Hmmm , ... Neck = 8.66 & Bridge = 9.27
Discussion in 'Pickups' started by BA-CHEE, Aug 8, 2017.
  1. BA-CHEE
    BA-CHEE Senior Member
    438
    75
    Mar 15, 2008
    And so today I was taking out my Gibson ES-345 Stereo Guitar outta storage to clean her up and do some maintenance on her. Well I decided to take a reading of the Humbuckers that are in her. The Neck measures out at 8.66 and the Bridge measures out at 9.27. That can't be right HuH ? She's a 1966 according to the serial number which is 368967. She has unopened Patent Number Humbuckers (Gold Plated). Are the readings possible ? Or am I hooking up my ohm meter incorrectly ? Thanks for any comments or assistance to the aforementioned query.
    cooljuk likes this.
  2. cooljuk
    13,581
    16,447
    Mar 12, 2009
    Those readings are possible, especially if you are hooking up your meter to the guitar's output jack and not the unsoldered pickup leads, directly.
    Another possibility is that the pickups are warm at the time of measurement, if you are metering them directly.
  3. bill m
    bill m Premium Member MLP Vendor
    1,860
    2,375
    Aug 14, 2010
    Another plausible possibility is your pots are not zeroing out on 10. Very common on old pots.
  4. Antigua
    Antigua Senior Member
    352
    65
    Oct 15, 2016
    I don't think those numbers are hard to believe, but they should be tested while unsoldered (which I wouldn't wager is worth the trouble). The parallel resistance actually decreased the measured DC resistance by some amount, because it gives the current an another path of travel other than the pickup itself. The actual DC resistance can be calculated by accounting for the 500k pot, but you also have to know the precise resistance of the pot, which probably isn't a perfect 500k, or just assume it's 500k (assuming that's what they're spec'd at) and that would get you closer than an output jack reading alone.
  5. scovell001
    scovell001 Senior Member
    189
    89
    Sep 3, 2015
    Agree with the others, not 'out of spec' at all. If the pups were unsoldered the reading would be even higher by about.20
    How does it sound?
  6. LtKojak
    LtKojak Senior Member
    3,945
    2,556
    Aug 26, 2009
    Then those readings are affected by the Varitone circuit. Pat#s clock at 7.5K on average.
    Don't sweat it. DC Readings have absolutely nothing to do with tone.
    HTH,
    6077dino likes this.
  7. hamerfan
    hamerfan Senior Member
    341
    83
    Jun 19, 2010
    Pepe nailed it!
  8. BA-CHEE
    438
    75
    Mar 15, 2008
    Cooljuk : Thanks for the "Like" , ... appreciate your comments too !
    cooljuk likes this.
  9. BA-CHEE
    438
    75
    Mar 15, 2008
    Here's some pics of the HBuckers that I am "talking" about :
    And "NO" they are not DOUBLE CREAM HUMBUCKERS , ... Darn !!!
    kboman and bulletproof like this.
  10. cooljuk
    13,581
    16,447
    Mar 12, 2009
    Pat number decals and nylon saddles. Mmmmmm, that's a nice combo!
    bulletproof likes this.
