 15, 2012
    I just noticed that last week. Tony's guitars have the strap pin in the proper location.
  15. Al Walker
    Al Walker Senior Member
    1,118
    1,118
    Sep 14, 2014
    If you move the strap button to the upper horn it will play easier, as in it moves the headstock closer to you. Just did this with my PGK Doublecut Jr. Also will probably cure the SG neck dive. Oh, and I use Shaller strap locks.
  16. nitrodave08
    nitrodave08 Senior Member
    1,818
    1,813
    Sep 29, 2013
    Washer on the back and Shaller on the bottom.
  17. jc2000
    jc2000 Senior Member
    6,212
    2,973
    Jul 16, 2013
    Strap locks for me. quicker and easier..
  18. Buzzin_Cousin
    Buzzin_Cousin Senior Member
    854
    306
    Dec 14, 2013
    Might be a good idea to put that screw back in the body/neck tho. It might be the only thing that saves the neck and body from separation in an unfortunate drop or similar challenge the the area.
  19. Al Walker
    1,118
    1,118
    Sep 14, 2014
    I put a stainless screw and a stainless upholstery washer in there.
  20. ant_riv
    ant_riv Senior Member
    1,069
    620
    Aug 4, 2009
    Schaller strap locks.
    C_Becker likes this.
