How are Edwards LPs so light?
Discussion in 'Other Single-Cuts' started by OBG57C, Apr 5, 2017.
  1. Udonitron
    Udonitron Psychedelic Stoner Rock Premium Member
    15,292
    9,738
    Aug 26, 2009
    No veneer here:
    Or here:
    Matty likes this.
  2. Olds442
    Olds442 Senior Member
    10,061
    12,104
    Jan 22, 2010
    ok i see what you are referring to. they must have done that with some guitars obviously. maybe the lower rungs of the models or painted versions of those models, who knows.
    i doubt you'd find that on a higher level eddy. i could be wrong though.
  3. SingeMonkey
    SingeMonkey Senior Member
    1,442
    635
    Jun 1, 2009
    If Udonitron's was also super light and one piece and very clearly not veneer, then it points to the species of wood used. If it were a true mahogany just grown under conditions that give a lighter timber, why wouldn't everyone use that?
    Most likely another species that isn't generally considered a 'true' mahogany. Definitely a great option for lighter LPs even if the sound is slightly different.
    Udonitron likes this.
  4. Olds442
    10,061
    12,104
    Jan 22, 2010
    that guitar has become somewhat of a local buzz. i sold it to a friend who guitar tech's at a local shop and gigs regularly. it's just got such a good feel to it, everyone who holds it freaks a little because it's so light. (And of course the fiesta red finish!)
    Matty and Udonitron like this.
  5. Udonitron
    15,292
    9,738
    Aug 26, 2009
    *gasp*
    You SOLD it!?
    For shame....for freakin shame.
  6. Olds442
    10,061
    12,104
    Jan 22, 2010
    not at all. you sold it too so don't shame me. :laugh2:
    it wasn't a money grab though, i let her go for $650 because I knew Doug really wanted it and i consider him to be a good friend. dude has jammed for 30 years, this is his first Les Paul, his chops and that ax make a great pair.
    and everyone loves the finish. :thumb:
  7. Udonitron
    15,292
    9,738
    Aug 26, 2009
    lol I was just buggin.
    Glad the new owner loves it!
  8. Angus Blackmore
    Angus Blackmore Member
    90
    45
    Aug 15, 2011
  9. tosh78
    tosh78 Senior Member
    189
    46
    Jan 26, 2014
    Mine is quite heavy compared to my other guitars, a bit more than 9 lbs, and actually selling it locally because of that reason.
  10. NJDevil
    NJDevil Senior Member
    262
    131
    Mar 30, 2014
    The weight difference is attributed to the difference in mahogany being that the lighter weight is different density in the wood. My Tokai LS-135 is over 9lbs. and my '14 LP Traditional is about 10 lbs. and my Edwards LP-92SD is a little over 8 lbs.
    Even though I've never measured it (it would take 2 minutes so I'm pretty lazy) but my Edwards looks like the body is a little thinner than both the Tokai and Gibson.
  11. Ph03n1x
    Ph03n1x Senior Member
    1,481
    856
    Dec 29, 2009
    Do those Edwards specials have fat necks like the Navigators? I saw a Nav special a couple of months ago but the neck was described as 60s profile.
  12. J-Dizzle
    J-Dizzle Senior Member
    2,721
    1,953
    Jan 27, 2011
    I used to have an Edwards Junior Special with P90s and the neck was so slim it felt like a toothpick. I don't mind a 60s slim neck but this was way beyond that, and just too thin. Because of the neck, I never really bonded with the guitar so I sold it, which is a shame because it was very well made.
    El Greco likes this.
  13. Ph03n1x
    1,481
    856
    Dec 29, 2009
    Yeah, I found a few people saying the same thing about skinny necks. I guess it is off the list for me. I am curious about the Tokai LSS specials. They have so many model numbers and it is hard to see any difference between them.
  14. nigelthebald
    nigelthebald Senior Member
    206
    150
    Apr 29, 2016
  15. El Greco
    El Greco Senior Member
    813
    587
    Mar 6, 2011
    I have an Edwards SG and I have the same problem! The neck feels very slim way beyond the 60's slim! So I measured the nut and found out it was at 42mm instead of the usual 43mm on most SGs and LPs! Mystery solved, problem not solved!
  16. Ph03n1x
    1,481
    856
    Dec 29, 2009
  17. Ph03n1x
    1,481
    856
    Dec 29, 2009
    I think you are referring to width. Most people here are talking about depth when they refer to thickness. Depth measurements usually taken at the first fret and can vary from 16mm to 24mm. Typical would be around 19-22mm. Profile is another thing as well.
  18. El Greco
    813
    587
    Mar 6, 2011
    Thanks! Yes I know, we are talking about depth here, but a 60's slim neck with a 42mm width, feels a lot skinier to my big hand, than a 60's slim with 43mm width! I didn't realize it is the width that feels slimmer, I thought the neck was super slim! Until I took some measurements..
  19. Ph03n1x
    1,481
    856
    Dec 29, 2009
    I would buy an Edwards if they had fat necks. In fact, I don't understand why guitar companies don't offer neck profiles in set neck models. It seems like with all the competition and technology, it should be easy to go online and order your LP with d-shaped fat neck with minimum / max acceptable depth range etc. No wonder so many people just make partscasters.
